Everything posted by madtatt
Let’s continue unspectacularly. We’re still missing skylights, handwheels, and a winch on the main deck at the stern. First, another small collection in my printed organizer. Nothing complicated, so straight to the result. The deck continues to fill, both front and back. The small stuff on deck is now roughly completed. I would like to show you this wonderfully detailed skylight a la Pontos again in a close-up. That’s what sets these kits apart. Molded plastic can’t replicate that.
- 104 replies
- Russo-Japanese War
- Mikasa
Yes, Jeff, you need this Yamato from "Glow2B." It's fantastic. Compared to that, the "Nichimo" model is complete rubbish. The two of us will then build two glorious, giant monster ship models from it. 😁
I completely agree with you, Jeff. This model is turning out to be a mysterious adventure. But with a high level of entertainment value. Yes, the anchor chains really look great. If you need them, I'd be happy to send you the link to where I got them. I also installed them on my Bismarck. And I hope you'll be finished with your work shed soon and we can marvel at your latest construction again. 💪
- 104 replies
- Mikasa
Today we’ll continue without much ado. I had time over the long weekend to finish the anchor section. That was fiddly.😵💫 In this area, the Pontos set was used exclusively. KA failed to score points here. Of course, double-link chains had to be purchased again. It’s disappointing that two very expensive aftermarket kits like KA and Pontos don’t consider it necessary to include proper chains. 👎
- 104 replies
- Mikasa
Just another small update that I had to do before moving further toward the bow. I was still missing the bollards and other small items that would go directly in front of the bridge houses. These are now also attached to the deck. This had to be done so that I could install the companionways that lead to the main deck. This means the inner area is almost complete. And so the bridgehouse was glued in front of the steam pinnaces towards the stern. Otherwise, it would have been difficult to install the companionways behind the pinnaces. Now I can start with the anchor area at the bow and have cut everything I need out of the boards.
- 104 replies
- Mikasa
After a short break, I’m continuing. The lower bridge houses are finished weathering and can be put on the deck for a test run. Now I have to think about the most logical way to proceed. I think the rear bridge house is not glued to the deck yet. Because directly behind it the steam pinasses come onto their cradles. It’s probably better to have a little more room for my fat fingers. For the armored control center, I lined the entrance with a profile. It was clearly too thin. And there isn’t much space in front of the bridge houses up to the tower. So I’ve already fitted the lower parts of the tower into their barbettes and made them move freely. They were practically impossible to move. And I’ve also prepared the lower ladders that belong on the mast.
- 104 replies
- Mikasa
Hello Jeff. Yes, the information about this ship is truly sparse and often contradictory. So, thank you very much for the wealth of information you've given me. 👍 I'll proceed as follows. I won't be doing the cable reel and drainpipes, as I can't see them in the photos that show them painted gray. So I'm going to finish the bridge houses now, just like you saw them in my picture above. I'm excited to see how it goes.
- 104 replies
- Mikasa
Another little mini-update to round off the weekend. The only thing missing were the support poles for the awning, and then the base coat could be applied. The protruding details such as profiles, davits and the like are accentuated again with a light grey. In combination with the preshading, this creates a fine first contrast Now I can start aging next week.
- 104 replies
- Mikasa
Now that the lower part of the masts is firmly anchored to the deck, I can turn my attention back to the bridgehouses. First, I soldered more attachment points for the rigging. It simply holds best. As mentioned in the previous post, I noticed two dark squares. I believe these can only be the gratings of the accommodation ladder. Since I'll be showing my ship at full speed, as usual, they'll have to be stowed there as well on this model. But that won't happen until after I've attached the bridgehouses to the deck. What I'm already doing is attaching the corresponding davits. I've identified them in the following pictures. Rear bridgehouse.... And the implementation by me. And at the front. Strangely, my image editing program didn’t allow a green arrow. So a white arrow points to the davit. Note that the davits point to the right and left. Great, I love searching for details like Sherlock and then adding them. 🔎
- 104 replies
- Mikasa
Hi Jeff, it's me again. I discovered something else interesting about the pretty good and well-known picture of the Mikasa at the Vickers shipyard shortly before its completion. I enlarged the bridgehouse and discovered the gratings of the accommodation ladder. See green arrows. Since I want to show the ship at full speed, I need them stowed. What I can't find, however, are the drainpipes you added. Is it possible that these were also added to the museum ship later? To prevent tourists from slipping when its rain? 😁
- 104 replies
- Mikasa
Good morning everyone. Another question for Jeff. You left out the small handwheel on the square mushroom structures and changed the height. I also think it's a ventilation duct and not a hatch. You took the height of the ventilation duct from the picture of the museum ship. However, there it's also positioned a bit further forward. And now to my thoughts. I found an original photo where the bridge houses are clearly visible and brightened it up a bit. However, I can't see these structures at all in the photos. Whereas the wheelhouse is quite clearly visible. Could it be that the height of the ventilation ducts on the museum ship was only subsequently changed? Otherwise they must be visible from the front view of the bridge house, like here, again on the museum ship. And another question that occurs to me, Jeff. Where did you get the information that these cable drums were installed on the bridge houses? I've carefully reviewed all my photos of the original ship, but I can't find her on any of them. 🤔
- 104 replies
- Mikasa
Today, it was all about properly securing the masts to the deck. I’m always a little nervous before such important steps. That’s why preparation is key to ensuring everything goes smoothly. That’s how I did this small plate that serves as a support for the stop angle. By placing it on the bridge house, I can quickly check the angle of each side of the mast. This is important because the time window is very small. I use superglue with a long setting time, but it still has to be done quickly. I won’t keep you in suspense, but it worked. I laid some more rope next to it and had a sailor check the ropes. And everything went smoothly at the rear as well. Phew… The deck amidships is slowly filling up. Now I can continue working on the bridge houses.
- 104 replies
- Mikasa
Okay, let’s move on to the masts and pause for a moment with the bridge houses. I noticed the really tight space in which the masts have to be installed. Once the ladders leading from the bridge house to the deck are installed, there’s hardly any room left to properly secure and align the masts. There’s even less space toward the stern. That’s why I decided to attach the lower part of the masts in front of the bridgehouses. It’s nice that the lower mast is then split in two, so it won’t be a problem in terms of height. I also noticed the very limited surface area where the mast connects to the deck. I consider this a problem. Especially since I’d like to take this model to one or two exhibitions. A little more adhesive surface would be helpful. So I decided to make it larger. This was done using an M4 washer. I drilled it out to the appropriate size and reduced its thickness. I then soldered it to the bottom of the mast. Primed… …and painted and placed in the holes on the deck for testing. I quite like this so far. This should significantly increase the strength of the masts on deck and make aligning them at right angles easier.
- 104 replies
- Mikasa
Thank you, Jeff, for the welcome to the delicate, nerve-wracking Mikasa Club. I feel honored to have been accepted. 😅 And thanks for the extremely valuable tips you've given me. I can really use them, especially on the bridge house. Of course, I'll be checking your build report again and again. Which brings us to the masts. I've thought long and hard about the best way to approach this. I've decided to first attach only the lowest part of the masts to the deck. I'm also concerned about the weak attachment of the masts; the adhesive surface is tiny. I'm therefore going to increase the contact surface by soldering a small perforated disc to the bottom of the brass masts. This will increase the adhesive surface and simplify alignment at right angles. We'll get to that in the next construction phase. Probably this weekend. Then let's see if I can get out of this tricky situation, as you describe, without any injuries, Jeff. 😉
- 104 replies
- Mikasa
Hello together. It’s fun to put your own stamp on a model that’s produced in large numbers. However, you should be aware that sometimes things won’t work out as you hoped. That’s what happened with the last construction phase. Cost me a sleepless night, but first things first. A new coat of primer was applied very thinly to check the profile height and build quality. I quite liked it. As I considered how to proceed with the bridgehouse, I encountered a problem. I have to say that building this ship is considerably more challenging than, for example, the Bismarck, with its rather simple, straightforward superstructure. Everything on this old ship of the line is so delicate and intricate that you really have to think carefully about the order in which you assemble the model. The mast is another thing I’m racking my brains over, but that will come later. Now back to the bridgehouse and the culprit that made my life difficult. This one: This is the external connection from the bridge house to the deck above. The supporting structure is once again extremely detailed by Pontos and simply beautiful to behold. The problem is that this outer bracket on the bridge house extends very low and could conflict with my profiles. So, to be on the safe side, I removed parts of it and rearranged them. Believe me, that really bothered me. But I think I solved it quite well. Less is sometimes more. It was a bit frustrating to remove the profiles at this point, but I wanted to play it safe. With such delicate structures, I felt it would be too risky to just keep going, only to find out at the end that it wouldn’t fit together.
- 104 replies
- Mikasa
A first coat of primer to check the profile height. Then I sanded it down further and adjusted it. Now I’m satisfied. The rain deflectors for the portholes are neatly lined up, and the door looks great. Pontos, in fact. The height of the portholes on the front bridgehouse is completely wrong; they are positioned much too low. So, they were filled with styrene round material and re-marked. Drilled and better… The grinding orgy continues. 😅
- 104 replies
- Mikasa
And now we continue with the application of the profiles. I used the same ones on the bridge house as on the hull, only this time I glued them on the short side. I thought they should look narrower on the smaller superstructures. That’s why they were sanded down quite a bit afterward. But today is the end of it for now, the whole thing needs to dry properly overnight before I sand it. Now I can repeat the whole thing at the front bridge house.
- 104 replies
- Mikasa
@Jeff59 Good morning, Jeff. I'm not sure which hatch you're talking about, but I think you mean this one.... You raised it higher and left out the handwheel, as you can clearly see on the museum ship.
- 104 replies
- Mikasa
Once again, the details are sanded down, portholes drilled out, and holes filled in to replace and re-clad everything with beautiful brass. First, the rear bridge house. The gusset plates are too thick for me and will be replaced with 0.25 mm thick styrene. And again on the deck. Now the same with the bridge house on the bow side.
- 104 replies
- Mikasa
Glad I can help, Jeff. I'm still waiting for a response from my friend in Hamburg; he's very busy at the moment. The good thing is, we have plenty of time until you're ready. The ship model itself will keep you busy for a while. 😉
Thank you Jeff, yes I also really like the rivets, even though they are in 1:72 scale they work well. I can report that the symbiosis of Pontos and Ka Models on the Funnel has been a success. It did require a bit of trickery, but I think it looks impressive. Let’s start on the port side. I had to position the rings so that the second ring wouldn’t interfere with the gallery. Therefore, it was important to measure the ring spacing precisely. Next came the task of threading the pipe into the gallery. The lower pipe clamp could only be attached after the pipe had already been installed on the funnel. A serious fiddly job. Additionally, the rings were in the way of the tubes to the right and left of the center. As mentioned in the last post, they needed to be slightly padded. Otherwise, they wouldn’t fit over the rings. It was not intended that the two accessory sets would be mixed together. I did have some initial difficulties, but I think I got the most out of both sets. And the result feels very satisfying.
- 104 replies
- Mikasa
Then I have this for you, Jeff. The Battleship Bismarck War Diary. bs-ktb-oct2018.pdf Maybe that will help a little with the studies.
