Ferrus Manus
Everything posted by Ferrus Manus
  1. Thank you for the suggestion. However, i don't think that would be possible for this particular iteration, as i am only scratchbuilding the castles. Like i previously mentioned, this build is not intended to be anything major. However, i would like to keep getting suggestions, because some of them might be possible even given the circumstances. We have never seen the deck of a nef. That being said, we do know where the deck would have been due to the through timbers, which i will fabricate out of card.
  2. I saw those on someone else's build. I didn't know ancient shipbuilding techniques existed as late as the middle of the 20th century.
  3. I still don't think the whole "framing buildup" will work. I can solve the "too low deck" issue by just plunking cargo on the deck. plus, it would look cool and make the ship look used.
  4. When i end up gluing the supports on the ship, i will use the measurements to make the framing to support the planks.
  5. I know you were typing before i revised my post. Check for results. Thanks for the advice!
  6. Okay, here are some of the supporting timbers for the sterncastle. Half decent? I will likely make the planks with strips of cardboard.
  7. ...And that's the problem with cardboard. I took some thin cardstock, but the scissors i had were not able to make clean cuts. I was going to use that as a framing material. Maybe this project is stupid. How do you cut polystyrene card. Whenever i cut it, it turns out like a mangled mess, every time. Even with a brand new blade. Mine is Evergreen 1/16 inch card. What frustrates me is i can't cut anything right. What the hell do i do??
  8. Ya know, someday, i might buy another copy of this kit and actually go full send on it. Wood decks, wood frames, wood castles, wood everything other than the hull planks.
  9. Mind you, Steven, you're talking about a century later than this vessel. The Holy Ghost is a ship from the late 12th century, not late 13th. 200 years is still 200 years. However, without any concrete evidence available, i will probably find myself keeping the deck mostly intact, plus the additions of ringbolts for the removable planks, a capstan, and a piece for the halyard. I would refer you back to post #3. However, the modifications i believe i could easily do, i will at least attempt. Anyway... This is only a teeny tiny dip into the pool of scratchbuilding. Change of plans with the castles: Both of them will be in the shape of a trapezoid, not a triangle. Also, the supports will be almost, if not completely, vertical. Please do not go away. I thoroughly enjoy you and your suggestions, and it isn't my fault that some of them are simply impossible given my current constraints. I'm in college now, and i don't have the time for a major project, unfortunately. When i truly get around to starting the Senora Fielden, you will truly have the time of your life. I can likely build up the sides of the ship, however, by putting actual supports between the knees, thereby closing up the oar-holes and making their puttying easier.
  10. So the bottom attachment (rope, withy, whatever) would be regularly kept loose enough to allow for sideways motion?
  11. It seems like a rudder would take at least two men to operate: one on the tiller, and one to continually loosen or tighten the bottom (or top?) attachment to allow the rudder to move horizontally.
  12. Can someone explain to me how a steering oar actually steers a vessel, and how it is operated??
  13. So, what do we think these holes in the ship's hull are? Are they oar holes, or are they freeing ports/scuppers? Also, another difference here. Steven elected to put the supports for his castles completely vertical in relation to the deck. I am electing to do something a little different. My supports will not be completely fused to the sides of the hull, but they will follow the outward angle of the hull. Thus, the castles will be slightly wider than the ship itself. This makes sense because the supports would be stronger if they were at least partially up against the hull. Or, i could simply shave down the sides of the supports and have them semi-attached to the hull strakes. The castles of any nef are so lightly built that the overhang wouldn't matter to the seaworthiness of the ship anyway.
  14. I think what i will do is simply leave the bow and stern decorations off (obviously), put putty in the locator slots, and scribe wood grain back into that. Boom. Now we have acceptable (albeit kind of short) stem and stern posts. You know damn well I'll make it exciting. 🤣
  15. Steven, is your San Marco Floating Hearse a nef, a type of Mediterranean cog, or something different?
  16. The forecastle will be entirely freestanding, but the sterncastle will likely have its aft end resting on the top of the sternpost. Either way, both castles will be freestanding on the supports in the hull. It will look something like this: The ship will not look like this in any way. However, you can see how the sterncastle rests up against the sternpost. On my nef, the aft end of the (likely triangular) castle will rest on top of the relatively low sternpost.
  17. I will likely have to keep the mast step, because i don't know how to remove it and keep the deck salvageable. If i can find a way, i could probably get it gone.
  18. "The Spaniard came in sight, with his huge sea-castles heaving upon the weather bow... And up-shadowing high above us with her yawning tiers of guns, took the breath from our sails... And we stayed." -Alfred Lord Tennyson From the Armada to Gibraltar, the Azores to Antwerp, the Spanish Galleon has always been a breathtaking and terrifying sight. With her yawning tiers of guns, she was the absolute pinnacle of an entire class of ship, built on the backs of plundered silver and blood. Tennyson puts it perfectly in his poem. Simply nothing could assail the Sea-Castle, so they stayed. It was not any kind of inadequacy that brought her downfall, but rather the arrogant hubris of her commanders. The ~1000 ton Esmeralda would have taken hundreds of men over two years to build, and would have been one of the largest ships in Europe at the time. However, the model of which only took one man six months. Thank you all for sticking around to see the glorious Esmeralda come to completion. She shall sail the imaginary high seas as a glorious and unassailable sea-fortress, carrying victory to her homeland for Gold, Glory, and God. My next build, the Beowulf, is currently up in the pre-1500 builds. Until next time (right now), fair winds and calm seas.
  19. Just for clarification, I am very well aware that a nef and a longship are two distinctly different designs, and the deck of a longship was likely very different to the deck of a nef. I am well aware that the organic curves and flowing lines that defined longships were likely not present on nefs. However, we have never recovered an intact nef, and they remain by far the most under-researched ship type of the Middle Ages. I am not claiming any form of historical accuracy on this build. I know that this is a departure from the norm for me. However, I am looking for a calm, interesting yet not time intensive "palate cleanser" while i get settled into online college. This vessel should not be seen as true to life or a historically accurate reconstruction, or really anything more than a fun proof of concept. It's kind of like the Mataro Nave in a way: meant to be viewed by church parishioners, not experts. Let the build commence! (Thank you Steven for being willing to help me)
  20. look for it in the pre-1500 kit logs! I look forward to your presence, as i always do. Cheers!
  21. Hey Steven, i'm building what will likely turn into a nef. Just letting you know, because i know you're really into ships from the High Middle Ages. I will likely also need your help.
  22. I also had a really good idea for a major change to the ship, while writing the first post. This ship is to be built for display in a church. So, i could change the ship relatively easily to a more "Christian" design: a Nef. I have always wanted to build a nef, and i also always wanted to considerably modify a plastic kit with card. This provides a challenge that the base kit would not do, and all it would take would be the addition of two relatively identical platforms (castles) at the fore and aft.
