Posts posted by wefalck
First I sand down these much to thick rings ...
Actually, depending on period and circumstances the hoops may not have been made from iron at all, but rather from split twigs of hazelnut or birch (I believe). There is a special technique to hook the ends together without nails or the likes. Such barrels would not contain any ironwork, but would be constructed entirely from wood. I have seen photographs of such barrels being made well into the 20th century, e.g. for shipping herring.
Thanks, gentlemen, for the kind words. Back to the subject ...This building-log is a recreaction of the one started on MSW 1.0, so that the updates now may follow in short intervals, while the actual work was spread out over a considerable time. There were several delays due to some technical difficulties and the work was further delayed by some tool-making projects, numerous travels and too much work in general.I have been thinking very hard on ways to make really convincing rigging blocks of late 19th century model. Some of the blocks would have to be as small as 1.6 mm long, while the typical block would be just under 2 mm long. Most of the blocks would have to have external ironwork. The ropes for the running rigging typically would have a diameter of somewhere between 0.15 mm and 0.25 mm in 1/90 scale, depending on the particular rope. This would mean that quite a large number of holes of equivalent diameters would have to drilled to a depth of around 1 mm, which is a bit of a challenge. I wanted to avoid this by cutting slots into the material and inserting real sheaves turned from brass. The slots at the bottom would have to be filled in later.Shape-milling of blocks with a fly-cutterSet-up for shape-milling the blocks in a dividing head on the milling machineThe outside shape of the block was to be milled in the dividing head from round stock. A table was prepared that calculated the exact distance of the cutter from the centre-line for each pass, so that eventually the oval shape would emerge. This raw part then was transferred to the lathe for cutting the slots. While perhaps a good idea from a theoretical point of view, the slotted material proved to be too flimsy for further manipulation.Slotting the blocks on the latheThe set-up for slotting on the latheTherefore, a different method was devised, for which the material was changed from brass to Plexiglas. The outside shape was cut as before, but instead of using a flycutter, a dental burr was used, which due to its smaller diameter exerts less force on the part. Then the holes were drilled at pre-calculated positions. The cross-section of the future blocks were positioned in the round Plexiglas stock in a way that the axes of the sheave would coincide with the rotational axis of the dividing head. This arrangement allowed the sheave to be milled out of the solid. The holes then were drilled through with a miniature drill.Milling of the sheaves from the solid stockMany shipmodellers just drill their blocks and perhaps, if they have a thin enough tool, attempt to file the edges of the hole round to give an indication of the sheave. However, this never looks quite right, with the ropes sort of sticking out sideways from the hole, rather than running around the sheave.These blocks then were cut off from the stock on the lathe. It should be noted that the stock was turned down at the end, so that it could be inserted into the collets against a shoulder, ensuring repeatable positioning. The latter was needed, as the dividing head on the lathe and the one on the mill use different types of collets.The botter has a variety of rather special blocks that also needed to be made, such as the sheepshead-block for the foresail. They were produced the technique described above, but in some instances were 'eyeballed' from the stock in the dividing head. One violin-block was also built up from hard paper with real brass sheaves and filed to shape by hand.The blocks were completed with 'ironwork' from copper wire. On the prototype this ironwork is forged from different sizes of bars. The blacksmith shapes the cross-sections as needed either flat (around the shell of the blocks) or round/oval for the hooks. This process was repeated up to a point by flattening the round copper wire used. In order to flatten the wire in a controllable and repeatable way another watch-repairing tool was adapted: a so-called jewelling press. This tool has a piston the movement of which is controlled by micrometer stop. In watchrepairing it is used to set bearings, i.e. the ‚stones’ or ‚rubies’ to an exact depth.I made some anvils and pistons for it that allow to squeeze the copper wire to a preset thickness over a particular length. The thickness is set with the help of a feeler-gauge.Jewelling tool with die for flattening wireA selection of unpainted blocksThe results from all these labours are by no means perfect, but I think better than what I have seen around in this size.I am not certain, however, whether I would go down the same route again. It would be useful to be able to solder together the straps, which is out of question for blocks made from Plexiglas. Using hard paper/Pertinax would be an option, but drilling this material is not so easy, considering the small sizes of drills required. Perhaps one should use boxwood. In both cases round rods would have to produced first from the available stock. Or at least one would need to turn-on a round end, so that the stock can be taken into a collet – square collets for watchmaking lathes don’t exist ! (this is another of my future projects, to make a set of square-holed collets.wefalck
Jules van Beylen (I think he was the conservator at the museum in Antwerp) has written many books on Dutch/Flemish boats and ships. There is also a monograph on the hoogars:
BEYLEN, J. VAN (1978): De hoogaars, geschiedenis en bouw.- 184 p. (De Boer Maritiem).
Most of the books cited above are packed with drawings. Van Beylen's books are actually written for modellers and have very detailed description for building a model in a 1/20 scale. Full size drawings seem to be available separately. Dorleijn's book contains also folded plates, but seems to have become extremely expensive over the past. I have almost all of the books cited in my library.
Yep, got a copy, but it doesn't have a date in int.
Garward, liked your Estwing geologist's hammer ! Bought one like this in my first year at university ...
Here a couple of interesting books on botters and boeiers, albeit in Dutch:
CRONE, G.C.E. (1926): Nederlandsche Jachten, Binnenschepen Visschersvaartuigen en daarmee Verwante kleine Zeeschepen 1650 -1900.- 309 p., 85 Abb., Amsterdam (Swets & Zeitlinger, Nachdr. 1978 bei Schiepers, Schiedam). - with English translations.
BEYLEN, J. VAN (1985): De botter - Geschiedenis en bouwbeschrijving van een Nederlands visserschip.- 223 p., Weesp (De Boer Maritiem).
DORLEIJN, P. (2001): De Bouwgeschiedenis van de Botter. Vierendertig voet in de kiel.- 168 p., Lelystad (Uitgeverij Van Wijnen ).
KAMPEN, H.C.A. VAN, KERSKEN, H. (1927): Schepen die Voorbijgaan. Een verzamling Afbeeldingen en Beschrijvingen die de Nederlandsche Binnenwateren bevaren.- 351 p., Amsterdam (A.N.W.B. Toeristenbond voor Nederland).
OSTROM, C. van (1988): Ronde en platbodems schepen en jachten.- 144 p., Alkmaar (De Alk b.v.).
SOPERS, P.J.V.M. (196?): Schepen die verdwijnen (bearbeitet von H.C.A. van Kampen).- 162 p., Amsterdam (P.N. Van Kampen & Zon).
VERMEER, J. (2004): De Boeier. – 528 p., Alkmaar (De Alk & Heijnen Watersport).
Thanks, ssd.
No botters and boeiers are different types. Botters are fishing boats, while boeiers where originally used for local (market) traffic and as pleasure boats (a use that continues until today). Boeier tend to be much more rounded and have a lower length to breadth relationship than the botters. Also their leeboards are much broader, almost a quarter of a circle.
Here is picture of the boeier DE SPERWER in the Zuiderzeemuseum in Enkuizen:
More pictures here: http://www.maritima-et-mechanika.org/maritime/zuiderzee/zuiderzee.html
Thanks. I have been collecting (and restoring) these machines for about 25 years now. The machines themselves are between 50 and 100 years old (I guess).
Next installment will come soon.
Continuation ...
The cast mast was nicely done by Artitec - in principle, but was too short for a boat of this size, did not have the right chocs for a boat from Marken and above all was warped. A new mast was fashioned on the lathe from a piece of steel rod - I did not have suitable stock of boxwood or similar and brass, aluminium or plexiglas would have not been stiff enough. The mast was turned in steps on the watchmakers lathe. This also allowed to turn-on the mast bands. It was then transferred to the dividing attachment (http://www.wefalck.eu/mm/tools/dividingapparatus/dividingapparatus.html) on the milling machine to mill on the squares. The various eyebolt and cranes were fashioned from copperwire and soldered or glued on.
As the mast, the boom was turned on the lathe from a 2 mm steel rod. The flexing of the rod was utilised to obtain the taper towards both ends.
Again the bands were turned on and the boom was tranfered to dividing apparatus for drilling the holes for eye bolts etc. The goose neck was turned from steel and the square, where it attaches to the boom, milled on using a very small end-mill.
The gaff has a rather odd, pear-shaped cross-section. In addition its longitudinal shape is rather crooked. It was fashioned from a piece of brass wire that was tapered off and bent to the right shape.
A piece of brass sheet was cut to follow the curve of gaff and hard-soldered to the brass wire. The pear-shape was filled-up with soft solder. Then the claws that were fashioned from brass were soldered on. Finally, the 0.2 mm holes for the line with which the sail is attached were drilled. The gaff was completed with various bands fashioned from partially flattened copper wire.
- avsjerome2003, yvesvidal and druxey
3
Thanasis, didn't you mix up the scroll saw (or fret saw) with the circular saw ... ?
Blackening only works on the brass itself, not on soldered joints. However, blackening first and then applying a light coat of black with an airbrush might be a good solution - the second best would be applying the paint with a brush. The blackening gives the brass a 'tooth' as well as being obviously being already black. In any case careful degreasing and not touching the parts with bare hands before either blackening or painting is essential.
Bought the Proxxon drill press almost 30 years ago and it is still good in spite of some abuse.
I cannot comment on the band saw, but have their scroll saw. Somehow I always seem to fight with the scroll saws, perhaps I am pushing too hard, but I found that the cut is never vertical in material of any thickness. A band saw is probably better in this respect, but has limitations to the minimum radius you can cut due to the width of the saw band. I don't think it is a particular good proposition for cutting out frames at the usual model scales.
Didn't know the English name of this nut, In German it is called Steinnuß, i.e. stone nut. The Latin name, Phytelephas macrocarpa, means big-fruit plant-ivory. I knew that until the middle of the 20th it was used to make buttons. Didn't know you could still buy it. Could also be an interesting material to make very small blocks from. By heat-treatment you seem to able to change the colour into a light brown,
I suppose Dacron sails are not 'tanned', but the fibre is coloured. It is not so surprising that coloured sails age faster than white ones, as the so-called albedo is lower, i.e. the reflectance for light. This means the sail absorbs more energy that can destroy pigments. Obviously the pigment used in colouring the dacron fibres is not light-fast. The red or yellow ochre used in the 'real' tanning procedure is a mineral pigment, iron (hydr)oxide, which is light-fast, but may change its hue to changes in the amount of water incorporated into its chemical composition.
... I always use Preiser-figurines (and in fact scale my models to match the model railway scales). They are the anatomically most correct and most finely sculpted. They also do 'academy', that is naked, sets in various scales that you can dress with putty etc. as required.
The rope that connected the outer ends of the capstan handlebars was simply there to steady the bars and prevent them from slipping out.
The tanning of sails was only done on small(er) boats, where there often was, due to their operating conditions, no opportunity to dry the sails before stowing. The tanning, which involves dyeing the sail in a bark solution and applying a mixture of tallow/oil with yellow or red ochre, makes the sails somewhat water repellent and resistant against mould (the main objective), but at the expense of slightly damaging the fibres. Tanned sails are not as strong as undyed sails for the same material.
True, a partial coat of gloss may locally change the 'depth' of the lustre of the paint.
Actually, if the decals aren't too complicated, I would cut them with a sharp scalpel as close as possible to the printed area. This avoids this 'silvering' effect.
The set-up and tools depends on the lathe you have, the size of the cannons, and on how many you have to make.
As one has to turn up to left and right shoulders as it where, i.e. to the bands, I would use a narrow straight tool. That is a tool that is 0.5 to 1 mm wide at the front and has side-relief ground into it. For brass there should be no top-rake, or it will 'dig in'.
People tend to make cannon from one piece, but, as you have to turn it around at some stage to finish both ends, they may be difficult to hold, because the profile is not cylindric, but conical, or even curved. Therefore, I would break down the design into two parts. The bands offer convenient separation points. Because the parts are shorter, you can probably also work without tailstock support, which makes working sometimes easier. The front part you can drill through a the calibre of the gun and in the back part you drill a blind hole with exactly the same diameter. A short piece of rod allows you to align the parts for soldering or glueing.
I would turn the basic shape using the slide rest and then finish off the rounded corners either using a file or a hand-graver. Again, the short sections make this operation easier. Finally, I would go over the pieces with steel wool while the lathe is running.
I would finish all the front parts and all the back part together, so that you can keep the same set-over for turning the conical parts.
Duplicators are probably nice (I never use one), but to make a good template is not that easy. I make myself a table or sketch of the slide-rest movements, so that I can repeat exactly the same movements for each part. This is akin to what a CNC-lathe would do under computer control.
When the guns are to be painted anyway, you may want to consider using Plexiglas/Perspex or aluminium as a material. I think it is cheaper than brass and lighter. Personally, I love to work with Plexiglas. It is also easy to glue and takes acrylic paints well.
You don't say what you are working on and how the finish will be. Typically, decals are applied once the basic paints are on. Some people apply a glossy varnish at the place were the decals go - this prevents air from being trapped in the pores of matt paint, which manifests itself by a silvery sheen in clear parts of the decal. Any wheathering etc. is then applied. Finally, a light matt or satin overcoat will blend everything together.
Yep, there is lots of useful stuff in that profession. My father trained as a MD (but never practiced) and after he died, I found a lot of interesting 'tools' in his drawers, including a collection of old-time anatomical scalpels (really heavy duty - I don't like to imagine what they were used for
), a really sharp bone chisel, needle holders, arteria clamps, pincettes, etc.
Thanks,@realworkingsailor, there is no real urgency. I have a particular future application in mind and if you did get a chance at some stage to take a picture, this would be much appreciated.
Tulles have the disadvantage of all commercial threads: they are fluffy with a lot of fuzz. I think that threads of these fabrics are particularly fluffy to make them soft and flowing.
The hairnets the ladies of our grandmother's generation used to wear might be something else to look into, though the mesh-width might too wide for this purpose.
@realworkingsailor, that looks like interesting stuff. Unfortunately, the picture on their Web-site is rather small. Would you have a close-up of the (unpainted) material ?
I don't know any details about these nets, but could imagine that it would be possible to make one's own nets in larger scales (say 1/64 or larger) using fly-fishing fly-tying threads. I would make myself a jig with appropriately spaced rows of headless pins to mark the location of the knots and then knot away. There is a special type of knot for nets that can be found in the literature.
For smaller scales, one could perhaps just pierce the thread with a needle, where the knot is supposed to be and secure the crossing with a drop of lacquer.
Zuiderzee-Botter by wefalck - FINISHED - Artitec - RESIN
First of all, thank you very much to all well-wishers
With many parts of the boat actually now completed, I turned my attention to the sails. I did this before painting the model, as various fitting and shaping actions will be required that may damage the paintwork.
The plan is to show the sails in a sort of semi-set stage, as they would be when the boat is in harbour, in order to allow them to dry. This going to be a much bigger challenge to represent convincingly than fully set or furled sails. As the boat will be shown in its winter rig, there will be only two sails.
The raw material is a very thin tissue paper that I found in my stock. The first step was to draw a sail plan 'as built', i.e. with the actual dimensions of the mast, boom and gaff.
Sail-plan ‚as built’
Sail-plan ‚as built’ (detail)
The shape of each panel of sail-cloth was pencilled in also with the help of a french curve. The drawing then was backed with a piece of stiff cardboard and covered in clingfilm. Based on this pattern the individual sail-'cloths' were cut from the tissue paper with the addition of 1 mm for the seam. This is rather wide at this scale, but inconsequential as the sail will not be translucent, being tanned and dressed (i.e. soaked in a broth from bark and smeared with a concoction of tallow, oil and ochre) on the prototype. This treatment prevents the formation of mildew and permits one to furl the sails when still wet.
The ‚cloths’ of the mainsail.
Using the drawing as a template, panels were stuck together using wood-filler (CLOU Schnellschleifgrundierung) as glue. The tissue paper soaks up the filler, turning it into a sort of compound material. I prefer wood-filler over diluted PVA-glue because it does not swell the paper and the joints can be loosened and re-adjusted by applying a drop of thinner. After completing the basic sails, outside margins and doublings were added in the same way, based on the detail drawings in VAN BEYLEN, (1995) and DORLEIJN (2001).
Glueing together the sail cloths
To be continued ...
