DocRob
Everything posted by DocRob
  1. Muchas Gracias, Gary, Craig, alan and shipman. The RC166 is one of the best engineered plastic kits, I ever build. You feel the love, Tamiya put into the model. It is really easy to get a decent result with that kit and the added detail kits helped as well. I had so much fun, building the Honda, I almost regret it´s over. @shipman, that must have been a very special moment. I guess, capturing the sound on video doesn´t live up to the original entirely. It is absolutely fascinating, how Honda build so much technology in such a small frame and the result was perfect and even looks great. Cheers Rob
  2. The speedy little Honda was a fast project indeed. It took me only two weeks to accomplish and leaves me with a "is it really done ?" expression. The fairing was the most problematic part of the build. I sprayed it with AK´s Extreme Metal flat aluminum and when I added some mild Tamiya decal fluid, I got a bad paint surface. The fairing needed respraying and then, I glossed over the flat aluminum with Alclad aqua gloss, after my Mr. Color GX100 clear wasn´t working. Not for the first time, it produced a candy cotton effect, equal, which mixing ratio I took. When it works, GX100 is perfect, but often it doesn´t for me and I don´t know why. Then I applied the decals which were generally nice to work with. They contoured well with Tamiya Mark Fit Strong fluid applied on top, using a hairdryer as well. For some reason, the 1 of the #16 deformed a tiny bit with the Mark Fit, but I corrected this with a marker. The numerous tiny metal rivets were applied, using a flat cut toothpick with low tack double sided adhesive tape. Before, the molded rivets were cut away with a sharp blade and after marking the center with a steel needle, I drilled 0,5 mm holes. Cheers Rob
  3. That engine looks beautifully detailed. For my 1/24 Fujimi Ferrari 250 GTO, I have a set, made by USCP, addressing the most visible shortcomings of the engine, the air funnels and ignition wiring with 3D printed parts, but your set is even better. USCP also produces exhausts for the 250 GTO, which are nicely detailed. I don´t know, if they are correct for your kit as well. Cheers Rob
  4. That was fast Craig and looks top shelf as well. I guess, decaling took about half the time. Cheers Rob
  5. Thank you Dan, but it is, at least sound wise, mine is not high pitch dentist drill screaming like the real thing . Cheers Rob
  6. Yesterday, I airbrushed the fairing, gas tank and rear. For the parts, I used Tamiya´s LP bright red with Mr. Color pink primer as a base. Today, I started decaling, which worked well. The Tamiya decals were easy to use and the carrier film is nearly invisible. The tiny rivets on the seat proved to be difficult to apply. I used a flat cut toothpick with low tack double sided adhesive tape, which helped a bit Cheers Rob
  7. Thank you Alan, it is indeed a very beautiful kit, well engineered and designed. You can feel that there was a lot of love going into it. Cheers Rob
  8. Thank you shipman, I used to be a halfway decent landscape and available light photographer, back in analogue times. I stopped photographing for years, as my favorite film, Agfa black and white slide film vanished and fell into a deep early digital hole, not liking what the cameras were able to deliver, since some years ago. I never got back full throttle on photography anymore, but still like the hobby, but less obsessed than in my early years. Since years, I try to take good pictures of my builds, but find it very difficult. Lighting, depth of field, color rendition and of course macroing isn´t easy, at least to me and I´m a bit lazy to improve my skills. Cheers Rob
  9. Thank you Craig and Alan, I had to use, what little time I had with the sun. There are still the hanging doors to fix, an area, I worked on for numerous hours during the build, but had no success. Anyway, I´m mostly happy how the big Cobra Coupe came out and that I pulled through. Cheers Rob
  10. De nada Craig, it helped a lot on some of my projects, mainly the carbon fiber decals on my McLaren MP 4/6 and on numerous Wingnut Wings WW1 planes, which got plastered in decals, like the huge AEG G.IV. Your decal job looks fantastic, all snuggled down nicely. You chose the best looking livery out of the four available. Cheers Rob
  11. The sun is shining for a change, so out with the Honda and my camera. Cheers Rob
  12. Thank you Craig, the build is nearly too fast to enjoy, I´m not even two weeks in and can see the finish line. I´ve studied the manual and made a plan, how to approach with other builds in this short time . Cheers Rob
  13. There was a little sunshine outside and I decided to add some natural light pics of the Cobra Coupe. Cheers Rob
  14. Looks great, Craig. I´d like to see some outdoor photos. I´m actually waiting for some better weather myself, to take some outdoor shots with the Honda and Cobra Coupe. No luck so far, it rains and rains. Have I mentioned that spring is the worst time of the year on the islands of eternal spring . Cheers Rob
  15. The Honda starts to look like a bike, slowly. I completed the front section, adding adding brakes, fender and front wheel, The tyre was aged a bit, using Flory grey clay wash, to accentuate the profile and branding. I added the cockpit, which only has only one dial, guess what, a rev counter. I also attached most of the tubing, but there might be changes for better fit under the fairing. BTW. fairing and tank were airbrushed in alu-silver and bright red. Cheers Rob
  16. No encouragements from me unfortunately, David, as I still struggle with the rigging of my Dok. Your work looks great to my eye and I may get the push from viewing your beautiful rigging and seriously start mine. Cheers Rob
  17. Very nice, like shipman, I love the Lightning, an elegant brute, specially in natural metal, which you reproduced very realistic. Cheers Rob
  18. Thank you, the good with Tamiya kits, it´s relatively easy to shine, building them, the bad, if you fail to achieve a good result, its only yourself to blame Cheers Rob
  19. Thank you shipman, agreed about the steering damper, the fit is a bit loose and I will fix it as soon, as I finish the front section. For now, it´s a tiny push with the finger to get it right temporarily. Cheers Rob
  20. Lots of sub assemblies got finished over the last days. The mighty six in six exhaust was airbrushed in semi matte black (Tamiya LP-5) and added with some fittings, build to the bike. When I glued together the three per side exhausts, I fitted them temporary into the engine block, while the glue was still not fully cured, to have the proper spacings and layout. The fit was perfect again. I even managed to exchange the sides for the exhausts wondering about, how to lay deep into the curves, but found out my mistake in time . Another addition was the front fork, which is a working full metal affair. The area around the handle bars looks a bit wild for now, but that will change soon. Cheers Rob
  21. Thank you Dan, I had bought the Tamiya PE-chainset, but was really happy, when I saw Falcon Model releasing a 3D printed set, which I used. The detail is fantastic and my treatment with panel liner, followed with rubbed on chrome pigment, made it look good. With bike kits, it is all about material appearance, specially with metals. They have to look right with their individual colors and sheens in these larger scales. Cheers Rob
  22. Thank you Craig, the liquid mask worked really well, holding the spokes in place, but easily movable. I chose the thickest, I had, Mr. Masking Sol Neo. Tamiya recommended using their craft glue, which is in fact white glue, to keep the spokes where they should be. I feared visible residues and therefore came up with the idea of using liquid mask. For adding the spoke nipples, I started with very sharp tweezers, but found, the method recommended in the manual was even better. I used some double sided adhesive tape on the flat backside of a toothpick, to pick the spoke nipples pushed them carefully into their holes and wiggled at the spoke with tweezers, until the spoke nipple slid in. Other than you, I had eight spoke nipples and some spokes left in the end. Cheers Rob
  23. What I especially like about bike kits are the different metal finishes, you need to let it look realistic. Here, I used aluminum, titanium a mix from jet exhaust and copper and chrome, all from the AK Extreme Metal range. Chrome got a undercoat of gloss black, the others were sprayed directly onto the plastic. I was lazy, avoiding masking and sprayed the 3D printed chain in aluminum complete with the chain sprockets. The chain should look like steel and was therefore treated wit a heavy dose of black panel liner, followed by Uschi chrome pigments, which I rubbed in. The tyres received a treatment with a grey Flory wash, to enhance the detail and let them look a little less plastic like. The fit and engineering is still fantastic and putting together the kit is pure joy. Cheers Rob
  24. Your Lysander came out beautiful, Andrew. The matte finish looks perfect. I don´t know, why I always have to think about "The Adventures of Tintin", besides the secret stuff in France, when I see a Lysander. Can´t wait for your Gannet, as I have on in my stash as well. Cheers Rob
