Everything posted by DB789
Thanks Craigie, I’ve temporarily stripped off anything loose that I might get in the way of the rigging such as cannons, swivel guns, pumps, etc. Mast is added and all the spars and booms made, although still some blocks to add to these. Bowsprit ready too although I forgot to include it in these photos. I didn’t like the idea of shaping and tapering all of these using a drill as my experience of tapering with a drill is that I quite often break something. So I’ve added a Proxxon mini lathe to the toolkit. Made the spars and mast so much easier. I added the forward four shrouds on each side as these are those that need ratlines. Below I have added the starboard ratlines and afterwards the fifth shroud. Port just the front four shrouds. No ratlines yet. In the meantime, Vanguard’s Grecian has turned up and is waiting to be built. She looks to be a fine model as I’ve come to expect from Chris. I had planned to build Ranger next to complete the set of six Vanguard fishing boats, but I suspect I’ll dive straight into Grecian.
- 70 replies
- Alert
- Vanguard Models
She looks fantastic. Does anyone know a good beginners resource or a log on here on how to copper a ship’s hull? In particular, how do you get the waterline cut straight? I’m very keen to build Grecian, but I need to master coppering. Many thanks Dan
- 80 replies
- Grecian
- Vanguard Models
(and 3 more)
Thanks, I won’t add the fiddly parts yet. I think the pumps are still removable as the dowel is in tight but with no glue. I’ll follow your Pen Duick build with interest. Many thanks Dan
- 70 replies
- Alert
- Vanguard Models
I have been very remiss on keeping up my Alert log. Her hull is largely complete now, except for stanchions, swivel guns and anchors. None of which I’m adding until I have a good idea of whether they’ll get in the way of the rigging. No major issues in building her, but a few idiosyncrasies and lessons learned that I might point out. Firstly, that the pear wood strips came in a pale and dark colour, I thought the pale colour would look better on the exposed upperworks so I planked the stern in this and then later realised that there weren’t enough pale strips for all the upper works so the stern is now a different colour. Furthermore I didn’t select my strips well and the top starboard plank below the wales is very discoloured dark. Good lessons for the future. I decided not to fit the lower counter PE decoration. My lower counter is quite curved so I found it difficult to get the PE to lay flat and decided it looked better without. The PE would have worked fine if I’d followed the kit instructions and kept the lower counter flat. The stove flue, part 108 in the instructions, did not seem to be anywhere in the parts and is not listed in the parts list, so I built my own from excess on the 3mm wood sheet. Looking down the deck. The guns are not glued yet. I wish with hindsight I’d added breach ropes to them, but too fiddly to do now the eyebolts are glued to the gunwales. Also the wood gratings supplied with the kit in (v.3) don’t match up with what’s in the instructions. The numbering of parts is wrong and whilst the gratings are the correct sizes for the front and main hatches, the third grating supplied fits the bread hatch, not the rear hatch / skylight. The bread hatch is supposed to have a solid hatch in the instructions but I’ve chosen to use the grating as it looks better. Whilst for the third hatch I’ve had to use a PE grating and paint it which doesn’t look as good. I see lots of modellers have amended this to be a skylight. These are very much small things and Alert is an excellent kit, as usual from Vanguard. She’s the ideal bridge for me stepping up from the fishing boats to a larger warship from the age of sail.
- 70 replies
- Alert
- Vanguard Models
Thank you very much, I was just curious and hadn’t yet got to that point in BE’s log. I won’t be adding these details, I’m just sticking to the kit. Your Alert looks superb, I wish you’d done a log too.
- 70 replies
- Alert
- Vanguard Models
Thank you. I felt the painting is a complete mess compared to other boats on here. I realise that iPhone cameras are quite forgiving and don’t show all the botched paint and glue stains!
- 70 replies
- Alert
- Vanguard Models
That’s what I meant. The instructions refer to “step blocks for the mizzen mast”. Temporary makes sense, but even so it’s hard to see how a mast could be mounted on those? Thanks
- 70 replies
- Alert
- Vanguard Models
More progress, but still scruffy and needs tidying up. Starboard side with photo-etch decorations, wales, steps, etc added. Wipe-on poly as per Glenn-UK’s recipe on the wood. Port side less progressed and no wipe-on poly and some fittings yet. Stern decoration and the rudder added. PE decoration on the lower counter still to come. Some deck fittings and ironwork added. A couple of the cannon rings on the bulwarks have already fallen out. Please could someone explain to me how the mizzen mast works? I haven’t got the Goodwin Anatomy of the Ship book as I want to stay largely true to the kit (it’s challenging enough for me as it is without modifying!) so don’t want the temptation from a book like that - plus it’s expensive. Thanks! Dan
- 70 replies
- Alert
- Vanguard Models
Capping rails are now fitted. Together with the cat heads and the forward swivel gun mounts. Also added the stern board and much of its trim. I’ve put a plank in below the stern board as per JPalmer and Thukydides great advice. I’m not adding the sides of the rough tree rail until later as they’re fragile and I’m bound to break them at this stage. Lots of touching up to the paint required. She’s looking a bit scruffy!
- 70 replies
- Alert
- Vanguard Models
Thank you both. That’s great advice, I’ll do that.
- 70 replies
- Alert
- Vanguard Models
Grecian is looking super, such an unusual but great looking boat. I think very likely my next build after completing Alert. Maybe Ranger beforehand in the highly unlikely event I complete Alert before the Grecian kit is launched. Grecian looks an easier step up than diving straight into Speedy/Flirt. Thanks for another excellent prototype build log James. I’m missing not having one of yours on Alert!
- 80 replies
- Grecian
- Vanguard Models
(and 3 more)
The problem at the stern that Thukydides has highlighted is that the bulkheads aft are too low where it joins the stern board and the rough tree rail is then too low. There’s also the problem on my build that the deck area is too high at the stern for the gunports pushing the stern board even higher. I would like the stern ports, are they gunports? To be at least level with the deck, so I’ll need to add a plank lower than the stern board and raise it a bit higher. These are the wedges I’ve added to compensate. Probably could have added more! Also painted the blue area between the gunports. It’s one plank wide except for the new wedges which I’ve needed to estimate.
- 70 replies
- Alert
- Vanguard Models
Hull painted white. Not perfect but as good as I’m going to get it! At the stern I’ve added small wedges to the stern bulwarks to make them a bit higher as per Thukydides’s build log. I’ll come back to this in a moment. Then added the rest of the inner bulwarks, painted red. Seems a pity to cut gun ports into the smooth, flowing lines of Alert’s hull. But needs must. I’ve been dreading this job, but following the other build logs on here I’ve used Glenn UK’s method of taping the ports before cutting them which worked well. The job was much easier than expected. MSW is a fantastic resource! Taped and ready to go. Port side complete. Starboard side underway. Once cut out vertically with a razor saw I used a scalpel for the horizontal cut and filed the edges clean. Gunports complete. Starting to look more like a warship.
- 70 replies
- Alert
- Vanguard Models
I managed a little time ship building recently. Main deck clamped and glued. Inner bulwarks started. Shaped to fit, then painted red and glued. Also painted the step below the tiller platform. annoyingly some of the paint has bled under the tape and instead of waiting for it to dry and scraping off I’ve made the schoolboy error of trying to remove it whilst still wet and it’s spread across the tiller platform. Fingers crossed it will sand out. Concurrently I’ve marked the waterline and added masking tape. I’ve used the Tamiya tape with polythene attached to protect the rest of the hull. First spray of white paint shows up a lot of imperfections. Several layers of white paint, filler and sanding later, still not done. More painting and sanding to do. I’m not after a perfect finish and it’s getting closer.
- 70 replies
- Alert
- Vanguard Models
Gus, I’ve built both Nisha and Saucy Jack, both are lovely kits to build. Nisha is slightly easier due to a less curved hull shape and a little easier to rig as the belaying pins at the foot of Jack’s mast are fiddly - not a great deal in it though. Enjoy!
- 206 replies
- Vanguard Models
- Brixham trawler
Bulkhead ears and stern timbers removed. The etched main deck is fitted and not glued yet. The tiller deck not fitted yet. More sanding of the hull still to do. Second set of six cannons built together with most of the hatches. Inner bulwarks planking next - then time to cut the dreaded gunports! I doubt I’ll have any time in the shipyard over the next fortnight. School holidays so busy with the kids!
- 70 replies
- Alert
- Vanguard Models
Thanks for the warning Thukydides. You’re right, I have thinned the stern post slightly. I’ll make sure not to do so any further.
- 70 replies
- Alert
- Vanguard Models
Thanks Bowline. Pale Moon, great to have you aboard, Alert’s hull is a lovely shape. I strongly recommend this kit, although if you’re a complete beginner to modelling with no skills, like I was very recently, I suggest a Vanguard fishing boat would be a touch easier. The second planking is now complete, it’s reasonably tidy above the waterline, less so below where thankfully it will be covered in paint. Failures all mine, not the kit’s! The next two photos show the port side filled below the waterline and sanded whilst the starboard side has had preliminary sanding but no filling yet. I’ve tried different patterns of planking below the waterline. I struggled to get a garboard plank to fit and plank up from it (port side) so lots of filler required. On the starboard side I added the garboard plank at the end and it worked better for me. Once painted they’ll look largely the same. I think the problem was towards the stern where I had thinned the first planking to the rudder post to create a rabbet, I hadn’t thinned the first planking further forward to accommodate this and the planking bulges a tiny bit. Lots more filling, painting and sanding to do here. Also worth noting that the planking strips vary in colour. I had plenty of darker pear planks to plank the visible upper planking, but wouldn’t have had enough paler pear planks so glad I checked before starting planking. You can see the light and dark planks mixed in below the waterline in the photo below. She is starting to look very nice though. Two of the stern timbers have broken off. But the planking is now sanded in line with these and my next job will be to remove these and the bulkhead ears.
- 70 replies
- Alert
- Vanguard Models
First planking now complete. I reverted back to the travel iron and jig bending tool for the port side so no scorching of the wood this side. Starboard side is filled and sanded a couple of times. Port side pre-sanding and still clinkered in appearance. Both sides now filled and sanded. Very smooth but maybe one more fill and sand as there’s a couple of low points. Stern post fitted and diagonal planking on the aft bulkhead. Top 4mm plank was soaked in hot water for 30 mins and then clamped in place without glue and left to dry overnight. Then glued and filled and sanded once dry. Stopping the front plank short of the stem post was one of those things that I was dreading, but was quite easy with this technique and clamps. Stern planking complete and stern counter fitted. As per other builds I’ve curved this a little to match the side trim that will be added later. The counter was also soaked in hot water and clamped in place whilst it dried to help it adopt the curved shape. Pretty much ready for the second planking I think. Starting to look like Alert!
- 70 replies
- Alert
- Vanguard Models
Hi Jim, Thanks so much for the advice. Believe it or not I have watched this before and use a plank bending jig based on Chuck’s. I don’t do the lining off for tapering - I lack the patience - and taper as per the method in the instructions. Where I’ve strayed further from Chuck’s method this time is first bending on this jig with a travel iron and then using the soldering iron type bending tool to bend the plank around the hull - watching Chuck’s tutorial again I see that I should be able to achieve the shape of plank I need using just the first jig and travel iron. I’ll try that for the port side and it should avoid the scorching too. Chuck makes the bending look so easy, but I find judging where to bend and how much tricky. The pins will come out fine with a scalpel and it’s only the first planking, I don’t mind what it looks like if together with filler and sanding it provides a good base for the second planking. On Alert I have doubled up the fifth bulkhead with additional MDF to enable me to split the first planking into bow and stern sections. On some of Chris’s fishing boats he builds up the middle bulkhead for this purpose, so I’ve copied that method here. Thanks again for the advice, it’s still a big learning curve! Best wishes Dan
- 70 replies
- Alert
- Vanguard Models
A little progress on Alert. Thanks for the advice on further fairing, I think it’s paid off. First I couldn’t resist making some cannons as I haven’t done so in a previous build (not being a standard fitting on a fishing boat). The first six are complete and temporarily aboard Erycina to keep them safe from the children and to stop my son “borrowing” them to play pirates. I’ve also been building some of the hatches and gratings for the deck, but I’ve got a query in to Chris about these, so I’ll update more when he’s had a chance to get back to me. The first planking is complete on the starboard side. It’s not beautiful and there’s some clinker. The main difference I found here over the fishing boats is that the lime strips are 1.5mm thick instead of 1mm which makes them harder to bend and more likely to snap when doing so. I needed to damp the planks and bought a plank bender of the soldering iron type with a bulbous end on it to do so. This worked well but gets very hot and in places has scorched the planks (they’re the dark patches). Fine for the first planking, wouldn’t look good on the second planking above the waterline. Need to find a different solution for that. Because the planking is harder to bend (even testing to see where the heat and damp applied bends should be) I found myself manhandling the hull more with the inevitable consequence that I broke off the forward starboard bulkhead ear and also two of the stern timber frames. The outer timber frame and the bulkhead ear glued back on OK using liberal applications of titebond. They’re all sacrificial so won’t matter longer term and seem to be in the right places at the correct angles. I even bought a keel clamp to hold her better. The benefit of the 1.5mm strips is that the overlap is greater between planks and it should be more forgiving to sand. I’m pretty confident this will sand down to form a nice base for the second planking. She looks better in real life than the photos! Port side next.
- 70 replies
- Alert
- Vanguard Models
Andrew, your build of Nisha is amazing. I’m very envious of your skill in adding all the details and those sails are so realistic. My Nisha looks bare and unfinished in comparison! Been fascinating to follow you building her, thank you.
- 206 replies
- Vanguard Models
- Brixham trawler
Hi Glenn, your Nisha looks superb. Really nice to see one of these fishing boats without sails. Shows off her very clean lines. Look forward to seeing you build Indefatigable.
- 48 replies
- Nisha
- Vanguard Models
(and 3 more)
