Posts posted by wefalck
  1. Thanks, Jan. I think I saw the link to the boatyard before. It is particularly interesting, as it shows the construction of the underwater body, which otherwise is not often seen, even if the boat is hauled out, as it usually covered by a thick layer of tar.
    I gather, if you don't want to sail on a sieve and constantly pump, you have to replace planks from time to time. It is a problem with 'historic' wooden ships, that much of their wood has been replaced at some time or another. I don't remember the percentage, but I think a good deal of what now is the VICTORY actually has not been in the battle of Trafalgar  ...   :wacko:
  2. The individual parts were cut such that the front and back pane abutt against the side panes. Since ordinary Plexiglas is much more prone to scratching than silicate-glass, the protective paper is being left on as long as possible. On the inside, however, it would be difficult to remove, once the case has been assembled. This was even more the case with the slightly oldish sheets I am using. Therefore, the paper was completely removed from the side that will face inward. On the outside a narrow strip along the edges was removed to prevent the glue sticking to it. The paper was only removed from the parts that were assembled at that moment.
    Plexiglas can be cemented together with a variety of glues, including cyanoacrylates or those UV-hardening acrylates that recently entered the DIY market. Epoxy resins, however, should not be used, as their exothermic reaction can stress the Plexiglas, which eventually will lead to fine cracks. If you can produce a perfectly flat edge that is at a right angle to the sheet, you can use a low viscosity cement. In most DIY applications it is better to use a more gap filling higher-viscosity cement.
    In order to achieve high quality bonds from both, the optical and mechanical point of view, the best option is to use the Plexiglas-manufacturer’s (Rhöm, now Evonik) own cements. I used Acrifix 192, that is easy to obtain. Acrifix is a light-curing cement, essentially liquid Plexiglas (http://www.acrifix.com/product/acrifix/en/products/reaction-adhesives/acrifix-1r-0192/pages/default.aspx, more information on Plexiglas cements here: http://www.acrifix.com). This means that the bond has almost the same optical and mechanical properties as the sheet itself. According to the manufacturer, Acrifix 192 has a shelf life of two years. The stuff I bought apparently in 1998 and kept in different fridges at various places around Europe since then worked without any problems. Only the open time was a tad short, but this seems to have been due to my two 100 W worklights. When I used only one and turned it away from the case, I could work longer on the bond.
    Cementing the parts of the glass case together
    The parts were arranged around the base plate. It would have been better to build the case before starting the scenic display, but my impatience to try out my ‚icing’ skills got the better of me. Now have to work a bit more cautiously when cementing the parts together. The four parts are held together temporarily by a gadget that is normally used to fix picture frames and the likes during glueing. In addition I used cellotape to keep the parts together. In order to allow the application of cement, the fixations are loosened a bit at the respective corner. The cement is applied rather sparingly in order to avoid it squirting out and damaging the surfaces of the Plexiglas sheet. All four corners are cemented together one after the other.
    It is possible to obtain a perfect bond without any bubbles – with a bit of practice. However, I wanted to be on the safe side and used a minimum of cement, which may result in some bubbles. This is of no consequence as the corners will be covered later by L-profiles in brass anyway.
    To be continued ...
  3. Actually, on the real thing there were no treenails in the decks. What you see (or rather mostly not, except when really standing on a deck) are wooden plugs that cover the holes drilled for iron bolts (at least in later ships). The plugs do not show end-grain (as would treenails do) but were cut so that the grain runs in the same direction as the planks. The idea was to make them almost invisible for  aesthetic reasons.
    It seems to be a fashion among modellers to use treenails to show how much effort they put into a model. There is also some mechanical reason, as the treenail securely fastens the plank. Otherwise, I would ignore them on a true 'scale' model.
  4. As I noted before, the model is now at a stage, where it needs protection from the domestic elements. The first step was the base-board with the scenic surroundings. The second step is a glass case.
    In spite of the hot weather I started this today – it turned out that the study/workshop was actually the most pleasant room in the appartment, but I had to restrict the lighting to a 100 W lamp ...
    Scoring of the Plexiglas before breaking (it is still covered in its brown protective paper).
    The construction of the glass case is inspired by the design MCCAFFERY describes in his book ‚Ships in Miniature’ of 1988. In the past I used silicate-glass for the purpose. Silicate-glass has the advantage, that it doesn’t scratch. From another project, however, I had a pile of 3 mm thick Plexiglas-sheets since 1980 in my materials hoard. My father then worked for a subsidiary of Röhm GmbH and we got the stuff quite cheaply. From that time I also have a copy of the very useful manual on how to work with Plexiglas.
    Fixing the plate at the edge of table
    Lucky for me, the panels for the case could be cut from those sheets with just a few cuts. In a domestic context, when you don’t have a big table saw, sheets of that thickness are best broken, rather than sawed. When marked the sheets are scored with a ‚cutter’ knife. Per milimeter of thickness it needs one go with the knife. It is important to score right to the edge of the sheet, otherwise corners may break out. The sheet then is clamped down with the scored line exactly at the table edge. Then, with a decided jerk, the plate is broken off. A clean, straight edge that needs little or no sanding before glueing is the result.
    A clean broken edge
    To be continued soon ...
  5. After a longer break – due to a lot of travelling, here an update.
    In spite of the high temperatures in our appartment, ice began to form in the harbour of Volendam. At the beginnig there were only a few floes, but the NE Wind pushed them together and piled them up in front of the dyke – pancake ice. The botter-crew tried to keep the ice away from the boat – ice is not so friendly to a wooden hull, but in vain. The low ridge of loose ice around the boat bears witness to the efforts of the crew with crowbar and broadaxe. In the meantime a continuous ice cover has developed, streaked with a few snowflakes by the wind.
    As noted before, the basis of the ice surface is a piece of Plexiglas, which was stiffled with acrylic gel using a bristle brush. The next step was a bit of an experiment: in the past I created drifting foam and breaking waves using a sort of icing (no pun intended) made from sugar and wallpaper glue. As we now have acrylic gel and varnish, I tried out a mixture of sugar with these. The sugar in France is rather coarse, so I ground it down in a mortar. The sugar partially dissolves in the varnish and then recrystallises. The viscosity can be adjusted by mixing sugar and varnish in different ratios. It dries up milky-white. Using this mixture, the ice floes were modelled in several steps. Also, the piles were set into the ‚ice’ with this mixture.
    Actually, several years passed by since the pictures in the previous post was taken. In the meantime the piles and other woodwork further weathered and became gray. Well, pastels and white watercolour accelerated this process. Vegetation has began to encroach on the dyke. Reeds root at its toe and grass began to cover the brickwork. The severe frost, however, has made the grass to wilt.
  6. Attention, the Proxxon FD 150/E doesn't have a leadscrew, so you will not be able to cut threads ! It is what is called a mechanic's lathe. The cross-slide has to repositioned by clamping it to the bed. Which means that the longest piece you can cut is not the bed length between the centers as in other lathes, but only the travel of the top-slide.
    The good thing is that it has a conus for standerd ER collets, but the capacity of the ER11 collets is rather small at 7 mm. One has to remember though, that ER collets are made for toolholding and not workholding. They don't hold properly, when not using stock that is as long as the collet itself.
    The backbone, i.e. the bed, seems to be the same extruded profile that is used for the column of their micro-mill.
  7. Of course, it is possible to stick wood onto styrene. However, the veneers you would be using have to coarse pores and the surface is actually damaged by the process of cutting the veneer. The latter doesn't matter so much in full-size applications, but will be highly visible on a model. You would also need to sand, fill and polish the surface, which would be not so easy. Many wood polishes would, in addition, attack the plastic.
    It is actually possible, to achieve quite convincing wood-looks by painting. On the Web you will find a variety of examples. Typically you apply a base coat of acrylics and then work with washes of e.g. oil paints. I am not showing the example of my Zuiderzee-botter here, because it is highly weathered, which is probably not what you are after.
    Good wood has its price, which is one reason, why wood kits cost money - though not all seem to contain good wood. If you insist on wood, may be going for a small-scale scratchbuilding project is a good proposition. You are then in full control of everything.
  8. This may have varied from navy to navy, but most models of the time seem to show the hammocks bent to an U-shape. The picture below shows the somewhat later BELLE POULE in the Musée de la Marine, but practices remained unchanged for some 200 years.
    These rolls consisted not only of the hammock as such, but also of the associated bedding.
    BTW, 'children caly' is neither in my mental nor printed dictionary, what is it ?
  9. It seems, judging by old time recipes, that the old-time guys concocted all sorts of mixtures hoping to keep nasty creepy-crawlings and ravaging weeds at bay. Chemical, biological and microbiological knowledge was not yet very well developed and certainly not wide-spread among the mariners. They tried to conconct something nasty that remained stuck to the ships' bottom and prevented lifely things from sticking ...
    I would also assume that on a ship such as the Endeavour they would run out of semi-industrial supplies, such as lead-white, at some stage. Lime can be produced quite simply in a short time by burning e.g. coral rocks in a kiln, but the production of lead-white requires slabs of metal lead, vinegar, acid-proof earthen ware and lots of time.
  10. No.
    Lime - CaOH which slowly carbonises to CaCO3, is already in an oxidised state. Its colour is brilliant white and absolutely stable - see the White Cliffs of Dover.
    Lead White - 2PbCO3·Pb(OH)2, contains lead in an oxidised state. Again its colour is brilliant white and it is very stable.
    I am not aware of any other component that would oxidise to a respective white.
  11. If you are using an accurate vice with a vertical V-groove, you can also tighten the vice onto the rod held in a collet; then you lower the head of the drill press with the tilt-lock loose and it will automatically swing into the right position, when the vice touches the table; then lock the head. This may give you more accuracy, as the spindle nose of the PROXXON tools is rather small and it is, therefore, difficult to see, whether it sits flat on the reference surface, e.g. the top face of the vice.
  12. If you use a vice, you may want to actually square up to the fixed jaw of the vice, rather than the table. This (partially) eliminates additional inaccuracies introduced by the vice. I am using this kind of (grinding) vice:
    Here you can use the surface of the fixed jaw to level the spindel nose against, or its vertical face, when using a rod in the chuck/collet.
    This method is not absolutely precise, but quick and sufficient for most of our practical applications.
  13. @JMaitri, unfortunately I don't have a picture handy and no time at the moment to take one. However, there is nothing special, just a piece of drill rod (or in my case a broken-off carbide drill of 6 mm diameter) that is held in the drill chuck or (better) a collet. On the table there is a block with one side that is absolutely vertical to the table surface. You unlock the head/column and swivvel it until the rod touches in its full length the vertical face of the block. Voilà. Then you lock everything.
    If you can run the head down so that the spindel nose touches the table, there is even a simpler method: just make the nose touch evenly the table surface. Voilà ancore.
