flyer
Everything posted by flyer
  1. Hi Paul It’s good to have you and your monstrous yet elegant beauty back online! Keep up the terrific work. Cheers Peter
  2. On Pegasus’ mainmast and foremast I added mast bandings made of paper and battens made of leftover deck planks. Foot of a topmast The mainmast is taking shape The wooldings are protected with simulated wooden hoops made of paper. mast bandings made of cartridge paper The battens added A finished masttop. This and other details are added according the descriptions in James Lees ‘The Masting and Rigging of English Ships of War’. This book costs a bit of money but it is an absolute gem and a great help if your building and rigging manual doesn’t show enough details.
  3. The next step is the assembling of the masts. The first is the most simple – the mizzen. Having no turning lathe I just use a file or a small plane and a drilling machine to form the different parts. On each mast I work from top to bottom. First I file all the square parts and the round parts are made into 8- or 16-sided polygons. Then I put the mast - with some extra length on the lower end - into a simple handheld electrical drilling machine. To form the round parts I use sanding paper of increasingly fine grade with the other hand. Lower end of main topmast Mainmast parts ready to be glued together With this kit there is again the problem that the manufacturer expects you to file a dowel of 6 mm diameter into a 6 mm sided square and I still don’t figure how to do that. (Recent repetition of basic geometry problems with my daughter didn’t help.) So I made the square part of a piece of the next thicker dowel and glued it to the rest. To give some more strength I used a pin to put the parts together. Lower end of main topgallant mast On the fore topmast I tried a different solution: a tenon was filed on the lower end and a suiting hole drilled into the extra part. Gluing the two parts together this way gave more strength. Alternative method on fore topmast The finished mast foot Another solution I saw in this forum is to form a smaller square and glue some planks onto the sides to make up the missing size. In any case this part of the mast will be painted black, which will cover the traces of the working process, the difference in wood colour and the glue. (I will have to figure however, how to make the spare topmast to be placed across the waist with other spars. I think these spare parts there were left in raw wood (maybe oiled to protect them) and only painted when used.)
  4. Hi Frank Some more about furling the sails: For deciding how I would make up my furled sails I was mainly using John Harlands ‘Seamanship in the age of sail’. I tried to follow the method used to furl sails. It’s not a straightforward description and I’m not sure if I read it correctly. But the main steps seem: Pull up the sail with its gear. This would bring the clews to the clewline blocks which are near the slings or about 1/3 of the length of the yard from the mast. Then fold after fold of the sail was brought up its front, the last fold covering all the rest to protect the bulk of the canvas from the weather. The furled sail rested on the front upper side of the yard.The clew would lie over the last fold back down the front side of the yard. Secure the sail with the gaskets. In merchantmen the canvas was probably distributed as equally as possible along the yard. The whole description goes over several pages and sometimes overstrains my English. The illustration is from the same source. And by the way… I really think you underestimate enormously your abilities by using a book called …for dummies’ (Isn’t the most useful in the series perhaps ‘crash tests for dummies’? ) Cheers Peter
  5. The port lids and several small parts, likely to break off, such as hammock cranes, hatchway rails or swivel guns will be put in place after the rigging. And yes, somebody will have to go over the transom with some blue and white paint to refresh the carvings’ colour. Most probably it will have to be me, which is only fair as I obviously didn’t always ‘mind the paintwork’.
  6. The general idea about colour was to use it as sparse as possible. So all the deck furnishing along the centreline was left in wood. As far as I know, they did also use varnish to protect the wood in the 18th century. The gun carriages are also just varnished. With those wooden ones this is fortunately possible and I like it better than red. (One of the comments to my first build log pointed very correctly to the rather ugly narrow sides of all the plywood parts. He was right of course and later I did try to mask them, where still possible, according his suggestion with wood colored paint. On future builds I will do this before assembling and building in.) A lucky shot against the sun rising behind the forecastle
  7. Finally the almost finished hull was fixed on its stand.
  8. Hi Frank Weeeel … my friend, since you asked … The color of the sail looks nice, worn and a bit shabby; I think that’s what you are looking for. The way you fixed the sail to the yard looks fine as well. But… After checking all my clever books I think that the furled sails should look different (at least on a warship, where you have plenty of hands to furl the sails). When furling the sails they took the sides in and up and then rolled it up the front to form a roll, which is thicker towards the middle, with just the two lower corners falling forward over that roll and then all the lines were straightened. It’s a bit difficult to explain as I’m actually sitting in a hotel in Far East and don’t have those clever books with all the correct terms available. I try to show what I mean with a picture of my Granado’s furled sails. I had those sails made by a seamstress with just the vertical seams and the seams around the edge and then sewed a boltrope around the sail. Then the sail was fixed to the yard and then furled and only now the yard was fixed to the mast. The furling went easier with the sail dampened. I am not sure how smooth your sail material actually is but usually it’s still rough-textured. Just use the very finest cotton you can find. I don’t mean to criticize your work - heaven forbid! – I am just giving you my honest thoughts and still think yours is a really outstanding build. Take care Peter
  9. Thank you, Aldo. I’m sure your scratch build oven will look much better than mine. Cheers Peter
  10. Hi Aldo Great build and superb quarter badge! I look forward to your further improvements and regret that it’s too late to include them myself. Thank you for sharing. Take care Peter
  11. Hi Frank Thank you for the very kind remarks. I look forward to how you make the sails. I’m still undecided. On the last boat I asked a professional seamstress to sew them. But her finest seams still look oversized. I might try the method of pulling threads I found in one of the old forums. But this still leaves the seams around the edges… How to mix pictures and text – that’s rather easy on the new forum. You must use the ‘More Reply Options’ option. If you now upload your picture to your unposted reply you see it at the bottom just above ‘Attach Files’. Below the small picture of the file you see 2 possible actions: Add to Post ¦Delete. If you click onto ‘Add to Post’ you create a text-placeholder in the text section where the cursor stands. This placeholder can be moved around like any text block. If you now push the button ‘Preview Post’ or ‘Add Reply’ the post will be displayed with pictures and text mixed. Take care not to scrape yourself on those barnacles! Cheers Peter
  12. Rudder assembly and deck fittings were fixed with the following additions: The chimney of the galley stove is a caldercraft part. And also the binnacle got a caldercraft chimney.
  13. I tried to improve the swivel guns by opening the muzzle with a small drill.
  14. The rudder could be hanged. It was previously coppered and fixed with a spectacle plate made from paper and 2 eyebolts. The channels were pinned and glued and deadeyes and chainplates attached as per instructions.
  15. Now the guns under the quarterdeck were fixed there with the tackles. The Deck was then closed and planked. To simulate the caulking I used a black textile marker to paint the sides of the strips. Now it was time to finish the bulwark inner planking, the capping rail and the headrail and cathead assembly. The last was quite a puzzle and finally I made the complete lower bow rails from the decorative white metal strips filed into size.
  16. Next the quarter badges and the stern with its decorations were fixed. Victory models carvings which are build with photo etched layers of brass are the best I have ever seen in a model kit. For colouring I used the ‘expensive’ gold only sporadic on carvings and the ships name. The side decorations were painted yellow.
  17. Initially I thought that Pegasus’ galley stove was placed under the main deck (similar to Granado) and fixed only a chimney leading up under the forecastle. This was the initial chimney. Unfortunately I found those excellent build logs of that marvellous Kingfisher kit in this forum and had to rethink. So it was back to the yard again. The chimney was pulled out and with help of the pictures of the Kingfisher logs I assembled a much simplified stove from scratch (mostly wood, wire and some leftover copper plates) with the same proportions. It would just fix between the supports for the riding bitts. To be able to put it in place the part just below the chimney was made separate. You really don’t see much of the finished stove, but the little building project was fun. (Looking at it now, I wish I had made it more acute...ok, replacing is impossible because it’s fixed with epoxy, I will make a better one on the next ship.)
  18. While laying the planks on the forecastle I grew more and more irritated by the size of the midship gun ports. Compared to those which will be fixed with port lids they seemed too large (and would have offered only a limited protection to the gun crew behind them). Old layout with the B I G gun ports Quite reluctantly I finally decided to scrap off the already partly fixed decoration, tear off some planking and fix those ports with a frame. Then the side was planked again. Now the ports looked more right to me. They were now also quite similar to those of my caldercraft HMS Granado. (I learned a lot with the Granado kit – except how to make rope coils – and still think it is one of the kits with the best value for money and excellent material and instructions. It lets you build a really beautiful model.) The lower sills of the gun ports and the sweep ports were no longer in line but I find the overall picture more convincing.
  19. Hi Frank Thanks to the grounding of those pages I found your log after the restart and realized I really missed something outstanding in the old forums! I love what you do to that poor hull! But… looking at the pictures, your Supply seems so realistic, it must stink a bit of rotting sea live!? Do you think the admiralty will let you place such a shabby, smelly old boat in the living room? It really looks great and I'm looking excitedly forward to what you will do to the rest of the model. Take care Peter
  20. Thank you Aldo. There is a lot of detail-work ahead also to rebuild the log. But going over it again will perhaps make my learning curve steeper and help me to avoid old mistakes. Cheers Peter
  21. Hi Andy Great to be and have you back again. Good Idea, that fast motion log. It is too bad about all those lost information which came forward during all the detailed discussions. Well, again, John Lennon must have had a presentiment: … it’ll be (just like) starting over… Newfoundland in winter for training sessions… I still like m y company better – although I had some training sessions in Kangerlussuaq, Greenland, but those were only in the simulator and that was standing in Zurich! Take care! Cheers Peter
  22. Next I started to work on the guns and put those under the forecastle into position. All guns are fixed only by their tackles. Thus they keep a certain play or flexibility and I think are less prone to be broken off after they are no longer accessible. (Actually this picture was shot a bit later and of course shows the aft part of the ship.)
  23. The next step after finishing the 2nd planking was the coppering. I did this rather early in order to have unrestricted access to the hull and less risk to break anything. The copper plates were attached slightly overlapping. Following the waterline is a double row of complete plates as top of the coppering. This pattern is according to one found in ‘Ship Modelling from Scratch’ by Edwin B. Leaf. It is rather easily done and in my opinion gives a satisfying result. And those copper plates from Victory Models are a pleasure to work with. (I find I must apologize for the quality of my pictures but when I took them there was no intention to post them.) After coppering the plates were cleaned with a brass brush in a little drilling machine. This was to clean all leftovers of the CA glue and let the copper get a natural patina. By the way – for the colouring of the hull I tried to follow the colour scheme of HMS Bellona.
  24. The opening for the quarter badge does not follow the form of the badge window but is rectangular, similar to a gun port.
  25. As you will know the details of HMS Pegasus’ kit box and the initial build from other postings I start with my log about 1 ½ years ago while I was building the great cabin during the 2nd planking. As the captain of a model ship I try to make my cabin as airy and spacey as possible. This means I had to file and scratch away some wood of the stern structure.
