Norwegian Plastic
Posts posted by Norwegian Plastic
On 8/31/2022 at 10:59 AM, Norwegian Plastic said:
Hei George. Jeg har enda ikke flyttet inn i nytt hus og er opptatt med snekring. Men om en måned....
Nå er jeg i gang med båten igjen. Hvordan går det med din?
- ccoyle, Veszett Roka and yvesvidal
- 2
- 1
On 7/25/2022 at 6:55 AM, Geam said:
Hi Andreas,
Jeg savner innslag og bilder fra deg og Carsten. Hvordan går det med CA RS1 bygging?
George
- JpR62, GrandpaPhil, Chuck and 3 others
- 6
On 3/31/2022 at 5:16 AM, Geam said:
That explains why there are so many of them....and also that they hang downwards even when sailing!
Well done, never thought of that🙂. Professional rescue-sailors in the old days would not need a piece of wool to help them set the sails properly!
Nice RS1 marking on the mainsail. I have been thinking about how to make that. good to see your example. Looks like you used the top of the glass to make the circle! I'll have to get one of those glasses before I do the sails🤪
See that you have the same Biltema compressor as I have.
Your RS1 looks really superb now👌👍
George
I have made a file for the Cricut and have a lot of adhesive paper. If you give me your adress i will cut all the masking you need for the main sail and snailmail them to you?
On 3/19/2022 at 8:20 AM, Geam said:
It's not really important, but if you want to make the telltales function during sailing, you may have to make them of thin, lightweight wool yarn. Off-White (ECRU) coloured "Dale Baby Ull" or similar.
George
I found out today that they are not telltales but ropes to tie the sail when reefed?
George
It will be a static model but able to sail. Believe I will sail it to get some cool pictures and a video and then it will be put in a glassed box built into the wall😂
- ccoyle, Paul Le Wol, Geam and 1 other
- 4
Colin Archer RS1 by Norwegian Plastic - Billing Boats - 1:15
in - Kit build logs for subjects built from 1851 - 1900
Hi! Well, almost done. Need to make and shape some rope coils to go on the pins and lay up the sheets as it is when sailing.
