DocRob
Everything posted by DocRob
  1. Thank you Alan, I like to follow good build logs a lot, as they helped me multiple times with my own builds. I always try to remember, what would have been my questions or points of interest, when I write down my progress and let some emotions flow in, as it´s a hobby and meant to be fun, which is not always the case unlikely. None the least, I write logs for myself as well, as I have very diverted interests in modeling and try a lot of different techniques through my builds. When I try to replicate a technique earlier used, I have the older logs and gather information and can even improve those techniques. Cheers Rob
  2. Despite some progress, today was kickback time. In the morning it dawned to me, that I haven´t seen the round clear acetate instrument glazings for a while and after a very long search it was confirmed, they were gone . After that, I installed various bits and pieces around the handlebar. Among them the very prominent finely engraved and polished large head nut, which seems to pre-tension the fork suspension. When I wanted to glue it in place, I saw a tiny dot of CA, which was left by my fingerprint. Back to polishing, but guess what, the part flew away, never to be seen again . I heard it hit somewhere in my shelf and searched for more than two hours without finding it, browsing through all the tools and boxes there. I´m pretty frustrated now and will reach out to MFH, to ask for spares to purchase and drown my bad mood with some Manhattan´s Anyhow, that´s how the Crocker looks now. Cheers Rob
  3. Thank you both, it is indeed a stunning bike. Me not being a great admirer of American two wheeled heavy metal, have to say, the Crocker is a pure beauty, something like the essence of American bike design of it´s time. @Egilman, I will try to find my white background later or do some outdoor pics in later stages of the build. Cheers Rob
  4. Some major steps got done, as I married the ready assembled fork with the rest of the bike. Alignment of the various parts connecting the fork struts was a bit fiddly, as you had to join a dozen tiny pegs into their holes, while adding CA glue all at the same time. The electric wires for the horn and headlight should be wrapped around tiny bolts, which I couldn´t do. I drilled three millimeter holes into said bolts and glued the wires in, after threading them through. The headlight got polished, as is the reflector for a nice and bright appearance. Cheers Rob
  5. I added more of the crockeristics, beginning with the stands. There is one for the rear end and a side stand, which are both movable. I will see, If the side stand will hold the bike, when ready, as it feels pretty heavy now. It is also becoming difficult to handle, with all those parts added. For the stands, 1,4 diameter mm screws were used. I drilled 1,2 mm holes into the white metal and used a 1,5 mm drill bit to drill a cone into the opening. With a good fitting screw driver, it´s now possible to screw direct into the relatively soft metal. The tank, with it´s various fittings was added. The fuel tank caps were made from chrome plated white metal, which didn´t look too good, having marks in the surface, so I polished them. The shifting lever got it´s counterpart below the tank connected with a shifting rod. The mid section with the instruments is only added loosely as a guide for now. Next is some plumbing, connecting all the fuel lines and other wiring, before I will turn to the front fork. Cheers Rob
  6. Thank you Ken, the white metal is absolutely not brittle. It´s soft and good to work with. The chain is a combination of white metal rods and PE chain links, which are "bolted" in a jig. The nature of the miniature size of the involved parts make it so fragile and you can only hope that nothing breaks after assembling. Luckily, there is a lug casted onto the rear wheel hub, hindering the wheel to spin. That could easily destroy the chain during handling. I´m happy now this is behind me and the build continues to be what it should a fun experience. Cheers Rob
  7. The chain haunted me again, when I fitted the polished sprocket housing. This part connects three principal areas of the bike and only the slightest bending or misalignment leads to not fitting exactly, where it belongs. To correct this, I pried the chain loose from the sprocket and cut away some more links to enhance the wiggle room for the cover and glued it in place finally, hiding the missing chain links. Next were the exhausts parts, which were also polished before. For this, I used the green side of a sponge first, followed by very fine steel wool and finally a cotton rotating tool on my Proxxon with Autosol polishing paste. The fitting was very good and a relief after the chain. Finally, I added some more wires leading from the chain guard to the fuel tank, the braking wire with it´s delicate to install return spring and last, the starter with it´s real rubber pads. Here is another shot, with the fuel tank loosely added: Cheers Rob
  8. That´s why I added the Falcon resin chain set to my RC166 kit, Craig. If I can avoid single link bike chains, I will do so. Cheers Rob
  9. Thank you Craig, but this phase of the build was really nerve wrecking. When the chain breaks somewhere, there is no easy fix to that, as it´s already bolted. The chain itself is relatively fragile and I was overly lucky, when I had it mounted without further breakage. Cheers Rob
  10. There is hope finally. I liked the setting a lot, Chris and would have liked to add it into my Sphinx´s cabin. BTW: you mentioned a fat lady, I wouldn´t be in the least offended if there was a Duchess of Kingston, who mustn´t be fat at all in 1/64 . Cheers Rob
  11. I finished the chain, which almost finished me beforehand . It was a challenge and test of patience and I would wish a resin chain for future MFH bike kits. Building the four strings of chain into the jig proved to be not a big problem, but connecting these strings proved very difficult. In the process of trying, I broke the chain on another place, true nightmare, because it was already flat bolted by that time. After a lot of trying and careful sanding, I glued the link together with CA. After that, I somehow assembled the full length of the chain miraculously, I didn´t had it in me to join the chain without a jig and glued it to the sprocket, as it´s not supposed to turn in any case. The good news, the chain link count in the manual is exactly correct, a thing rarely seen with tank tracks in kits. The side of the fenders look terribly on the pics, but that must be the lighting. Cheers Rob
  12. Today, I assembled more than half of the chain. Again the design by MFH helps a lot, but the work is eye straining and tedious. The last links felt more difficult, a clear sign of fatigue. Thirty chain white metal chain axles, connected by a cast sprue will be set into a pre drilled jig. Then you add the intersecting PE links, which are luckily only adhesive fixed to the foil and dosen´t need to be cut from the PE fret. When one side is finished, the heads of the bolts are pressed flat with a pair of pliers. One side done: The chain will be flipped over in the jig and the second side gets mounted like the first. Here are both sides done. Then you cut the white metal sprue away with a sharp nipper and you have 30links made. The last pic shows two sets of 30 joined together in the jig. Cheers Rob
  13. On to the wheels, which proved easier to build than thought, luckily. It took two days to assemble them, but the second went together much faster, which keeps me hopeful for the five wire wheels of my recently purchased Ferrari kit. Some words of advice, if you plan to build a MHF motorcycle: - Check the rims and the building jig for perfect flatness. In my case, all were warped a bit, due to sanding and polishing the wheels. - Drill the holes for the spokes angled, as shown in the manual and indicated through the cast or you will have difficulties to thread in the spoke nipples. - Don´t use your best nippers for the spokes. The material is VERY hard and left dents even in my hardened tools. First spokes, aligned to the vent hole, one from under and one from above. All spokes need to be bent further and cut short on the bent side. First quarter of spokes is mounted per manual, then the spoke nipples were added from the outside and secured with CA One side finished, I then cut the protruding spoke ends, flipped the part in the jig and on with the second half. MFH chose to print their manual slightly larger than the real thing, unfortunately. One wheel ready, except for shortening the protruding ends. You can see, how the nipples fit into the rim´s holes. The front wheel is done: And the rear wheel followed "short" after , really not too hard to do, but you should work with concentration to prevent from mistakes: Cheers Rob
  14. The Crocker starts to look like a bike now, with the rear fender attached. Primarily, I gave the fenders clear coat a polish with Tamiya´s polishing compounds. A bit of dust and fingerprints remain visible for the moment, as these are work in progress pics. To align all the struts, a positioning peg and a screw for mounting the rear fender was a bit fiddly, but in the end, it worked out. I added the rivets and taillight and started with the wheel hubs. Spoking is next . Cheers Rob
  15. Thank you Craig and Egilman, it confirms, what I started to understand with the clear coat. I began with an approximately 60/40 mix, where the cotton candy effect started and then thinned a bit more and the effect vanished. 60/40 is my go to mixing ratio for lacquers and similar and works perfectly with my usual colors and relatively low pressure setting. More thinner would lead to not enough color coverage and possible color running. Clear seems to be a different breed and I was confused about past results, where I thought, contamination was the problem. Luckily, I try colors on a dummy sprue first, as not all the cotton candy residues vanished with overcoating. Tiny white residues where left, not acceptable for me. Cheers Rob
  16. Gloss coating to me is always adventurous and this time was not different. I used Mr. Color GX-100 clear gloss, which really looks perfect, when everything fits, but can be a nightmare to work with. I had cases in the past, where I had an effect like cotton candy, when spraying the GX-100 and thought, it was, because the clear was contaminated during the process. This time, I picked a new jar of GX-100, opened a new bottle of Mr. Color leveling thinner, poured both liquids directly into the metal cup of my airbrush and stirred with a cleaned metal rod. The airbrush was thoroughly cleaned beforehand. Cotton Candy again on my test sprue. As the whole process was clean and uncontaminated, I added more thinner, step by step and finally, it worked. The mix was not too thick at the beginning, but seemed to be the reason for that strange effect. I would really like to master that stuff on a reliable basis and take the thrill out of this step. Cheers Rob
  17. Thank you Gary, polishing the tank was always the second option, if the two color scheme failed and I doubted a positive outcome from the beginning. I start to like the finish and today, I sealed everything under a layer of gloss coat. When do you have the chance in modeling to let metal look like real metal, no Alclad no Extreme Metals, just the real thing. Cheers Rob
  18. That´s how the Crocker looks with the applied flame contour decals. I added the rear fender loosely to get an idea how everything looks, before I start to clearcoat everything. there is also another option included, which includes decals the front part of the tank to be pre painted gloss black. Looks attractive too, but somehow, I like the polished finish. Cheers Rob
  19. I thought about that too, Craig, but cutting the masks error free, without a cutting plotter would surely exceed my abilities. I always had the fall back plan to do a polished version of the tank with decaled flame contour ornament. The last option, would be a part black, part polished fuel tank. Cheers Rob
  20. I gave the fuel tank another try and oversprayed the white, after sanding away the visible seam, using a different white color. The result was better but not good enough, so I stripped the tank, something I never did before. I always try to have the perfect plan, the appropriate tools, but this time, no luck. There are several decals for the fuel tank included in the kit, so my next try will be a polished finish with next to apply pinstripes in flame shape, similar to the black and white design. I filed and steel wooled the surface, before I polished with Autosol and my Proxxon cotton bit and finally by hand with cotton cloth and again Autosol. Somehow the sheen is hard to capture, it looks near mirror like in reality and the grey ´smear´ on the lower pic is some kind of reflex , no bad spot. Cheers Rob
  21. Hmmh, well, mixed success for today. The decals for this MFH kit are extremely well made. They fit perfectly, are robust and have a good color density. I dreaded the golden pinstripes on the mudguards a bit, but they came out great, applied only with water and a drop of detergent, no decal solutions needed. The parts are still not gloss coated. I´m not happy with the fuel tank. As per manual, I airbrushed it gloss white, masked off the front part, and sprayed the rest gloss black. The finish was almost perfect, but there was a tiny parting line between the colors. After applying the decals, the parting line showed even more, but there is also a different hue to the white sprayed part of the tank. I may strip the tank and use other decals as decor. The flame decals generally lay down beautifully and all the wrinkles on the curved contour could be pushed out while curing, but the result is not satisfactory. I watched the MFH promotion pictures of the kit, and the parting line is visible as well, bummer. Cheers Rob
  22. Lots of prep work done lately. I filed, sanded and near polished fuel tank and mudguards, primed them with Mr. Color grey primer 1200 and sprayed the tank with Tamiya LP-2 gloss white, which came out nice and shiny. Of course, I drilled all the necessary holes beforehand. The rims also needed a lot of preparation. As you can see on the pic, there are prominent cast seams between the spokes, which I cleaned with a sharp blade and then used a rotating tool to refine the surfaces. I decided against polishing and also primed the rims, after I drilled the holes for the spokes. Body color will be black now, where initially thought about dark blue, but I don´t like the look of blue rims. All other parts, which will be painted black, were drilled, prepared and primed. Luckily some help arrived today, more drill bits and two DSPIAE hand drills, the left one with a collet, the right one with a chuck. You can´t have enough of these, as you permanent need to drill holes in different diameters. Cheers Rob
  23. You are right Peter, your release is the only -3 of the pack, it seems, but I guess the sprues are modular, to made fit to all -X with some new parts added. Mine is a shelve queen for the moment, as I have other projects in the pipeline. I added Quickboost resin engines and propellers for mine and also some Reskit Browning MG´s. I´m not sure, if I like the all gloss sea blue proposed for my -5A, so I may have to look for some decals as well. 1/72 is not my favorite scale, so it may take a while until I start, but I like the big Cat and this makes the build mandatory. Cheers Rob
  24. The original kit was issued by Academy in 1993, but got new parts and decals for different versions. To my knowledge, Wolfpack adds new decals and masks with their releas. I have the Revell boxing rooting from the same base kit. Cheers Rob
  25. What a nice kit and display. Like Egilman says, the rotating prop let it look real. Cheers Rob
