Everything posted by wefalck
A Lorch Micro-Mill that never was ...
wefalck replied to wefalck's topic in Modeling tools and Workshop Equipment
A radius-turning tool with a vertical axis would be difficult to implement on a watchmakers lathe, as the clearance over the top-slide is only 7 mm ! So you would need to somehow construct a cantilever from which the turning point would be suspended, or the maximum diameter you can work on would be about 10 mm. Not sure anymore, whether this was my own inspiration or whether I saw it somewhere in a picture, but I had the idea to use a boring-head, which has a built-in micrometer dial, to change the radius. I also wanted to be able to turn spherical surfaces for which the centre is not necessarily in the axis of the lathe. Therefore, I built the tool around the quick-change tool-post. Essentially, I built a miniature boring-head and an insert for the QCTP with a horizontal bore, into which the shaft of the boring-tool can be inserted. The design is not perfect. I should have better control of the end-play in the QCTP and started to work on a system of cone-bearings, but did not finish this. For the relatively big jobs presented here it works well enough, but when it comes to turning door-knobs and the likes with 0.5 mm diameter, I need to have a better control on the play in the tool. -
I should perhaps add that I let myself be guided in the desgin of the various bits and pieces by what was practice for these machines. Surprisingly, since the 1880s all manufacturers seem to have followed largely the same designs with only small variations in detail. For new parts I try to imagine how these manufacturers would have made them. However, as I have no possibility to have iron castings made, I have to fabricate parts. -
Thanks for the praise At a matter of fact, it is all in my head. These days I don't even make working drawings Sometimes I make dimensioned sketches for machining, literally on the back of envelopes, in order make sure that what I imagined actually works out. Most of the times things seem to come out as I imagined them. Not alway though Just struggeling with the motor mount now, as my original idea would create a too long lever, when clearing various parts of the mill, with the risk of amplifying vibrations ... have to re-think it. -
Was kind of working holiday: had to work on finishing off the decoration and furnishing of our part-time home in Spain - putting in/up wardrobes, building a mock fire-place (unfotunately, we can't have real one there), etc.; jumping up and down the ladder at around 30°C made me loose some 4 kg in weight - feeling a lot fitter than before the holidays - but have been to the beach only once ... grilling on the beach in the August heat is for German and British tourists only anyway ************************************ The milling spindle will be secured in its place between the two brackets by a lever-actuated excentric bolt that pushes it down. I found a rough excentric bolt in my scrap-box of odd lathe parts, but it would have been as easy to start from scratch. The excentric was worked over holding the bolt in the 3-jaw-chuck with a brass-shim to give the off-set. Rough and ready method for excentric turning The head was turned with the help of the shop-made radius-turning tool (which I originally made to be able to turn miniature door-knobs and the likes). The tool-bit diameter was chosen to match the neck and shoulder of the bolt. The turning operation was followed by smoothing with wet-and-dry paper and steel-wool of various grades. Finally, it was polished with polishing paste. The pictures below show the various steps of this machining process: To be continued ... -
I gather the best source of information on 1:72/1:75 scale (25 mm) figurines (in plastic) is this review site: http://www.plasticsoldierreview.com/. You will have to scan the site for suitable manufacturers and ranges. Information on (white) metal figurines is more disperse and difficult to come by.
" ... I wish there was a simple diagram pointing out all the different materials in a cross section." - Past generations used to make beautiful technical drawings/lithographs, at least for publication purposes, where the different materials were colour-coded. Typically iron/steel was laid out in blue, brass/bronze/copper in yellow, wood in light browns, etc. Having read through the Greek philosphers of old (and various even in the original language) at school and later, I came to the conclusion long ago, that most fundamental thoughts have already been thought some two and a half millenia or so ago - and the thinking may have been much older than the writing. The challenge today is to keep an overview over the available knowledge - or rather to have meta-knowledge, to know where to look up things, when you need them. This in itself can be daunting task in the professional life and a hobby alike.
Excellent job and tutorial. When the boat is to be painted all-over, one can also use other materials than wood for planking. I used, for instance, phenolic resin impragnated paper ('hard paper', Hartpapier in German), as used in the electrical industry. It comes in thicknesses down to 0.2 mm and can be cut with scissors and files with diamond nail- or needle-files. Epoxy or CA are suitable cements. While I have my reservations over CA, a boat I built some 20 years ago with this material still looks like on the day of completion. The advantage of this material is that it has a smooth surface for painting, which may difficult achieve with wood on a clinker-hull, particularly on the inside.
I am not aware that bronze bolts were ever used, but then I am not necessarily an expert on 18th century shipbuilding. Copper was used extensively for smaller fastenings. While mechanically, from the point of of tensile strength the use of (wrought) iron bolts has many advantages, it is problematic in conjunction with certain woods due to their acidity (tannic acid) contents. This makes both, the bolt and the wood rotting. I believe certain oaks were not considered suitable for use in conjunction with iron fastenings. Iron bolts certainly would not be used in places, where they would be exposed to sea water. If the bolts, due to their location would be exposed, they were countesunk and the hole would be plugged with a wooden plug. This can actually look like a tree-nail from the distance, but the plugs would not show end-grain, as they would be cut from a plank (as for the decks) to have the same grain direction as the surrounding wood. Iron-fastenings can also not be exposed to seawater, when the ship has copper-, or Muntz-metal-sheathing, as both are electrochemically more stable and would lead to fast anodic corrosion of the iron bolts.
Now, with the summer holidays behind me, I am back in the fora and in the workshop However, first a little postscript on things that were completed before the vacations: A couple of pictures that show the different components of the y-axis spindle. Also visible on the first picture are the parts of the friction brake for the dial, short piece of acrylic rod that is pressed down on the spindle with a set-screw. Tightening or loosing the screw allows to adjust the friction. The parts of the y-axis spindle Spindle assembled Spindle in its working place To be continued ... -
Thanks for the 'likes' I hope that the project will continue in the not too distant future. I have become distracted by a couple of machine-tool building projects (http://modelshipworld.com/index.php/topic/10278-shop-made-filing-machine/ and http://modelshipworld.com/index.php/topic/13268-a-lorch-micro-mill-that-never-was/) that in turn were prompted by some machining needs for exactly this project. Things may go slow, however, as I will have a heavy professional travelling schedule until the end of the year
Although the original question was about novelty fabrics to be used in very small scales, it may be worthwhile to explore the aid materials for book-binders and restorers. In these trades very fine cloth (and paper) often is used to double up fragile original materials without detracting much from their appearance. I seem to have seen various around the WWW, but did not follow through, as I didn't have any needs. Incidentally, many mid-19th to mid-20th century ship's drawings have been done on drafting linen, particularly when they were meant for reproduction.
"I guess on the whole I'm just surprised that while you can cover a model in PE detail and someone has even come out with a credible 3D 1:350 crew, that someone like ModelExo hasn't come forward with "the thinnest, finest woven fabric on earth" or something to cater to the sail ship hobby. :)" Purely for technical reasons ... you cannot weave scale cloth, neither in 1:100 or let alone in 1:350 scale. The thinnest (usable) natural fibres are the yarns taken off the cocoon of the silk worm and have 0.005 to 0.01 mm in diameter. Indidividual hemp cells have a similar diameter, but would need to be spun into a yarn to be useful. Man-made nanofibres could go down to 0.0001 mm or less in diameter, but still are prohibitively expensive. In any case, the individual fibres need to be spun into yarn, the thickness of which is much greater than that of the fibres. So, I think for the moment we are stuck with the finest silk cloth. However, natural silk should be avoided in modelling, as the protein of the fibre is prone to relatively fast degradation. Realistically, I think that non-woven fibrous materials, i.e. paper-like materials, are the only solution for small-scale sails. Paper can be produced from relatively short individual fibres and does not involve the mechanics of weaving, for which a long yarns are needed. Therefore, paper can be much thinner than the thinnest cloth.
Mid 18th Century glass
wefalck replied to Mark P's topic in Building, Framing, Planking and plating a ships hull and deck
Following the Medieval Revival fashion in Europe from around the 1840s these 'Butzenscheiben', as they are called in German, have been used in 'restoration' and imitation projects. They have become associated with a 'romantic' view of small German towns and the likes, but can be seen in France, the UK, and other places as well. -
I gather the problem with a lot of fancy and novelty materials is that they are (still) prohibitively expensive. They may also not be sold over the counter or in small quantities. The second question would also be for what application fabrics in real life would be used that would be fine enough for modelling purposes. OK there are a lot of uses of materials the average person isn't aware of, or even wouldn't dream of. Still, there are also technical limitations to the weaving of very fine materials, regardless what the thread is made of.
Old wood imitation
wefalck replied to Engelard's topic in Building, Framing, Planking and plating a ships hull and deck
There are a couple of basic questions to ask first: - is the model made from wood or other material, namely plastics ? - if it is made from wood, do you intend to keep the appearance of the real wood it is made from, or do you intend to cover it in opaque paint ? There are various painting guides around the Internet for aged wood, namely in the railway and diorama modellers realms. Some use real wood as a basis and other plastics. In the case of real wood, this is usually stained in some grey, controlling the process to keep perhaps some of the original wood colour. Applying white, black, and burnt umber as washings allows to modulate the basic grey. At some places a technique called 'dry-brushing' may be applied to highlight surface features. On plastics, you would apply similar processes, but you would start from an undercoat of light ochre to simulate the wood. Like the Old Master, in principle all the various aging or weathering effects can be achieved by painting. However, in particular the plastic modeller community has developed a range of processes that involve more or less controlled random processes, such as stripping paint layers with adhesive tape, deliberately reducing the adhesion of paint layers in order to partially strip them later to achieve a flaked impression, etc., etc. Again, there are numerous tutorials on the Web as well as in printed form available. In think I pointed to some of my own work in a similar thread. This is a 'resin' modell with an ochre undercoat and various washes of burnt umber (both acrylics). In addition water/salt 'stains' were applied using white pastel chalk: In the scenic setting of the above model I used real wood for the landing stage etc. that was treated with stains and acrylic washes: I tried to give some keywords to search for in the Internet that give more detail than this short post. -
The blank on its arbor was then transfered to the dividing apparatus on the milling machine for engraving the dial. For this a 15° engraving bit was used. in the same set-up the hole for the friction brake of the dial was pre-drilled. Set-up for engraving the dial Engraving the dial The numbers were stamped in a make-shift set-up in a vice. In order to ensure that the number-stamps were applied exactly radially a purpuse-made guide-block was used. Set-up for stamping the dial Finally, the dial was mounted back on the arbor and the burrs from engraving and stamping cleaned up with a couple of light cuts in the lathe. Cleaning up the engraved and stamped dial The two parts were separated on the lathe with a jewelers saw substituting for a parting tool. The dial then was degreased and the engravings laid out in black enamel paint. After the generously applied paint had dried, the dial was cleaned up with very fine wet-and-dry sanding paper. Painting the dial To be continued ... -
Thanks, Pat. I was actually surprised myself, that it turned out so well -
Per, as it never was, the mill doesn't have a price-tag ... unless you were indeed prepared to pay me at my commercial rates, which means that you would have to trade-in a decent car, may not quite an Aston Martin (but I would gladly exchange it for the mill, BTW) *********************************** For the dial on the y-slide I had a piece of 21 mm diameter brass to hand. This was faced in the 3-jaw-chuck, drilled and reamed for the 5 mm spindle, and then bored out to fit over the spindle bearing-plate. Preparing the blank for the dial The blank was the mounted on an arbor with a 5 mm stem so that I could turn the outside shape. At one end there is the notorious convex knurled ring. For this, a ring of 1.2 mm width and 1 mm height was left standing with edges slightly chamfered. Turning the blank for the dial For the next machining step the knurling tool with the concave knurl was mounted to the cross-slide. The knurling tool was fed slowly into the slowly rotating blank. It catches quite quickly at the edges and the pattern evolves fast. As expected, the processes is both, a cutting as well as a shaping one – the relatively soft being squeezed into the indentations of the knurling wheel. While generously lubricating with WD40 the knurl was fed into the faster rotating blank until the pattern had developed fully. Knurling the dial To be continued ... -
Turning brass thimbles
wefalck replied to jdbondy's topic in Metal Work, Soldering and Metal Fittings
What lathe do you have ? It may be worthwhile to invest into collets, if your lathe spindle has a taper for them, or into a collet chuck. This gives a much better and concentric grip on thin material - and is also safer, because you are not bothered by the jaws and can work closer to the chuck, which eliminates chatter. Of course, the tailstock needs to be checked for alignment. Why do you use a file to make the groove ? A tool in the slide rest would be safer and more efficient - or are you using a wood lathe ? -
Thanks Pat and I hope you have enough Kleenex around ***************************************************************************** After some disruptions due to travelling (spent inter alia a couple of days in Pisa for work ) I tackled a job I had never done before: Digression: making a concave knurling wheel Today, concave knurls to produce the convex knurling seen on many older high-end precision machines are obtainable only at prohibitive costs. Therefore, I embarked on making my own knurl, encouraged by a few examples on the Internet. Knurling wheels normally have to have a certain diameter in order to prevent their bore from being distorted under the stress of the knurling process. I choose a blank of only 10 mm diameter for a bore of 6 mm in order to reduce the mass to be heated, when attempting to harden the knurl with my rather limited heating capabilities. I also had a cut-off from a Schaublin collet-blank available, which I assumed would harden nicely. Hobbing the knurl on the milling machine The proposed process of creating the knurling wheel employs an ordinary threading tap as an improvised hob. This, stricly speaking, would result in a 'rope' knurl, but the helical angle of a, say, 0.4 mm pitch tap is barely perceptible. The easiest way to hold the blank for cutting seemed to hold it in the knurling-holder for the watchmakers lathe that I made a few years ago. This means, however, that the process could not be done on the lathe, because it would have been not so easy to mount the holder on its side. Cutting the knurl on the lathe would have been better, as the end of the tap could have been supported in the tailstock in order to eliminate flexing. Unfortunaly, the DIXI horizontal mill does not have an overarm, which then would make it the ideal machine for the job. So the job was done on the vertical mill. Hobbing process in detail The blank was drilled and reamed for the arbor of the knurling tool holder. Some polishing ensured that it spun freely. A M2 tap was chucked in a collet as short as possible and offered to the blank with its uppermost end in order to keep flexing to a minimum. Initially, the mill was run at slow speed and with a small feed. After each incremental feed, the blank was allowed to make several revolutions until no chips were produced anymore. Once the pattern was created, the mill was run at a somewhat higher speed and the amount of incremental feed increased from around 0.03 mm to 0.05 mm. Every time blank and tap were flooded with WD40 in order to wash out the chips that then were wiped off. A first failed trial showed, how important it is to wash-out chips. The second attempt was successful. The finished concave knurl After the machining, the knurl was hardened by heating it to a cherry-red colour and quenching it in ice-cold water. As I don't have a very strong torch, the knurl was pre-heated to 450°C using the hot-air soldering gun and then brought to temperature with the gas-torch. The knurl was also rubbed in soap to prevent scaling. After some cleaning, the hardened knurl was tempered to a straw-yellow colour using the the hot-air gun. A test with a file showed that the hardening was successful. The knurl in the tool-holder for the watchmakers’ lathe ... well, it actually worked as you will see in the next contribution To be continued ... -
Indeed, the bull's eye-glass (or 'Butzen' in German) has been very common and is used in 'romantic' reconstructions of medieval windows. However, considering that there only two bull's eyes coming out of each cylinder and only one from each disc, there must have been a considerable production of plate glass to give sufficient numbers of them for a window. I guess, from the mid-19th century on, they were not only 'waste' products anymore, but made specifically to meet medieval-revival demands. Also, in Germany the 'Butzen' often are 'bottle-green', indicating that inferior quality raw materials with a lot of metal contaminants were used - so the associated flat glass must have also been green. Here is an image from Wikipedia that shows the production of disc-glass in the 'forest' ('en bois', because they needed the wood for fuel): If I am not mistaken, sometime in the last quarter of the 19th century the float-glass was inventend in France, whereby the the near-liquid glass was poured onto a bassin with mercury. Indeed, France seems to have been technologically ahead in glass production for quite some time. -
Wasn't this blown into a long cylinder, the bottom and top disc (with the blow-pipe attachment) cut off, the cylinder split lengthwise and then rolled flat while still hot ? Cheaper and smaller panes were cut from the discs, which accounts for the streaks often seen in old window panes. -
Making Shackles my way…
wefalck replied to Thanasis's topic in Metal Work, Soldering and Metal Fittings
Actually, I don't mind people adopting ideas - but as you said, it's nasty to take someone elses pictures etc. and then post them at another place without due credit. I have whole pages from my own Web-site being 'mirrored' on Web-sites of certain Eastern European individuals and Russian fora - and they just don't care when you just ask for proper credit to be given. Still, I like to share ideas, tips, information, because somehow it will be repaid by others sharing their ideas, tips, and information ... give and you will be given, as the Romans said.
