madtatt
Everything posted by madtatt
  1. Thank you very much, Yves. I would be very happy to read your construction report on the Mikasa here. Continue with additional small details. The next picture shows why I add large parts like gun barrels as late as possible. I would like to implement this device with which the anchor was lowered into the water. To do this I first have to remove material from the fuselage. Then all profiles are checked again and some are sanded down a little further The torpedo tube opening also has a riveted ring. On to preshading. And then tape it off. I’m doing this relatively precisely, even though I’m only in the basic color. Of course I could spray the red without masking it off, but then too many layers would overlap afterwards and the whole thing would be too thick for me. And now the antifouling paint is on the underwater hull. The waterline is running great. Profiles attached at the correct height. Here are the two recesses for the side with the double anchor. I really like the structure I made from the styrene profiles. And the preshading also comes into its own. Now we continue with the details on the upper ship.
  2. Thank you Yves. Then let us make more details in the inner values of the ship. I’m going about this a little differently than usual. For me, the cannon barrels are attached to the model much later and the deck has to be closed early. There are two reasons for this. The special feature of the Mikasa is its casemates with the protruding gun barrels. They get in the way and you quickly get stuck with them as you continue building. In general, I always attach large pieces very late. I will also raise the hull to the next level earlier than usual. It’s about the upper row of casemates. If you glue this fuselage part later, which is actually logical and intended, you can get to the internal structures much better. But you also end up with a very unsightly slot that can no longer be removed. More on that in a moment. First I soldered the shields of the cannons on the bow and stern. Then, since you can’t see anything behind the shields anyway, I simply replaced the cannon body with a small piece of styrene pipe. This was then glued in… …and I’ll simply put the barrel of the cannon through the hole later. The same with the middle casemates, only here it is much less complicated. Now that all the cannons in the hull are installed, I can prepare the deck. First say goodbye to unnecessary details. I got a small electric chisel, it simplifies things a lot. After the grinding orgy, the deck was glued to the bow. And the other two parts. Great, deck ready. Let’s come to the slot mentioned at the beginning. Here you see the culprit. I might still put up with the gap at the yellow arrows. But the one with the green arrow, no, doesn’t work at all. And that’s exactly the problem. What I would then have to mask off on the wooden deck, superstructure and other details if I wanted to fill and paint the gap late was almost impossible. That’s why I’m going to say it in advance. Anyone can do it.
  3. Thank you Mark. I'm very pleased that you think my ship is so good. The model of your Bismarck doesn't have to hide, it looks fantastic. I hope they let us participate in their further construction.
  4. Let’s continue with the basics. A privacy screen must be created so that you cannot see the portholes from one side and the other side. That’s why styrene plates were placed in the middle. At the bow. And at the rear. The whole thing is flexible so I can move the plate back and forth a little. This is how I get the front 3 inch cannons to fit into their openings. After that I need a little individual privacy protection. One for the muzzle openings of the torpedo launchers, yellow arrows. And for four small portholes that are located under the first deck near the green arrows. It’s hard for me to get the plates right here, hence the angles. Good thing I put the Pontos wooden deck on. (Which wasn’t lasered properly and I had to help with my scalpel.) Doesn’t fit at all. I’ll have to work a little with the milling head. But it was actually about creating tubes for the anchor hawse. Now that I knew that, I created half tubes. But they are larger in diameter. Which should be completely sufficient. It’s just a matter of ensuring that no light shines through on the chain. Nice and dark. That’s the way it has to be.
  5. Done with the profiles. At first I wasn’t sure if I liked it because it’s actually shown the wrong way around. Because the plates would have to create a gap and not an elevation. I also sanded down the profiles on the underwater hull a lot Of course also in the places that you can hardly see afterwards. And so I think it’s going to look really good at the end.
  6. Now I created the vertical joints on the bow and sanded everything well. Now I had to paint part of the fuselage to see if I didn’t make a mistake with the profiles. I think you can take it. The casemates were also checked again. Can stay like that.
  7. Hello Jeff. Your construction report and your model are absolutely top class. I think I can learn some tips from them for my Mikasa. Do you want to display the torpedo net open on both sides? Or should the network be displayed on one side? I had already thought about how to display the net rolled up well. I will use tulle for this.
  8. Continue with the profiles. It’s slowly going faster now. But there are still a lot. Now, however, I also have to take add-on parts into account, such as roll keels and propulsion. They will only be attached to the fuselage after all the profiles have been done so that I can sand them properly beforehand.
  9. Fantastic solution Jeff. 👍 I'm also thinking about this little detail as I'm currently studying this picture.
  10. Continue with the seams for the armor plates. This time on the underwater ship. It takes a bit of effort and nerves. They have to be attached very precisely and parallel. But it seems to work: However, I have to move the torpedo tube opening a little at the stern, so I first closed it with styrene.
  11. Ok, let’s fill the holes that I don’t need due to the etched parts sets. Then check with a white primer to make sure everything is sanded smoothly. Of course the fuselage seams were also checked. Then we come to my beloved Styren profiles. I use this to imitate the seams of the armor plates. At that time, riveting was still taking place, not welding. However, you can hardly see the rivets under the paint on the original. So that’s enough for me. The storage areas for the anchors were sanded smooth, as Pontos also fills everything here with brass. Now for a special feast for the eyes. The dinghies from New Zealand have arrived. Thank you again for the Tip, Jeff. Absolute detail madness. I’m blown away. 🤩
  12. And so I continued on the port side and completed the areas around the casemates. Consequently, all structures of this type on the fuselage are now being replaced by styrene profiles. As can be seen above. Otherwise it would no longer look consistent. But that’s over for now, I still have to fill and sand the holes first.
  13. So, I have created the removed surface structure with my styrene profiles. It's a little bit wider than the original line, but if it's painted afterwards it should fit.
  14. Exactly LED. This is very helpful, especially at the beginning when you are modeling the surface structure of the hull. I remove some of the foam in the middle so that the ship sits neatly inside. Prevents one or two scratches, especially at the beginning.
  15. Thank you very much for the advance praise, Yves. Continue working on the hull, which will probably take quite some time. Because after I filled the recesses with styrene profiles, I noticed significant sinkholes that unfortunately had to be thickly filled. On the right side, I think you can still clearly see the small dent of the sink under the filler. Since I had to do a lot of filing and sanding here, I could no longer take the surface structure of the hull into account and removed it. Which isn’t a big deal since I’ll be making them again with styrene. After the first sanding process, the worked areas were primed as a check and I am quite happy with the result. To the next round…
  16. Lets start. First the basics, with glue the fuselage together. Next, drilled holes for the stand nuts. Neatly glued in with two components resin. Just like the internal structures to stiffen the torso. This time I treated myself to the elegant stands from Pontos. Look really great. Then the first lower deck comes into the hull. Now it is really very stable. Next, the holes for the crampons. Nice straight through the drilling templates from Pontos. And the usual drilling out of the portholes. After researching the few images available, I noticed that the porthole that sits on the model below the anchor hawse did not exist. Herby63 discovered this too. This was then closed with a round styrene profile. Filled and sanded. Another mistake that needs to be corrected. Merit made recesses in the fuselage to accommodate the etched piece gunports from the model in the correct location. Since I’m using the pontos set here and the hinges of the gunport on the original ship were riveted onto the hull from the outside, I close them with styrene. I’ll be busy with that for a while.
  17. Thank you for the great comments. That makes me very proud. 😊
  18. Ahoi, Freunde der Klebezunft. Zurück zu meinen Wurzeln, dem Bau von Modellschiffen. Es war ein schöner Ausflug in das Star-Wars-Universum und ich hatte viel Spaß. Aber jetzt freue ich mich auf ein echtes Schiff, das ich schon lange in der Pipeline habe. Das Schlachtschiff Mikasa aus der Zeit vor dem Dreadnought der Kaiserlich Japanischen Marine (IJN). Ich weiß, für die meisten nichts Neues. Es gibt so viele Bauberichte über dieses Boot und dennoch bleibt es für mich ein Muss. Und das aus zwei Gründen. Da ist zunächst die Form des Rumpfes. Wirklich archaisch. Erinnert mich aufgrund des angedeuteten Widders an eine griechische Triere. Mir gefällt es unglaublich gut. Und an Deck ist auf diesem Schiff alles so anders als zum Beispiel auf meiner Bismarck. Zweitens habe ich für dieses Modell nicht nur ein Pontos Detail Up Set. Nein, als Bonus gibt es auch das MK1 Deluxe Paket von KA Models. Bei Pontos fehlen einige Details. Wahrscheinlich nicht gründlich genug recherchiert, oder was?! Aber dazu später mehr. Nun ja, schon in der ersten Kabine wird es eine ätzende Orgie geben. Was für ein Spaß. Dann möchte ich Ihnen das verfügbare Material für dieses Projekt vorstellen. Zunächst einmal das Modell. Dies ist von einer Reihe von Herstellern wie I Love Kit, Wave Corporation oder HobbyBoss erhältlich. Aber alles ist definitiv Trumpeter, was man sofort sieht, wenn man die Box öffnet. Schließlich kommt mein Mikasa von Merit International. Es ist erstaunlich, unter wie vielen Namen dieses Modell verkauft wird. Auf dem Bild ist die Box der Firma I Love Kit zu sehen, da ich meine nicht mehr habe. Natürlich gibt es auch mein liebstes Ätzteileset von Pontos. Und jetzt übertreibe ich, ich weiß, aber dieses Modell wird auch mit dem MK1 Deluxe-Paket von Ka Models geliefert. Was mich dazu motiviert hat, erkläre ich später in meinem Baubericht. Leider gibt es von Veteran Models zu diesem Modell nicht viel, aber immerhin das: Diesmal stammen die Figuren von der Firma ION, die ich passenderweise als Preis für meine Bismarck gewonnen habe. Für mich ist es immer noch unverständlich, dass die Hersteller, egal ob Modellbau oder teure Nachrüstprodukte, Ankerketten mit Doppelsteggliedern anbieten. Also machten sie sich Sorgen. Kommen wir zu einem weiteren exquisiten Accessoire, das ich erst durch den erstklassigen Baubericht von Jeff59 entdeckt habe. Diese fantastischen Schlauchboote von Micro Master aus Neuseeland. Ein kleiner Traum. Das ist also die erste Zutatenliste für mein neues Projekt. Wobei ich nicht ausschließen kann oder will, dass das ein oder andere Teilchen dabei sein könnte. Auf die nächsten zwei Jahre voller Spaß.
  19. And now the final photos of my falcon. Don’t be surprised by the bolder colors, as this time I used my new cell phone, which has an excellent Leica camera. So that’s it, a good year of fun in the Star Wars universe. Now I’m looking forward to my next project with a real ship. Of course again in this theater.
  20. Good morning dear model building friends. Last night the last clear coat was applied after a year and two months. It’s done, my falcon can finally take off. The plate had to be placed on its back one last time to be able to do the details at the top. But this time carefully supported on a foam. Then off to the airbrush cabin. So as far as this huge structure goes. All parts finished painted. And one last picture of the finished record without her falcon. So, that concludes my construction report. I’ll take some decent pictures of the model this weekend and then present them to you. It was a great pleasure for me to embark on this journey with you into a galaxy far, far away.
  21. What a fantastic work. 🤩 I'll take a lot from your build report when I start my Mikasa.
  22. Ahoy dear model building community. I feel very honored by this comment. The dress rehearsal took place today. The falcon was screwed onto its threaded rod one last time for testing. I did some light chipping and fading on the base plate and am now checking to see if anything is missing anywhere. Take a look at the bird. The front laser looks in exactly the right direction for me. The height and angle of the falcon looks good. Of course, it is unnecessary to paint any further details in the middle. There is still a little aging missing on the lower plate, front edge. Sides look good too. And the upper laser also shoots in the general direction of the falcon. Also a few little things that I will improve. I expect my model to be completed next weekend.
  23. Many thanks. The back has two filters and very slight chipping. I don’t even know if I still do dirt running. But now the last segments have been added to the front. The upper laser… And the one on the big truncated pyramid. The cover for the falcon holder is also designed. All parts are now installed. And again in total.
