Everything posted by wefalck
  1. Lock for the 30,5 cm gun The next thing to be tackled was the lock piece or ‘wedge’. This 'wedge' has a rather complex shape with a flat front, but a round back and various recesses and cut-outs. I decided it would be best to undertake most of the machining operations while it is still attached to some (round) material that can be easily held in a collet. The round back was milled in an upright collet holder on my mill's rotary table after the various coaxial holes had been drilled and the flat sides milled, all in the same set-up. For machining the other recesses the piece had to transferred to the diving head on the mill. Round-milling the lock piece in an upright collet-holder on the rotary table Cutting off the finished lock piece The most time consuming part turned out to be the cover piece for the lock, which in the prototype was fastened by five hexagonal head bolts. It holds the moving and locking screws in their place. It took me four tries before I produced a half-way satisfactory piece. Soldering the microscopic bolts (0.4 mm head diameter) in place got me quite a few grey hairs. Finally a fake locking screw was turned up and the moving screw, which moves the lock in and out, was faked from a couple of drilled-together 0.1 mm copper wires, covered in a thin layer of solder to make them look like steel. Milling square and hexagonal bolts Facing the locking screw in special protective brass collet The large re-enforcement ring for the barrel was also turned up and two holes drilled into it for seating the rack quadrant that forms part of the elevating gear. In fact, I had cheated a bit, when drilling/milling the lock seat: the front of the hole should have been flat, which is difficult to machine; so I continued the elongated hole under the re-enforcement ring, which was made as a separate part and slipped over the barrel. The various parts of the lock were assembled using lacquer and cyanoacrylate glue. The (almost) finished gun barrel with its lock (toothpick for scale) To be continued ...
  2. Thanks, gentlemen, for the encouraging comments ********** Milling the trunnion seats and the lock For drilling holes for the trunnions and milling the seat of the lock the diving head was set up on the slide-rest. I could have done this operation on the milling machine, but on the lathe the dividing head (http://www.maritima-et-mechanika.org/tools/dividinghead/dividinghead.html) is centred automatically. The outer end of the barrel was supported by the arm with an appropriate centre fitted. The resulting shape from the milling operation looks like a keyhole, but something like a mushroom shape with sharp edges is required. This was achieved by hand filing. Set-up showing for milling the seat for the lock Close-up of the milling operation in the dividing head with support Working drawing and files used to finish the lock seat For the next operation the set-up had to be transferred to the mill anyway: milling the seats for the square trunnions. The trunnions merge in a concave curve with the barrel. The trunnions were turned up on the lathe as disk with two round stubs protruding from either end. In the dividing head on the mill the disk was milled square to the size of the seat (or rather the other way round). These parts then were soft-soldered to the barrel. Back on the mill the concave curves of the square part of the trunnion were milled using a miniature ball-head cutter, rotating the barrel in the dividing head. Milling the square part of the trunnions Milling the seat for the trunnions Trying the trunnion Milling the concave transition between trunnion and barrel Aiming a gun in these days was a rather primitive affair, using just simple sights. The sights (two of them on either side of the barrel) consisted essentially of a round bar with a sliding rod to give the elevation. The beads (mounted near the trunnions) were observed through a ring of inverted U-shape on top of the rod. The bar was screwed into a notch in the barrel. Now, drilling into a round at a tangent is nearly impossible without deflection and breaking the drill (0.3 mm!). Therefore, I ground flat a broken drill bit to make a make-shift micro-mill and sunk a start hole. This was finished with an ordinary drill. Milling the seat for the sights Drilling the seats for the sights To be continued ...
  3. Don't know about kits, but like to work with it, because it is (largely) isotropic, i.e. it doesn't matter in which direction you are working. The material is designed to not warp. It sands and glues well, it is also easy to saw. It holds sharp corners. Hardness and compressive strength are slightly different vertical to the board and horizontal, which is due to the manufacturing and partily intentional. The idea is give a relatively hard surface, while keeping it workable. I seem to have heard some warnings against breathing-in the dust of MDF, but I don't actually know what the issue is. I not producing a lot of dust, so it wasn't something I was worried about. As it is is easy to get material in sheets from 1 mm thickness on in shops that cater for architects, I assume it is very popular with them. It can also be cut easily using lasers.
  4. These appear to be artistic representations of a certain Aldo Cherini. He has been very busy, but unfortunately, he does not give any sources for his drawings, so that it is impossible to ascertain their correctness. Some people actually do model pacific boats: http://www.maritima-et-mechanika.org/maritime/models/ellice/ellicecanoe.html http://www.maritima-et-mechanika.org/maritime/models/gilbert/gilbertcanoe.html
  5. And the show goes on ... ************** The gun barrel and lock Turning the barrel Because there will various visible areas of bare metal, the material of the original, that is steel, was chosen. A piece of round bar was faced, centred and rough drilled for the bore. This hole served as a protective counter bore for the tailstock centre during the following turning operations. In order to get a good finish the automatic longitudinal feed for the lathe was set up with the change gears. Unfortunately the minimum feed per revolution on the watchmaking lathe is still too high to get a 'mirror' finish. One day I have to construct some sort of reduction gear. The outer part of the barrel has a slight taper (1 degree included angle) and the top-slide was off-set accordingly for this operation. Facing and centring a piece of steel rod for the gun barrel Rough drilling of the gun barrel Turning the barrel using the automatic fine feed Taper-turning with slide rest off-set For rounding off the ends of the rings the lathe’s hand tool rest came to good use. The work was finished off with fine wet-and-dry paper (remember to cover ways!) and steel wool. The bore was bored to diameter using the slide-rest and a micro-boring tool. I had originally envisaged to also show the rifling, but a quick calculation told me that for a 1 mm bore and 72 rifled fields I would need a tool edge tha is just over 0.04 mm wide ... Rounding the 'rings' using a hand turning rest Boring the barrel using a micro boring tool To be continued ...
  6. Are you trying to achieve a 'realistic' or an 'old museum model' look ? For a realistic look the deck is way too dark and too brown. Real decks are usually quite bright, more like newer wood, due to constant cleaning. They also attain a more greyish hue due to the weathering of the wood. Your deck currently looks more like what you see on old museum models, where the wood has darkened and accumulated some dirt.
  7. @bear, I must say, you rather embarrass me with your praise I gather, a professional mechanic would throw up his hands into the air seeing me doing things, being just a self-taught amateur. Actually, collecting old machine tools and their restoration developed into a hobby of its own: http://www.maritima-et-mechanika.org/tools/toolsmain.html ******** Back to the subject …. Rack-and-pinion drive for training the gun The gun was trained by pinion acting on a circular rack. The pinion was driven from under deck by a sets of gears and a couple of cranks manned by a number of sailors. The chief gunner was able to connect and disconnect the drive with levers from his aiming-stand behind the gun. I set up my hand-shaper (http://www.wefalck.eu/mm/tools/shaper/shapers.html) for cutting the rack teeth, but had to throw away the first two attempts because of the poor material and because - again against better knowledge - I did not lock the traverse slide when cutting. The table was removed from the shaper and the home-made dividing head bolted on instead. For lack of a proper tool grinder (another project now in hand) I hand-ground a cutter for the rack teeth (0.1 mm at the bottom) from a rod of high-speed steel. For holding this tool-bit in the shaper, an old lantern-style tool holder from the watch lathe came very handy. The unwanted parts of the ring were cut away on the shaper using ordinary left and right hand lathe tools. Finally the necessary sections were trimmed off with a fine saw blade on the lathe's sawing table. Hand-shaper set-up for cutting the toothed rack Cutting the toothed rack with a specially ground tool Cutting away the unwanted part of the ring with an ordinary tool Rails and rack provisionally in their place inside the barbette To be continued ...
  8. The 30.5 cm Rk/l22 gun The main armament of the WESPE-Class was a massive 30.5 cm (12”) Krupp breech-loading rifled gun (Ringkanone, abrev. Rk). This caliber stayed the bigges in the German Imperial Navy for many decades and well into the Dreadnought-era. It is this gun that essentailly made the boats in floating batteries, rather than ‘real’ ships. http://www.dreadnoughtproject.org) A few years ago a detailed dtawing of gun-mount originating in the adminralty archives in Berlin surfaced on the site ‘dreadnought’. The arrangements for all the heavy Krupp guns of the time were similar, so that a visit to the Finnish fortress Suomenlinna (http://www.maritima-et-mechanika.org/maritime/models/wespe/suomenlinna/suomenlinna.html) off Helsinki was helpful; here a number of Russian clones of 28 cm coastal Krupp guns are still in place since the time, when Finnland was part of the Russian Empire. 28 cm Krupp-clone coastal guns in the Suomenlinna-fortress off Helsinki Rails for the Lower Carriage The lower carriage of the gun is supported on four races that run on semicirucular cast-iron rails bolted to the deck inside the barbette. These rails need to go into their place in the barbette early during the construction. The same applies to the semi-circular toothed rack that is part of the gun-training machinery. I decided to make the rails from steel, even though ferrous metals in model construction are frowned upon by many. My justifications were that it is difficult to represent cast iron or steel by paint and that there hundreds of models in museums around the world that contain iron. I have used steel in models some twenty years ago and presumably due to the lacquering they shows no signs of rust. Roughing out the rails from a metal disc with the backing of a wooden disc Grooving the races with a specially ground bit Cutting thin disks from round stock of large diameter is a pain I wanted to avoid. Against my better knowledge I picked a suitably sized steel washer as starting material. Unfortunately, the steel used did not machine very well and lot effort was spent to avoid chatter marks while turning and to obtain a reasonably good finish. The various types of wheel collets and chucks available for the watchmaking lathe came into good use for working on inside and outside diameters of these discs. The rails were shaped using a specially ground forming tool. Cutting out the inside of the large ring for the tail-races of the lower carriage, while holding it in a so-called bezel-chuck Trimming the outside of the smaller forward ring holding the material in a so-called wheel-chuck The rails laid out in the barbette To be continued ...
  9. The standard type of equipment was already mentioned. Concerning tooling: If you are planning to mill wood, plastics or aluminium, carbide end-mill with 3 mm or 1/8" shaft come handy. They can be bought at a reasonable price e.g. at electronic bay and come from e.g. the aerospace or circuitboard industry, where they are replaced before they get dull - it is cheaper to replace them before they get dull than to throw away ruined work-pieces. For our purposes they are still good enough. On a machine like the MF70 I would always use drills with thickened shaft, they run much more concentric. They come with 1 mm, 1.5 mm and 1/8" shaft, depending on the size. Again carbide drills down to very small sizes are available from the same source mentioned above, but beware they are very fragile. If you have also a lathe, you will probably begin to make useful accessories for the mill. I could think, for instance, of a fly-cutter that allows you to mill flat larger work-pieces. Another useful piece would be an indexing block for the PROXXON-collets that can be held in the vice - great for quickly milling-on flats/squares. Talking about vices: my favourite ones are the screwless ones that were originally designed for e.g. EDM-machining. They come in small sizes and the movable jaw is pulled towards the workpiece as well as down.
  10. It is always best to consult reference books on the period of the ship you are modelling. I believe the FAIR AMERICAN dates from the late 18th century, so there should be several of books on rigging ships of that period that you could consult. Some of them may be even available on-line. I believe Darcy Lever's early 19th century book is available for downloading somewhere. One has to distinguish between yards that would normaly stay put and those that would be hoisted up when setting sail. The method of keeping the yard near the mast would differ. As noted by the others before me, a rope, the 'parrel' would be slung around the mast and the yard in a particular fashion. In your period it may be in two parts which have been spliced around yard and has an eye-splice in each end; the two ends with eye-splices would be taken around the mast and lashed together. On the hoisting yards you may find also wooden cleats with a half-round hole; a rope- or iron parrel with hinges would secure such yard to the mast. Sometimes parrels could also be loosened or tightened from deck level; this may be necessary when bracing-up hard the yards. The best model solution is always the one closest to the prototype, irrespective of scale. Due to the limits of material dimensions (and your dexterity) you may have to simplify things. However, I would dare say that the parrel-arrangement as discussed above could be even reproduced in a 1:200 scale and believe there are examples for it on the Web (look for miniaturist, such as McCaffery). Your ambition is the limit ...
  11. I have been using an undercoat of Prince-August (a French packaging of Vallejo it seems) 'bois' (='wood') acrylic underpaint and then a thin layer of acrylic 'wood stain' from a DIY. This then was 'weathered' using thin washes of acrylic 'burnt umber'. The colours in the photograph below are sligthly distorted due to the mixed-temperature lighting, but comes close to what teak might look like (though the intention was actually tarred, weathered oak, hence also the weathering with white pastel):
  12. Yes, Plexiglas is a nice material to machine. I have been making small deck-houses etc. with this method since the late 1970s. My late father worked for a sister company to that manufactured Plexiglas (Röhm GmbH) and we had easy access to it in all sizes and shapes. Röhm GmbH also produced a comprehensive technical manual for working with Plexiglas, of which I have a copy - very useful.
  13. One day I would like to build a model of a yacht like this as well … what scale did you say is it ?
  14. Engine-room skylight The frame of the engine room skylight consists of a an etched brass part, folded up and soldered together. On the inside, grooves have been etched that will serve to locate the protective bars to made from thin copper wire. The lower frame was constructed from Pertinax. The ‘wooden’ gratings on both sides of the lower frame are again etched parts. Unglazed framework for the engine-room skylight Once this structure was complete, a square block of the size of the footprint of the skylight was milled from a piece of Plexiglas. Squaring up a Plexiglas block for the skylight In the next step the roof-shaped faces were milled on. To this end, a small insert vice was set to the appropriate angle of 40° in a larger vice bolted to the mill table. The fixed jaw of the insert vice pointed upward and the side of the block to be milled rested against it. This ensured that all four inclined faces would have the same angle and would start from the same height with respect to the reference (bottom) face of the block. Milling the sloping faces Polishing the sloping faces A very smooth surface with little tool marks can be achieved on Plexiglas. The final polishing of the surfaces was done using CRATEX-type drum polishers followed by a felt drum loaded with polishing paste. All in the same vice setting to ensure a flat surface. I was lucky the Plexiglas 'house' fitted like a plug into the skylight frame. Finished Plexiglas 'glazing' block Glazed engine room skylight To be continued ...
  15. Drawplates for wire and drawplates for dowels are different animals. The one for wires do not cut, but reshape it, by forcing it through a conical opening. One can probably abuse the ones for wire to make dowels by drawing the wood the wrong way through. However, it is important that there is sharp cutting edge. When drawing wire, one needs to anneal the wire between each pass, as it may work-harden. Drawing is normally done on a sturdy drawing-bench that allows to pass the wire straight through the drawing plate or die and to apply a steady force. The wire is pulled with a special pair of pliers, the closing force of which is proportional to the pulling force.
  16. You are certainly correct concerning the shape of the planks, they were irregular, economising the available wood. I think, however, the original question concerned the third dimension, that is the thickness. Reconstructing the original thickness is quite problematic, as the wood shrinks in different ways, depending on the species of wood and how it was cut from the tree. I am inclined to think that the surface was quite even, no steps between planks. Otherwise, it would have been rather difficult to caulk the hull and the deck. Steps would also be very exposed to erosion and weathering, increase the drag of the hull and constitute a tripping hazard. These were factors people even 400 years ago were aware off (to some degree). The absence of pointed pieces has good reason: it is almost impossible to caulk such parts permanently. The part would always bend and move.
  17. Shouldn't be too difficult to turn them on a lathe or even a power-drill with some files and a template ...
  18. My guess would be that the shipwrights then would have been quite capable of producing a smooth hull and deck all over. It is a question of strategy and method. The photograph below shows how this is done with an adze (then and today the main tool for this purpose) at the beaches of Sansibar: One should also consider that a model probably needs to look a tad neater than the prototype, or these intended unevenesses are likely to be mistaken for shoddy workmanship.
  19. Thanks ************* Skylights, Companionways etc. I have used two basic techniques for the construction of skylights, companioways etc., depending of the type and purpose. Skylights particularly were constructed around small blocks of Plexiglas milled to shape. Other types were constructed from strips of Pertinax. More intricate parts were etched from brass. For some of the skylights a combination of the techniques were used. Etched parts for skylights Boiler-room skylight The prototype construction of the boiler-room skylight is not completely clear from the drawings I had, so that I had to 'fudge' it a bit. First the central piece that supports the chimney was shaped from a piece of Plexiglas. The PROXXON drilling machine was abused as a milling machine to this end: a diamond-cut milling bit was taken up into a collet and the height of the machine set so that the bit reached just below the table. Now the Plexiglas part was passed free-hand along the mill. The form to be cut out was printed on a piece of paper that was stuck to the Plexiglas. It was tested against the shape of the etched grilles in order ensure a snug fit. The box around the skylight was constructed again from Pertinax. Shaping a Plexiglas-core for the boiler-room skylight The assembled boiler-room skylight To be continued ...
  20. Chain-stoppers One pair of chain stoppers is located immediately behind the hawse pipes as usual. A second pair is placed above the chain locker, which is located immediately in from of the armoured barbette. The bodies of the stoppers are rather complex castings, calling for some complex machining operations in model reproduction. The same basic technique as for the bollards was used. Given the complex shape, however, machining is not possible in one set-up. For certain operations the axis of the spigot has to be perpendicular to the milling machine, while for others, such as drilling it has to be parallel. For the latter and for milling the various slots, I choose to transfer the dividing head to the lathe. This has the advantage that its centre line is at the centre of the lathe spindle. Milling the profile of the fore chain stoppers Milling operations using a dividing head in the lathe The slots were milled using a micro-tool made from a broken carbide drill, the end of which was ground flat. This results in a non-ideal clearance of 0º, while the cutting angle and side rake are that of the original drill bit. However, not much metal is removed so that this doesn't really matter here. Home-made milling bits made from broken carbide drills ground flat One set of stoppers was milled from brass, while for the other one I used PMMA (PLEXIGLAS®, PERSPEX), the main reason being that I ran out of brass stock. However, genuine PLEXIGLAS®, is pleasant material to machine and easy on the tools. It holds sharp edges and it easier to see what you are doing than on the shiny brass. Acrylic paints seem to key-in well - basically it is the same molecule, of course. On the downside one may note that small and thin parts are rather brittle. Using diamond-cut carbide tools gives a nice smooth finish, but normal CV- or HSS-tools can also be used. Milling in an upright collet-holder on the milling machine While for the bollards and the front pair of stoppers the spigot could be on the geometric centre of the part, making it easy to measure while machining, for the after stoppers I had to place the spigot to the centre of the pipe down to the locker, so that the concentric rounded edges could be milled. The pictures show this operation. Round-milling the body of the after chain-stopper using the rotary table of the milling machine The stoppers have now completed with etched brass releasing levers, etc. The fore stoppers were also soldered to surface etched base plates. The completed chain-stoppers (right column, the grid of the cutting mat is 10 mm x 10 mm) To be continued ...
  21. Muntz-metal is a kind of brass, i.e. an alloy of copper and zinc. Zinc sheathing uses … zinc.
  22. This surface would not look metallic at all. It just looks a dull grey.
  23. Working close to the collet improves precision due to less run-out and side-play, which are minimal on a watchmaker's lathe already ... ******* Completing the capstan Again the guiding rollers are a simple turning job. The shapes were produced with a free-turning graver and by rotary milling in the dividing head. Using a worm-driven dividing head to round-mill the head of the chain-rollers Using a worm-driven dividing head to round-mill the head of the chain-rollers In the meantime various etched parts had been produced, including the base plate made up of two different superimposed parts and minuscule pawls. Also a chain separator from 0.3 mm copper wire rolled flat was produced. The various parts were soldered together. The etched parts for the spills The completed capstan (lower left corner, the grid of the cutting mat is 10 mm x 10 mm) To be continued ...
  24. Yes, the squares on the cutting mat are 10 x 10 mm ... ******* Anchor capstan One component that always has puzzled me somewhat as to their manufacture in a model has been the sprocket on capstans. While the geometry on horizontal windlasses is quite simple, with suitable depressions for the chain links around the circumference, the sprocket on a capstan is a complex affair. In any case the capstan head cannot be manufactured in one piece. So I broke it down into three pieces: the spill head, the sprocket and the base drum with the pawls. The whole capstan has more pieces including four guiding rollers and a finger to pull the chain off the sprocket. The cast base on the prototype will be reproduced as a surface-etched part. Milling the sprocket, 1st step Milling the sprocket, 2nd step The sprocket started out as a 2.5 mm brass rod taken into the dividing head and five notches were milled to produce something like a five-pointed star (these sprockets typically have five or six arms). The notches for the horizontal links were cut on the lathe with a forming tool. The sprocket then was faced and drilled to fit onto the capstan stem. The next step is cutting it off. This produces some burrs that need to be taken off. Luckily I have collected over the years almost every type of work-holding device that was ever made for the watchmakers lathe. Here the insert jewel chucks came handy to hold the 2.2 mm by 0.6 mm sprocket for facing-off. Cutting with a forming tool Facing-off the sprocket in a jewel chuck The capstan head is a simple turning job. The curved surfaces are pre-cut with appropriate lathe tools and then finished with very fine files. Incidentally, the implement shown on the appropriate picture is a rare miniature micrometer, also coming from the watchmakers toolbox and very handy for measuring narrow recesses and the likes. They came in sets of three, the other two are a depth-micrometer and one for measuring the width of notches respectively. Finally, the three parts are soft-soldered together. Assembled capstan head To be continued ...
  25. Zinc was indeed used in the mid-19th century as a cheaper (though less lasting) alternative to copper. It seems to have been particularly popular in the Baltic and for ships that did not venture out into the tropics, but only to southern European coasts. Zinc is toxic to certain species. Zinc in seawater would attain a dull, powdery grey colour relatively quickly, owing to its relative inertness. This intentional corrossion would make it dfficult for 'fouling' to take a hold on the surface. One had to take care that no less inert parts of the ship (such as propellers, rudder hinges etc. made from bronze) would come in contact with the seawater or otherwise the zinc would electro-corrode away. This is one reason why zinc was given up again soon as anti-fouling sheathing.
