Twokidsnosleep
Members-
Everything posted by Twokidsnosleep
Love it!! been on my list to make one
Ok so here we go starting rigging 😱 Starting with the Standing Rigging, saw that the main mast has these huge dead eyes on its line 8 So off to the garage and the lathe to make some appropriate sized ones Then lacing up the deadeyes and a temporary placement of the line. I muffed the spacing a bit as one of the eyes rotated on me as a I glued in the line.
Indeed They are super easy to use, just need a bit of patience to let them dry. I often paint on Sunday and let it sit for a few days over the work week so I don't f with it Quick tips Place a little blob of oil paint onto a bit of cardboard...it will soak out some of the linseed oil and let paint set faster For say making leather or wood effects an acrylic light tan primer layer down first. You can put clear orange tamiya over that primer too Thin oil burnt umber or sienna and mind your brush strokes direction so they look like grain over top that primer/orange You can wipe some of the oil away to expose the under layers, gives convincing wear So many good videos on it, will post some links later This is my favourite video from Plasmo, awesome guy. He started my desire to use oils. I have this airplane kit and want to duplicate the video. Will is annoying a hell, but has some good tips
Good to take a step back and see the forest for the trees so to speak Quiet Sunday afternoon primed the belaying pins tan and then a thin layer of burnt umber by Aqueilung. I usually use Windsor Newton burnt umber but it is running out so I tried this Abteilung for a slightly different contrast colour as it is lighter. Nice fine pigments and it dries quick so I will get more of them. Oils are nice to work with as you can thin them out well and not clog up details.
This look like an excellent project, keep at it!! I am eyeballs deep modifying the plastic Black Pearl, but you have me contemplating this as my next ship build
- 30 replies
- Flying Dutchman
- OcCre
Pulled the Trigger == Lathe coming
Twokidsnosleep replied to kgstakes's topic in Modeling tools and Workshop Equipment
Two favourite Youtube metal workers Clickspring..he is making the scribe here. Highly recommend wasting some time watching him Blondihacks...a Canadian female and does great projects. She makes brass boilers and such for trains and big stuff too -
Great news!! I am sure it will be absolutely perfect for you, nothing at all wrong with Taig My decision making was ease of ordering, model and speed of availability....ie the Sherline was on sale in Canada and in stock so SOLD! -
Tool Rest Question
The Sherline is the 17” extended one. No steady rest but I am studying that option now you guys have shown it! I found the teak chopstick wanted to wobble and warp on me if I got heavy handed with it. A steady rest might have helped there. Turning the masts was just to remove the moulded fake rope lines on styrene masts. It was tricky and boy was I careful. Cemented brass rod stock inside the masts before any operations…more for strength on the model than for turning. Used the three jaw Chuck and tail stock support as my mandrels would not fit. I was soooo careful tightening and speed control she got a little squeaky and flexed too as I went along Some areas I used the carbide tool, some a needle file and some sandpaper… and combinations off all depending on the flex, taper and access. IMG_5519.mov I keep my tools surgically clean, so as to avoid problems, keep things neat and tidy and extend their useful working lives you can get a plastic cover for the sherline toggle switches off of Amazon to stop metal or wood dropping into them -
Tool Rest Question
Oh thanks for posting that video, have not seen it before. Love Paul Budzic videos and is encouraging to see him using a lathe for parts clean up like this We share a profession and he reminds me of some of my former professors; in both good and bad ways smidge condescending I dare say He is an unbelievable modeller and likely dentist too Anyhow, past July was my wedding anniversary (32) and I called in an IOU; she had said I could buy a shop equipment tool It ordered a Sherline lathe. I love it and have been trying to incorporate it into many areas of hobby and home repair The first project was a complicated one to justify to my wife precisely why I needed a lathe From there I made a brass/aluminum scriber tool Then an aluminum push button replacement for a mini clamp Then some Teak wood chop sticks….still a WIP And for the Black Pearl build I plug cut and lathe shaped/smoothed deadeyes Also for the Black Pearl I removed some mouldings on the masts with the lathe and then wound “ropes of scale” rope on them The lathe is an absolute luxury item and I am so fortunate to be able to get one. It needs a better designated home in my workshop(s) so I can access it easier and quicker. Always learning curves to conquer with new equipment and machining metal is a steep but not impossible task to get decent at. my .02 cents ’ -
I have knocked off on lamp and bent both the others🙄 Off they come before I damage the entire wire. I will add new lights and wire them and make better attachment points Rigging the last lines on the canons, one side of the out haul tackle lines done Threaded 0.5mm brown lines were challenging.I need to do some clean up and flat everything
