Everything posted by DocRob
The AEG got it´s teeth - hmmh, well - besides the painted on jaws I mean. The LMG 17/17 Parabellum are from Gaspatch, airbrushed satin black and then I rubbed on steel pigments with a cotton swab. Stock and grip are painted with oil colors and after seeing the pictures, I decided to put on some varnish for a more realistic look. The kit guns are not bad and I used one inside the fuselage, but detail of the Gaspatch ones is absolutely fantastic. Positioning of the guns is not final. I also made some touch ups and detail painting and added the artificial horizon. Gun mounts and other details got sprayed aluminum, then covered with hairspray with the dark sea blue on top and finally weathered with a toothpick. Cheers Rob
Thank you Gentlemen, the AEG has the widest wingspan I built until now. I am not so much interested in four engine planes so much, as I don´t enjoy repetitive work so much. I always had a soft spot for Lozenge camo, with the colorful fighters it adds a beautiful contrast. With the big bat not so much, but somehow it looks special. Photographing is another hobby of mine, but I still find it difficult to take proper modeling photos. My lightbox helps a lot and I normally use my 45 mm macro lens, which equals to 90 mm with a full format sensor camera. This allows distortion free pictures, which I take free hand, because I´m too lazy to use a tripod. Light metering and white balance is done before capturing and that´s it. I don´t like post processing and try to do as little as possible, mostly none. Sometimes, I make some experiments with different lighting or focus stacking, because I feel, I could do better. Cheers Rob
The big bat flexes it´s wings. Today, I finished rigging the wings and I´m happy to have that behind me. It was not overly difficult on the outer wings, but fiddly with lots of scissors and tweezers involved, always adjusting the light and try not to knock off or scratch parts. I loosely attached the rudder, but not the elevators. The tail will be last, as until now, it´s easy to set the plane onto some foam, bottom up. With about 60 cm of wingspan the bat starts to handle a bit awkward and it´s relatively heave, luckily quite robust. It´s hard to see on the pics, but the white rudder has spar markings visible. I used 1mm masking tape over the spars, when I sprayed the tinted varnished over the whole airframe. Cheers Rob
AMC DH9 by davec - FINISHED - Wingnut Wings - 1/32
DocRob replied to davec's topic in Non-ship/categorised builds
The lobster is coming together nicely, Dave. I like the vivid scheme and good to see, that the decals worked well. With persistent decals, you can use a hairdryer as well as the usual softening solutions. You asked about masking in an older post. It can be a real pain, specially with these WWI planes. I use whatever comes to mind, mostly Kabuki tape, but I like liquid mask for the strut connectors. You don´t want to have any color there. for the strut holes in the wings and fuselage, I use parts of toothpicks or styrene rod, glued in temporally with a tiny bit of diluted white glue. Damp kitchen paper is heavily underrated, as it can be pushed in tiny crevices and around complicated contours, like engines and it stays in place. Cheers Rob -
De nada, Dave. The 0,5 mm drill bit does not only take care of the burr, it leaves a little bit conical opening of the tubes hole, which helps, fiddling the fishing line in. I try to prepare everything as good as possible for rigging, which relates to the hardware, like the right line, de burred tubes, good CA, ... and also the sequence to do the job as easy as possible. Rigging is complicated enough, get stuck somewhere due to poor preparation is a nightmare. Cheers Rob
One side done . I finished the rigging with pulling all lines taught and add a drop of CA to the anchor points to secure everything. This part of rigging was much easier, than the nacelles and inner rigging. I had to fabricate new turnbuckle tubes, which is not the most exciting work, but now, I have enough for side number two. Cheers Rob
Today, I pre rigged one wing in about four hours, not too bad. First, I fitted all the lines to the eyelets, like shown above for the entire lower wing. Then I added the struts, where the inner ones had eyelets in their connecting stubs, which were also pre fitted with fishing line. With a pulling test, I made sure, all connections were ok. This is a step, where you want to make proper preparations, as mounting on the second side, the upper wing is more difficult, due to space limitations. I also made sure, that all the struts fit completely into the wing holes. In the next step, I pushed the lower wing onto it´s connecting tab, but still without glue and carefully slid the upper wing onto it´s tab, without breaking the struts. When everything aligned correctly, I glued the wings and upper strut connections in place. Luckily the fit is very good. Then I turned the AEG onto it´s upper wing and made the same loop and tubes like before with the upper wing eyelets. This is, where I am now. The fishing line isn´t pulled taut and CA secured for now, as this will be done in one flush, to maintain taut lines in the correct positions throughout. Cheers Rob
Ok, there was a lot of talk about tubes, loops, eyelets, ... through the last steps of the build, so I thought, it might be helpful to explain my rigging process. I cut my ´turnbuckles´ from aluminum tube with the inner diameter of 0,3 mm, the outer 0,5 mm with a length of about 3mm. I roll a fresh blade over the tube until it splits. You don´t want to run into trouble with burr, later when you try to loop the fishing line through in the middle of a fragile spider web, so I use a 0,5 mm drill bit to remove the burr, holding the tube with a reverse action tweezer. I glued the eyelets into pre drilled holes into the wing, like here around one strut and for the ailerons with CA. I use Gaspatch eyelets for the structural rigging and Bob´s buckles eyelets, which are finer for steering lines. I orientate the eyelets for the easiest possible rigging. Maxima Chameleon fishing line is the weapon of choice, the brownish color looks ok to me and it´s monofilament. Now it gets serious, using one piece of tube onto the line and pass it through the eyelet. With tweezers, I pick up the end of the thread and bend it back to the tube and fiddle it through the tube for a second pass. Finally, I apply a drop of CA to near to the eyelet and push the tube onto it, holding the fishing line into it´s designated direction and cut the protruding rest with a scissor. Cheers Rob
Got the center section rigging done. It was not easy to fiddle everything in place with different tweezers, using magnifiers, backlight and a lot of care not to break anything. Now I have to stretch my back and help myself to a nice stiff cocktail. After testing the stability of the center section, I decided, I could take a peek with the outer wings inserted. She´s a big bat. Somehow the wings disturb the view onto the more interesting middle section, but I will build her with complete wings anyway. Cut away outer wings is scheduled for my Felixstowe maintenance build. Cheers Rob
For the wings, I will use Maxima Chameleon fishing line with a diameter of 0,12mm. This is perfect for my ´buckles´ made from brass or aluminum tube with an inner diameter of 0,3 mm and an outer diameter of 0,5 mm. The fishing line is threaded through the tiny tube, then through the eyelet, glued to the plane, and finally looped through the tube again. The second pass can be fiddly and you need to be sure, there is no burr in the tubes hole. The good thing, it´s almost self securing after pulled taut. I add a tiny dot of CA to be sure and cut off the rest of the fishing line. I used to buy the tubes ready cut from Bob´s Buckles, but make them myself now, rolling the tube material on a rubber mat under a sharp blade and nott too much force. Cuts the tube without burr. Cheers Rob
German WWI biplane rigging is relatively straight forward, even these twin engine bombers, compared to RAF planes with flat rigging and mostly a lot more rigging lines. I have a WNW FE.2b in stash as well as a Copper State Model Caudron G.3. These giving me the creeps with their spider web rigging. With the AEG, it´s all about planning the sequence, when it comes to when to add the eyelets, struts and actual rigging. Cheers Rob
Believe me, it isn´t wefalck. I build the Duchess of Kingston as my first serious attempt in wooden ship modelling and tackled the build in three month, including hull, detailing, mast and yards. Well, what´s amiss, right - rigging. I got nightmares doing it halfway right only for the bowsprit and postponed the build for now. I think, rigging the mid part of the plane with the nacelles with elastic thread was a good decision. The thread is easier to handle and is easy to tauten. For the outer wings, I will use fishing line, which gives some strength to the construction. Cheers Rob
Today, I managed a very dreaded step in the build, finishing the mid section of the upper wing. Before, I added rigging wires from the nacelles through the cabane struts and later to be fixed under the upper wing, therefore they are not taught. WNW tells you to install the cabane struts first, reaching diagonally from the fuselage, which makes perfect sense, but then let you put the inner struts from the top of the fuselage to the gas tank in the middle of the upper wing to be glued into it´s wing fitting and then last into the fuselage. I didn´t like that second part like shown here in the manual and preferred to have all strut gluing to make on the upper wing, which worked good. Alignment was not easy, but now all looks more or less straight. Cheers Rob
Thank you Greg, it´s a great kit and is a generally straight forward build, with the exception of decaling, which takes time and the area around the nacelles, with rigging, many struts and not so much space to wiggle, but there is no need to wait until retirement. I even thought about buying another AEG, but this time the early version. Cheers Rob
Today, I reached one important milestone with the huge bat. After painting the internal MG, I installed it into the fuselage, because this area will be harder to reach, when the wings are on. Then, I installed the nacelle struts, which received eyelets before for the nacelles rigging. Before adding the engine nacelles itself, I finished the rigging between the fuselage and the struts, a hard to reach area, after the engines are in place. I used Infini elastic rigging thread and tiny aluminum tubes for the rigging and tried successfully not to break the struts while rigging. Lastly, I added the engine nacelles itself and the radiator and engine steering axles. It was a nerve wrecking task and not all went completely satisfactory. The starbord engine isn´t perfectly upright, but there was no way to correct it without a lot of fuss. Cheers Rob
There is a lot of hot air travelling through the engine compartment via tubes and turbos. I´ve never been a friend of turbo charged engines and their characteristics, but yours look fine to me. They are a nightmare to build, like I found with my Tamiya 1/12 F1 Renault lately. This and the exhausts were the worst parts of the build. It seems you are on a good way with your Ferrari. Thanks for reminding me on pink primer, I will soon test that. Cheers Rob
Muchas gracias señhores, oil colors are indeed perfect for leather replication with their good coverage, easy blending and brushstroke free application. My love for oil colors in modelling started only four years ago with the replication of wood, another area, where oil colors are perfectly suitable. I use different thinners for different finishes, like in this case the matte thinner. Everything started with my Hansa Brandenburg build, where I tried to get a grip on wood reproduction. For the same build, I first discovered the oils capability for looking like aged leather: Later, I used oil colors more and more and don´t even use pre fabricated washes and panel liners any more, as oil colors render the same with a much better ability to control the result. I even decided to make an experiment and paint a whole airplane kit with brush and oil colors. The Polish PZL was perfect for the job with it´s single color camouflage and corrugated wings, where the oils added some depth. The oil colors proved very versatile in breaking off the monotone olive surface. Cheers Rob
The beast got teeth, literally I mean. After installing the bomb racks, I added the bomb load. Again, I used CA to glue the parts in place, which I prefer with painted parts. There is less risk of damaging the paint and applied with a tooth pick, it´s a very fine method. I will add some holding belts later, which I will make from fine Kabuki strips. The tailskid fits into a massive part inside the fuselage, but lasts only on a tiny plastic peg on the rear end. As this was damaged while handling the AEG, I replaced it with a 1mm brass rod for some extra strength. The fuselage window was very dirty from the inside, possibly due to lacquer fumes, but I could reach the inside from above and clean the panes. I removed the masks from the cockpit openings and painted the paddings with oil colors and matte medium thinner. I used a dark brown base color, which I darkened for crevices and shadows with dark blue and lightened with some vanilla yellow for highlighting. I really like oil colors for replicating leather, you get great coverage, easy modulation and about the right shine. Cheers Rob
Today, I added some multi color sponge ´chipping´ onto the non lozenged areas. I considered brown Flory clay wash, but decided against, as there are not many panel lines or similar on the fuselage for the wash to lock in. Then the bat got wheels - Does it make it a Batmobile? The undercarriage is very robust luckily and I added the first rigging through the beforehand glued in eyebolts. I used Infini flexible thread here, which was great to work with, elastic and therefore easy to tauten, but stiff enough to fiddle through the aluminum tubes, even for the second time. On with the wheels, wich are luckily included in two versions, weighted and normal. I chose the weighted ones for the heavy bird. Hard to imagine landing this huge bat on an improved airfield with only four wheels the size of my mountainbike´s. Cheers Rob
Great work on the Sea King, James. The interior looks absolutely fantastic and I hope you can see a lot through the canopy and doors. Well PE, love it or hate it. I like to work with PE, but like the others have mentioned, only where it truly enhances the plastic parts. It´s a learning curve with complicated PE assembles and good to have the appropriate tools, like bending pliers and tweezers and last but not least a trusty CA glue or solder experiences. Cheers Rob
