Everything posted by wefalck
  1. I hope everyone made it safely into 2017. Now that various toolmaking and machine-building projects have been completed I am returning to SMS WESPE after a long break. First I had a look at the box with the parts already made to aid my memory a bit: Also, the building-log proper is a great aid in recapitulating what has been done already. I hope to be able to report soon here on real progress ...
  2. Hope everyone arrived well in the New Year ! ************* Here a few additional pictures of the machine with the attachment for indirect dividing mounted. It also shows the over-arm (or rather under-arm) to support longer and slender parts. Both were already fabricated some 15 years ago for the use on my lathe. The first picture also show a micrometer depth-stop for the vertical slide, which was made some 20 years for use on the small 6 mm-watchmakers lathe.
  3. OK, it appears that some people had problems with displaying the movies on non-Apple devices. Here another try: http://www.maritima-et-mechanika.org/tools/micromill/MF-V1.mp4 http://www.maritima-et-mechanika.org/tools/micromill/MF-V2.mp4 http://www.maritima-et-mechanika.org/tools/micromill/MF-V3.mp4 http://www.maritima-et-mechanika.org/tools/micromill/MF-V4.mp4 http://www.maritima-et-mechanika.org/tools/micromill/MF-V5.mp4 http://www.maritima-et-mechanika.org/tools/micromill/MF-V6.mp4
  4. Tonight I did some test-runs and made some short videos, showing the machine in action: http://www.maritima-et-mechanika.org/tools/micromill/MF-V1/Resources/MF-V1.mov http://www.maritima-et-mechanika.org/tools/micromill/MF-V2/Resources/MF-V2.mov http://www.maritima-et-mechanika.org/tools/micromill/MF-V3/Resources/MF-V3.mov http://www.maritima-et-mechanika.org/tools/micromill/MF-V4/Resources/MF-V4.mov
  5. Good idea for a simple tool to make a difficult task easier ! But the title of the post is misleading or even wrong: ratlines don't actually need to be 'tensioned', in reality they are slightly sagging due to their own weight. This uniform sagging is rather difficult to reproduce, as the catena-shape changes as you proceed upward. I would modify the tool a bit and drill two holes in the ends for a couple of machine screws with wing-nuts. But take caution not to squeeze the shrouds flat ...
  6. Following on from dafi's post, one should point out that most people (except dafi) put the identations on the wrong way around. These are not rivetted plates as you would see on an iron- or steel-ship, but (relatively) thin sheets of copper nailed onto a flexible bed of tarred felt. Hence, the nail-head are slightly sunk in as opposed to being proud of the surface. Therefore, all commercially available sheathing, whether embossed or etched is wrong - unless you apply the the embossed ones the other way around - no remedy for the etched ones. While overlapping application would be technically correct, I am not so sure of the scale appearance, as even the thinnest (0.05 mm ?) copper sheet is still too thick for many scales. Below is an image of the real thing on HMS GANNET (1878) that shows the identation from the nailing and that the overlap of the sheets is barely perceptible on the original:
  7. Like the systematic approach to polishing. It is important to not cross-contaminate between different grades of polishing agents. The jewellers, watchmakers and other metal-workers have a whole arsenal of different abrasive materials that contain pumice, chalk/limestone ('rotten stone', Wiener Kalk = Viennese Chalk, Tripel or tripoli), and red iron-oxides (Parisian Red). One can have these as liquids (as above) or bound in waxes to charge felt-wheels.
  8. Thanks for the kind words. Well, actually most of the really serious machining (namely the guides for the slides) was done decades ago by the Lorch-guys in Frankfurt/Germany. That really cannot be done with 'nothing', but requires a bigger and sturdier milling machine than I have. The quality of their workmanship is difficult to find these days. I also wished I could work with cast parts, rather than having to fabricate them. About the scale: sorry, I am so familiar with the size of these machines, that did not think of adding a scale. The overall height of it is 35 cm or 14". for those across the water. ********************** One of the most important aspects of the machine is the flexiblity in holding even tiny work-pieces. The dividing head offers a wide variety of work-holding options using the spindle-tools from the 6 mm-lathe, such as 3- and 6-jaw-scroll-chucks, independent 4-jaw-chucks, ring- and step-chucks, face-plates, as well as the whole range of collets from 0.3 mm to 14 mm diameter. 3-jaw chuck Step-chuck Ring-chuck Independent 4-jaw-chuck A very old face-plate (I have newer model too, but this is not refurbished yet) The dividing head can be positioned at any angle between vertical and horizontal. Direct dividing is provided for by a drum with three rows of 8, 10, and 12 indents respectively. This allows the milling of prisms or pyramids with 2, 3, 4, 5, 6, 8, 10, or 12 sides. A worm-wheel of 40 teeth that is driven by worm on the axis of which is mounted a dividing plate with 90 teeth provides for indirect division of up to 3600. While such divisions are unlikely to occur in practice, the fine angular movement is useful for shape-milling against a schedule table. When the indent is disengaged the worm-drive can be used for round-milling. Dividing head in horizontal position Dividing head set at an angle Worm and dividing plate for indirect dividing Collets for work-holding are particularly useful, as a wide variety of small parts can actually by milled from round material of various diameters and then sawn-off from the stem held in the collet. The collets, a holder for standard 6 mm end-mills, arbors for slitting saws, as well as a small boring-head are stored in a fitted antique box. Antique collet box adapted to the use with the micro-mill To be continued ...
  9. Once the motor-housing was painted, what remained was to solder the electrical connections, to put everything together, to oil and to adjust the machine ... The completed micro-milling-machine To be continued ...
  10. I believe draw-benches existed since the Middle Age. There is also a variety, where the drawn wire is wound up on a reel that also transmits the pulling force.
  11. Although hardened steel draw-plates were used for brass and iron/steel, these would wear rapidly, resulting in a gradual increase of the diameter. So, today carbide or ruby dies are used for anything harder than copper and, of course, in any commercial context. I would doubt that drawing your own wire without a draw-bench as illustrated above would be successful. The forces and steady action required would be difficult to apply by simple drawing with elbow grease. The process results in the metal sort of flowing and this has to be maintained also without changing the direction of pull. Otherwise the wire will break. However, this is digression from the original subject ...
  12. Well, we prefer the original Bellini, though we were not impressed by the one served in Harry's bar (in the Cipriani hotel in Venice), where it was invented - they seem to be rather nose up in the air there and the setting is not really nice and comfy, more something for serious drinkers, such as Hemingway, who don't want to be distracted by the scenery ... our prefered spot for a Bellini (and some excellent food) is the terrace of the Gritti.
  13. These tongs really only make sense, when you have a draw-bench. A draw-bench is used for drawing wires, not wood/bamboo. The draw-plate is fixed at one end and at the other there is a chain with a geared winding mechanism, or a belt. The hooked arm of the tongs points upward, while the straight one slides on the bench - in this way the pressure on the wire increases the stronger you pull. Here a historical example from the Internet: Source: http://phiden.net/wp-content/uploads/2014/08/draw-bench.jpg I don't think these tongs would be useful to draw material for tree-nails ...
  14. The motor also needs a housing, so that the electrical connections can be adequately installed. I wanted to make the supply cable detachable in order not to have it hangig around, when the mill stored away. Unfortunately, the motor has the somewhat odd outer diameter of 51 mm and it was not so easy to come by a suitable pipe. Finally, I chanced upon a can from a weird drink that pretended to be an alcohol-free Bellini-cocktail. In this way the overly expensive can somewhat amortised. I shortened it to suit with a diamond saw in the hand-held electrical drill. A lid was cut and turned from a piece of 5 mm Plexiglas™. Three fastening holes were pierced with a needle and opened up using cutting broaches in the very thin and flimsy drinks can. The lid was drilled and tapped for M2 screws. A 6 mm hole for a 3.5 mm mono-socket was pre-drilled with a small drill and then reamed to size into the bottom of the can. The motor housing before painting To be continued ...
  15. OK, first another little item, I have been working on in between travels ... ********************* Several years ago I constructed a micro-vise that was intended to be hold in a collet e.g. in the upright collet-holder on the larger Wolf, Jahn & Co. milling machine. The stem has a 5 mm diameter, which was chosen so that it also fits into the largest regular collet of a 6 mm-lathe. Shop-made micro-vice While the collet thus can be mounted in the dividing head, this may not always be convenient. Therefore, a small holding block was fashioned from a piece of steel. Steps in machining the holder for the micro-vice This holder allows to rotate the vice around the clamping bolt, but also in the mounting hole. With this arrangement and the tilting capability of the vice itself, it can be offered to the milling spindle in any conceivable angle. http://www.maritima-et-mechanika.org/tools/micromill/MF-125.jpg Parts of the holder for the micro-vice http://www.maritima-et-mechanika.org/tools/micromill/MF-126.jpg Holder and micro-vice Various ways of positioning the micro-vice To be continued ...
  16. It really depends on the period and the type of guns. There are three main materials for guns, namely bronze, cast iron and steel. I gather, we are talking here about either bronze or cast-iron guns. The surface treatment was intended to stop or reduce weathering and degradation of the guns exposed to the weather. To my knowledge, bronze guns were not given a specific surface treatment. With time bronze develops a brownish patina that reduces further degradation. However, as bronze sculptures, one can also create articial patinas by rubbing the material with sulfur compounds or vinegar-based concoctions. This can change the colour from a deep green to a sort of metallic black. Cast-iron rusts easily and needs to be protected. This was done by either (black) paint or by creating a passivating patina. In the latter case the guns were repeatedly rubbed down with vinegar. The resulting rust, mixed with iron-acetates, was solidified after drying the guns carefully by rubbing them with lineseed-oil. Effectively, this process created in situ an iron-oxyhydroxide-based paint of a deep brown colour. Some navies also used black or (rarer) dark green oil-paint. One would need to establish this for a particular prototype and period. We have become used to certain types of surface treatments on models and their guns. Very often, these may be aesthetically pleasing, but are certainly not 'realistic'. While a painted gun certainly would not have a metallic appearance (except for the muzzle), a surface treatment on the model that suggests 'metal' might enhance their appearance. In the case of black guns, I would spray-paint these in a semi-gloss and then rub ridges, rims etc. lightly with a very soft pencil; this then can spread and blended in using one's finger or cotton-sticks. Such a treatment gives a certain 'plasticity' to the gun. Not sure about a procedure for bronze guns, as I never had this issue.
  17. Beautiful execution and excellent workmanship ! However ... the Muntz-metal sheathing would not have had raised nail-heads I think. Not sure how the plates were fixed to the isolating wood layer, but assume they would have been nailed like in the older days. It was important to achieve a galvanic separation between the Muntz-metal and the iron/steel plating underneath. When the plates are nailed down on the wood (with a layer of felt in between), the pattern looks a bit like on a deep-buttoned Chesterfield sofa. One can see this on the copper sheathing of HMS GANNET (1878) in Chatham:
  18. The amount of pressure needed obviously depends on the hardness of the material to be knurled. I found that the brass I am using is very easy to knurl. I also knurl brass dry ! Just at the end, to wash out swarf, I gave it a blast of WD40. Knurling is actually a kind of milling operation, meaning the material is not displaced but more or less cut. Some of the material though squeezes to the sides of the knurled rim and needs to be cleaned up with a light cut on the lathe or free-hand with a file. I seem to have been lucky that the hardening of the knurl seems to have worked fine. There is a risk that with my primitve arrangements for this it may crack. I pre-heated it with the hot-air soldering gun and then continued with a blow-torch until it was heated to a cherry-red. The PROXXON-torch I used was a bit on the weak side, a bigger one would have been better. On the other hand, one should avoid to overheat, because this burns the carbon in the steel. Heating on a bit of charcoal can counteract this.
  19. Thanks, gentlemen. I like to have beautiful things around me - this includes my machines and tools ***************************** Managed to squeeze a couple of hours in the workshop in between business travels and entertaining friends, who stayed with us for a week ... The rotating spindles, such as the main spindle and grinding spindles on watchmakers lathes have a knurled sleeve in brass that is meant to prevent dirt from entering the bearings. The one for the grinding spindle used as dividing head was missing. Using an original one as example, a replacement was fashioned from a piece of round brass. After facing a short length of brass it was drilled 5 mm and taken onto a respective arbor for turning the outside to size. A rim was left standing that was given a round knurl. Back on the 3-jaw-chuck, the inside was bored to a tight fit to the body of the milling spindle. The front part was given a concave bevel with a form-tool. The various steps in machining a new dust-sleeve Original dust-sleeve (right) and fabricated copy (left) Sleeves in place - an original one on top, the newly made one below To be continued ...
  20. It is also a question of the scale at which you are working. The larger the scale and the closer you are with the rigging material to the 'real' thing the less likely you will need to secure belayings etc. Where on the prototype they would have slapped tar over it, I would use black/brown paint. On small-scale models, where synthetic material would be the only practical material, you will need to secure knots and belayings because the material does not provide enough friction to hold (as pointed out by Chuck). In such cases I use a drop of light solvent-based varnish - if the need arises, the thread can be softened again by applying a drop of solvent and lines can be tightened or loosend.
  21. Probably the best modern source on seamanship, including furling sails, that reviews practices spanning roughly the 17th to the end of the 19th century is: HARLAND, J. (1985): Seamanship in the Age of Sail.- 320 p., London (Conway Maritime Press). I think every sailship-modeller should have this book handy ! There are also various contemporary works that are available as reprints or as e-books for (free) download. For the 19th century this would be e.g. BRADY, W.W. (1852): The Kedge Anchor; or Young Sailor’s Assistant. Appertaining to the Practical Evolutions of Modern Seamanship, Rigging, Knotting, Splicing, Blocks, Purchases, Running-Rigging, and Other Miscellaneus Matters Applicable to Ships of War and Others.- 400 p., New York (Published by the Author). LEVER, D. (1819): The Young Sea Officer’s Sheet Anchor.- 124 p., London (Nachdruck 1963 bei E.W. Sweetman & Co., New York). NARES, G.S. (1862): Seamanship.- 232 p., (reprint 1979 by Gresham Books).
  22. To add: the notches have to high enough to allow the pins to be lifted out of the sockets on the stern-post ...
  23. OK, the thread is already a few weeks old, but I just wanted to chip in. Below is a picture from a dhow-building place in Nungwi on Zanzibar in 2012, where these boats are built using the traditional methods: Source: http://www.maritima-et-mechanika.org/maritime/tanzania/tanzania.html The scorching shows that an open flame was used to soften the garboard plank, which then was held in shape and place until set using various clamps and levers. Steam-bending was and is a common process in furniture-making. The most famous of all probably is the German firm Thonet, that had before the war their main production facilties in what is now the Czech Republic. They made incredible complex pieces using massive cast-iron pattern to hold the steamed wood in shape until set. On the hot-air soldering station: I got mine several years ago and use it on all sorts of heating tasks between 100°C and 400°C(not F !). No problems with the equipment so far. I rarely read product reviews for such things as I feel quite capable to deal with issues. One problem is that people pay KIA and expect to get Mercedes. There is a reason why things are cheap and not only economy of scale, so I am prepared to rectify (some) issues as a trade off for a lower purchase price (that not necessarily guarantees quality these days). A lot of the Chines-made equipment has to be considered to be in an 'advanced stage of production' and you can finish it to your requirements. With this attitude you safe yourself a lot of aggravation. If the air-gun comes on, when the main switch is off, this is, of course, a concern. However, by looking at the wiring, it is easy to tell, wether the main switch is really the last element before the wires leave the box. If not this would need to be rectified. Otherwise, I have all my equipment plugged into extensions that can be switched off and that are so, when I am not in the workshop. Or, I unplug pieces of equipment out of principle.
