ddp
Everything posted by ddp
  1. also the hull plating on that model is overscaled & to symmetrical to be used on a ship. i wonder if they did a Nagato model mistake incorporating the Excel graph lines into the cad file?
  2. how many arresting wires come with the pe kit? here is a cropped picture of the flight deck with the red showing the arresting cable locations, the blue for the locations of the arresting cable pulleys & deck edge tabs the pulleys partly sit on then the green for some of the riser locations. would not be Enterprise's sisters as both CV-5 Yorktown & CV-8 Hornet were sunk in 1942 & the Hellcats came out in 43 so he must of been on one of the Essex class carriers that started entering service in 1943.
  3. you have them in the wrong spot as should be on the lines with the 3 short dashes as per Sheet 6 Flight Deck drawing. as your friend was flying a F4F then he was on an escort carrier not a light or fleet carrier as they used hellcats & corsairs.
  4. not your fault the model & pe instructions appear to be crappy. there is a saying, "if in doubt, ask" before you make a mistake & we'll see if we can get the answer(s) so that you can continue building. those line are crash barriers not arresting cables from midships elevator to alongside the island as i just checked the Booklet of General Plans of the Enterprise, 1944/45 Saratoga & 1946 Bunker Hill as the other plans of the fleet carriers i have are angle decks from 1955 to 1968. your arresting cables stop before the midships elevator. you have windows photo viewer as is part of windows which is what i use.
  5. are you using windows, mac os or linux? see if that pe is a bit longer then the dashes on the flight deck where the risers are supposed to be.
  6. i use windows photo viewer to view plans/photos with no problem so what are you using? there would be 3 risers for each arresting gear cable with 1 in the middle & 1 near each end of the cable. the riser would look like a somewhat flatten upside down "U".
  7. did you look at sheet 6 flight deck of the plans i linked before as your wires are in the wrong places? do you see what looks like little dashes parallel to the centerline as there is supposed to be wire risers that the arresting cable lay on so that the cables are just above the flight deck to help the plane's hook catch the cable to stop the plane when landing.
  8. did you read the plans like you said you would once you got back from your trip?
  9. i would leave applying the decals til last til at least all the large parts are glued onto the hull, putting done, most painting & touchups done plus less likely messing up the installed decals with model handling.
  10. take a look at this. "In talking with Keith Bender (look for a build review of this model from Keith in early '24!) he noted that the rudders are molded too far apart. To quote Keith, "In reality, the rudders are 20' apart and the shafts are 26.26' feet apart. The manufacturer has molded the rudders 25 scale feet apart, and the shafts 32.66 scale feet apart". Keith followed up that statement by saying "I'm leaving them as is, because most people won't know or notice the difference". " http://www.modelwarships.com/reviews/ships/ddg/ddg-54/ILoveKitCurtisWilbur/ILK62007.htm
  11. that "window" between the middle elevator & the deck edge is the "torpedo" elevator to bring the torpedoes from the torpedo workshop on the main deck upto the flight deck. is in the plans i uploaded on page 2 & the link on the same page.
  12. by cutting along the top of the bulges where it joins the hull then pushing the bulges tops thru that hull slice to narrow the top(ledge) of the bulges. there is video(s) on the net about that. depending on the thickness of the plastic that forms the bulges & how much the tops(ledge) has to be narrowed to the proper width, i would shave/scrape/sand the sides of the bulges near the top of them to the proper width. but that is me as that is what i do. BB-35 USS Texas Booklet of General Plans (1944) https://archive.org/details/bb35bogp1944v4/mode/2up
  13. just to let you know on Trumpeter 1:350 USS Texas kit that the top of the torpedo bulges are too wide.
  14. Chris, the true scale is 1/429 as per this link. http://www.shipmodels.info/mws_forum/viewtopic.php?f=84&t=286900 i'm using that same model 17 times to build all the USN OBB's during ww2 from the Wyoming class to Colorado class in this link. http://www.shipmodels.info/mws_forum/viewtopic.php?f=59&t=165105
  15. why do you have a B-25 Mitchell bomber in the drawer when the Enterprise never carried them?
  16. i think it was tamyia putty that i have used before & appears to work for me alright but i don't use it that much as can be seen in my link above. are all the different levels of the superstructure glued together?
  17. suggestion, i would cleanup the seams so that you don't see them & remove the knubs when you cut the parts off the sprues before you get any further. in this link http://www.shipmodels.info/mws_forum/viewtopic.php?f=59&t=165105 you don't see the seams & it is a still a work in process.
  18. Ted, did you download the Yorktown plans from the link i provided earlier? about 1/3 of the armor belt is above the water to the top of the boot topping & about 2/3 below the waterline just past the bottom of the boot topping. just looked at my 1940 Yorktown drawings & the the top of the armor belt reaches to the floor of the 4th deck with the bottom of the armor belt 6' below the waterline with the waterline at 24' 4.5" from the bottom of the ship.
  19. are you talking about the flight deck number "6" at either end of the flight deck? do you see any white in these pictures? https://www.navsource.org/archives/02/020695.jpg https://www.navsource.org/archives/02/020695a.jpg https://www.navsource.org/archives/02/06a.htm
  20. take all the .50 cal guns off as not there after July 1942 according to that link i posted above.
  21. paddle officer would be on the side of the flight deck not at the actual end of it. look at Sheet 6 Flight Deck of the plans i linked before for you to download so you have them to look at to see if what you are doing is right or wrong. until Oct 1943, a quad 1.1" aa gun was mounted in that forward gun tub. http://www.cv6.org/ship/armament.htm what are those guns on either side of that gun tub at the bow?
  22. what gun/s is going into the bow mounted gun tub besides the director in front of it? is that .50cal machine guns or 20mm aa guns mounted on the focsle deck on either side of that gun tub?
  23. now you see why i tried to get you to correct that area. what time period are you doing the model in?
  24. Ted, the catapult machinery enclosure hangs down below the flight deck framework to that U shaped platform on those 2 rectangular posts. you have to extend the sides of Trumpeter's enclosure to that platform by using sheet plastic. look at the 1st drawing that i orange circled the enclosure. the cutouts were put there in mid 1943 for 2 platforms containing 2x20mm aa guns each. https://www.navsource.org/archives/02/020695.jpg https://www.navsource.org/archives/02/06a.htm this is what i am talking about after going thru your pictures.
