Bryan Woods
Everything posted by Bryan Woods
  1. Thanks Trevor, I not the best at research. Scratch building probably isn’t going to be my thing unless someone is telling me what to do:-) If I can just do something simple using one boom on the starboard side to utilize my winch I built. Of course I’ll probably be inventing it with a mind of this century and with very little knowledge of what I’m trying to to accomplish:-) I’ve got to scale the mast, I think it to tall. I’m hoping this arrangement.is going to be workable.
  2. Thanks Trevor, I thought it should be scaled down quite a bit. Pictures and information on a small boat in the late 1940’s are pretty hard to find, especially when I don’t know enough to know what to look for:-)
  3. Thanks for responding guys, Yeah I knew it was too good to be true:-). Even me with little knowledge could see something was up:-)
  4. I’ve been trying to stay focused on the weathering. Since I have no knowledge I’ve been dependent on AI. It’s told me the colors and the recipes to mix them. Also the brush type and stroke. Most of them I also have ask what they are and how to do them. I hope it’s getting it’s info from a good source:-) It always says to set back at arms length, and if you can’t tell you did anything then you’ve done good. I kinda like to see things happen:-) While I’m waiting for more motivation in that area I turned to the deck. AI gave me some good ideas on constructing a winch. Here’s a before and after the salt streaks and waterline grime. Here’s the winch that I’ve just started. The last phone update makes my work light to bright for the camera. Here’s a shot I took for AI to show me the rigging. This is what it came up with. When I had questions on the things I didn’t understand I tried another view That just made me start wondering:-) When I first got started, before I had the engine house on I asked about the rigging for a shrimp boat. Bottom line, it give me answers and maybe if they are wrong some of you will speak up and steer me right:-) I need to add, it’s an enjoyable build that I can’t see the end yet:-)
  5. I’ve got the base coat on. After taking these photos I see I need to adjust the waterline on the starboard side a little. The wheel house hasn’t been glued on. I need to do quite a bit more work on it. Now the weathering needs to start. I’ve decided to shoot for a post war boat located in the North Sea.
  6. I got the wales and keel installed. I painted a thin coat of white on the hull, while I was thinking of how I needed to go about starting to weather this boat. I thought I would just see how much AI could help…… Here’s what it said it should look like:-) Here’s the deck. AI is so smart! It can even figure the water line on your boat even when you float it vertically:-) It’s really got my expectations high.
  7. I got the hull sanded. The thin planks prevented me from sanding it all the way smooth. Since my original idea was to look weathered, I’m not going to use any wood filler. Hopefully no holes will appear. I worked on a toe board just to add some detail. This build is turning out to be more of a scratch build than a kit build. I’ve used all the material except for the pilot’s cabin. I have to purchase some wood to cover the bow. No top rail even shown. I’m trying to bend a piece to fit, the results are unknown. Here’s my jig I’m bending with. Here’s some shots of the up to date hull. The kit came with a 3D printed rudder but I’m not sure it fits this hull. Since I have no knowledge of these things. It makes the build much slower than if I had a plan to do as it says. Now another question. The rudder. I’m hoping one of these types exists on a boat like this. comments and advice are extremely welcome:-) thank you!
  8. As planking continued, I realized I should have been paying closer attention to the stern and not just the bow. I started tapering both ends and made a simple jig to edge bend the fragile planks. Clamping wasn’t even an option. I glued about 4 bulkheads at a time while applying heat. It went as easy as using CA. I’m down to just one space to fill. It’s 3mm wide. I’m going to fit two small strips in so it doesn’t edge up on me so bad. Next I’ll sand it down a bit, put the false keel on. I’m thinking I’m going to put a toe board around the inside.
  9. Last week I had a major distraction and I when to the Fischkutter to try to keep my mind off of it. Well, days later I was looking it over and saw my mind wasn’t on Fischkutter. I cut two planks off at the stern where I had clamped the plank on the deadwood too far up. In the YouTube video they don’t plank the deadwood so the last few bulkheads just right angles with the spine. I would have glued some wood on these if I noticed it earlier before I faired the hull. This still left a sunken spot. I just filled it the best I could with a splitter and called it unique:-) I’m down to just 4 planks on either side. They aren’t being as cooperative as the first. I’ve been using PVA and after shaping them to fit the hull. I just been mainly using rubber bands while it sets up. The last two planks I could only glue 2-4 bulkheads at a time without raising an edge of the plank. Above is the area of repair. Here where I’m at.
  10. It looks like the Gretel had a safe voyage to Alabama.
  11. I call this the Mossy Shipyard. It’s a 12’ x 16’ salt box pole barn. The right side is my wife’s scrapbook area, if I haven’t got is so messy she can’t sit down.
  12. I think you have done an outstanding job! I bet not very many first builds with double planking ever make it this far. I tried one on my fifth build. And ended up putting it back on the shelf for a year before I attempted the second planking.
  13. You would maybe have to make another plank:-) When I was doing the pram , I did as you are doing. .
  14. No arm bending needed here:-) That’s what I’m going to do. Thanks so much for the advice!
  15. Besides working on the planking I laid the planks on the deck. I decided to use a smaller width than what was provided with the kit. That’s some of it on the right. I’m about halfway completed on the planking. The way I chose to plank , it can’t be the best way. But it only uses second grade math. Of course, it’s not done yet. I just measure the longest bulkhead and divide it by 4, (my plank width ). Take that number, that I round to whole and divide it into the measurement of the first bulkhead at the bow. And that’s what I cut the taper at the bow end. I’ve ended the taper starting. #5 but the last few I went to #6. At the bottom, about the third plank, ( when it went past the first bulkhead and landed on the bow stem) I started tapering them also. It’s probably just this hull but it has stayed pretty consistent. There will be 4 or 5 planks with both ends pointy.
  16. The Gretel is all strapped in and bolted down for her 5 hour drive to her new home.
  17. I’ve only been modeling for about two years. I’ve tried lots of way to bend the wood. My go to tool is a ladies hair straightener I bought at a thrift store for $3.00. I just mist both sides and run it through. Then clamp it to the hull making sure it where I want it , then let it set for a bit. This is one I’m working on now. I’ve gotten better at pulling up the plank as I pull it through, to get the bend as close as possible.
  18. You’re doing a good job. I would cut the gain when it was flat. Trying to think back when I did the pram, I probably didn’t cut them. Probably just put a bevel on them, thinking if I cut I would probably cut part of it off:-)
  19. I got the oval shape cut from the wood board I purchased. Glued two wooden pedestals on it, but wasn’t quite sure the wood glue was enough. I flipped it over and drillled from the bottom. Then inserted some brass rods. I’m going to stick some felt over them to cover the holes. Well that brings this build to a close. The Saturday after Thanksgiving I’ll be taking it halfway to its destination in Auburn, Alabama. My nephew is putting it in his office. Whether he likes it or not, that’s him and his family sailing:-) Thanks for all the views, likes and comments.
  20. Good morning, I find mine by searching under members using my name. Then choose content, and then choose topics.
  21. Thanks Jacques, It’s 8 1/2” long. And yeah the close bulkheads are nice. The planks are going on easy but because they are so thin there will be little room for error. I can already see through them before sandpaper even hits them.
  22. The planking has begun. On my last build I glued the false keel on before I faired the hull. Resulting with sanded down areas of the keel. Which may it harder to fit a pedestal on it. This time I left it off. I built up the bow to give a little more gluing surface. With just these four planks on it may look like I know what I’m doing. But now the guess work begins. I’m going to try to do a little math but that doesn’t mean I’ll listen to it.
