ddp
Everything posted by ddp
  1. Brad, if you can, post a 3d image of Copper Cliffs before you print it if you are going print?
  2. it is 4 files at about 6mb, will send it to you via email like i did with the Bonnie.
  3. Brad, are you certain the prop shaft housing in the hull flares out that much going towards the bow?
  4. no problem. i'm using Revell's 1/429 scale USS Arizona as a base to kitbash all the old battleships from the Wyoming class to the Colorado class. a work in progress. http://www.shipmodels.info/mws_forum/viewtopic.php?f=59&t=165105
  5. i got some bad news for you. 1. the bilge keels are to far up the side of the torpedo blisters. look at the top picture of this link http://www.researcheratlarge.com/Ships/BB39/BOGP/RG19_ALPHA_Arizona_BB39_09.jpg 2. the 14" turret faces do not overhang the barbett but set back a bit. look at the 1st & 2nd pictures. 3. the main gun port openings do not have flat bottoms especially the center opening. look at 3rd picture
  6. so what is the status of the model since i sent you the drawings?
