Doreltomin
Everything posted by Doreltomin
  1. Excellent workmanship, Isalbert! Victory isn't a quite easy subject because the ship still exists and there are a lot of known details which you have to follow closely. Also, the scale you have chosen is very demanding, but your craftmanship is certainly up to that! Keep on the good work and thank you for the photos!
  2. Hello, I just wonder if this computer-aided design of a period wooden ship isn't plain misleading. Don't misunderstand me, I also work as a professional architect, busy all the day long with my 3D models, but I remember the old days of the hand drawing and I have seen how this 3D models and uncanny precision of the CAD can modify your thinking. I mean, there may be too much precision which for practical reasons wouldn't be necessary for a wooden ship, where some 1-2 cm of adjustment and deviation from the standard dimensions would have been quite normal. Then, there is something else which annoys me from a long time ago and I am not yet sure how it was on a real ships.What do I mean: I know all period plans of these ships show the vertical sides of a gunport to be a true vertical, while the "horizontals" are parallel with the respective gundeck. Is it like that on their period plans because it is plainly easier to draw or was it also true in reality? Each gundeck lid would have been custom-built and then fixed to place, a tedious and time consuming process. For the real ship I believe it would have been easier to do it otherwise. I mean, on the shipyard there must have been a logical development of the things. First, the frames were erected and put to place. Then, the external wooden skin was put to place, then the gundeck beams were fixed inside and the gundeck put over. Then, I believe for practical reasons it would have been easier for them to make a wooden jig of exactly the needed size for the gunport aperture including two "legs' to align it do the deck at the needed height, mark the place and then cut the gunport along the marks. If it was needed, the true vertical of the frame was adjusted away to make room for the gunport aperture. This way the "horizontals" would be paralel with the deck, the "verticals" of the gunports wouldn't be true verticals anymore, however the gunport lids would have been at 90 degrees each, easy to build, easy to adjust and easy to switch from one gunport to another if needed. What do you think?
  3. Hi Tony, just take a look at the picture above. You will notice the ship actually has three masts: two "normals" as for a brig and then there's a third, a thinner one. It looks as if a normal "ship" with a mizzen mast put VERY close of the main mast. That was called a snow, a kind of rig which gradually dissapeared, being transformed into the two-masted rig called "brig"
