Posts posted by stevenmh
- mtaylor and John Allen
- 2
I've made a "lathe" using an old drill and had success with the slight tapering required for the main and top masts of my Mimoli Constitution cross-section. However, when it came to shaping the yards, disaster struck - happened on both the main and topsail yards - the diameter at the ends is supposed to be about 3mm.
I'm a bit fearful of trying to shape the top-gallant mast and yard and the royal, since these all need to end up much thinner than 3mm.
Is there some trick to this that I am missing? Do I need a drill with less torque? Am I making a big mistake using the dowls that came with the kit - if so, what wood would you suggest?
I was trying to shape it in my DYI drill-lathe - think I just squeezed too tight and gave it that spiral fracture - fortunately I had plenty of material and could start over, with a lighter touch.
- CaptainSteve, Canute, EJ_L and 1 other
- 4
- zappto, GrantGoodale, Canute and 2 others
- 5
An Egyptian cotton thread Chuck recommended, but I didn't know about the 'stretching-on-the-rack' bit.
- Canute, EJ_L and CaptainSteve
- 3
Cannon finally done; in addition to trying to rig those little tiny blocks, I also had a lot of trouble preventing the lines from twisting - any suggestions on how to prevent that from happening would be greatly valued.
I've also finished trimming and notching the deck beams - I need to install the rear and the middle beam so I can fit the remaining knees into place, then it is on the gluing down the pumps, buckets and scuttlebutt, applying a bit of poly and then it will be time to frame the spar deck.
- zappto, EJ_L and Ryland Craze
- 3
My first (and so far only) attempt at wooden models is a semi-kit-bashed cross section and I find myself fascinated by it, I would love to try a cross section that would be a bit less, well, trying, a little less make it up as you go.
Wasn't there talk at one point about a Viking ship, or did that morph into the barge?
Rigging the cannon has been such an adventure - particularly when the glue doesn't stick. First tried to use wood glue to strop the blocks and attach the home-made wire bolts to the carriages and bulkheads, didn't work on the wire and tended to swell the blocks and close up the holes; CA also often would not stick and soaked into the ropes. Will make for a real adventure when I have to strop dozens of tiny blocks for the rigging. Stay tuned.
Still here, been a hectic couple of months, but getting the space in the basement set up again and should be on to rigging the guns, putting in the rest of the knees on the gun deck, and framing the spar deck.
Did manage to get most of the posts in on the berth deck and some representation of the hoses for the pumps in - I made the mistake of gluing on the planking of the gun deck before putting those in, so had to work from below and bend and twist and glue them all at once - coulda used 2 or 3 more hands at that point.
Guns and gun deck fittings are just dry fit at the moment. I'm also trying to decide how to handle the finish below the waterline. I don't like the look with shiny copper foil at all, and the green wood chips that came with the kit are so uneven, not to mention ugly. I may go for a bit of fantasy and paint the hull an off white to represent lead-infused paint, and may paint just the one side I have already painted the black with white stripe - I am still planning to leave the other side unpainted, I think the walnut with wipe on poly will look fairly dark, and the holly I got is very light (and hopefully will remain so once it to has been poly'd), so I may just leave the rest of the hull unpainted.
- Canute, CaptainSteve, EJ_L and 2 others
- 5
Thanks EJ - although I did see someone copper the hull while sticking the mast into his keel clamp!!
Turning to turning match sticks in my home-made drill lathe. Using these for the columns between the berth and gun decks - a bit hard to see when painted white.
I also wanted to have something representing the lines that drew water from the bilge into the pumps - settled for 2mm - ish square balsa sticks, painted white again, that straddle the keel, go through the berth deck openings and up to the underside of the gun deck where the suction pumps will be placed - you can see them most clearly behind the mast seat.
- EJ_L, Canute, CaptainSteve and 1 other
- 4
A bit more progress - dry fit the mast, added the columns in the hold, and tried out a figure from a 1:96 plastic kit on the 1:93 berth deck. Nearly finished with the deck frames and waterways, almost time for the deck planking (still haven't figured out what will be covered and what left open) and then time to mount and rig the great guns!
- 5
Hammocks about as good as I'm gonna get them, I think. Now to finish the deck framing for the gun deck. Originally I was intending to plank over the whole deck, but now I think I will leave a good portion of it open so the berth deck and the hold are visible from above - just need to figure out which sections to do what with. I do want to mount all 4 long guns, just to complicate things.
- CaptainSteve, EJ_L, Canute and 1 other
- 4
Starting to put in some of the berth deck furniture/fittings before I block my own way with the framing for the gun deck.
Decided to play with making one of the guns, and trying to thread the tiny blocks for the gun tackle. Despite the best advise from several members on how to skewer those darn things, I had to be rescued by the Admiral. Eyes like a hawk, that one.
Then I made the "mistake" of re-browsing some other cross-sections and decided to allow myself to be seduced by Modeler12 and his hammocks. So I'm going to place another roadblock in my quest to complete this thing by the 36th Annual Northeast Ship Model Conference and try to make a couple of hammocks. I bought some bits of cloth at Joann's, but we (meaning the Admiral) decided a scrap of old cotton sheet actually looked best. Photo shows prototype # XVII placed to see the scale. If I do manage to make something I like, I will post the method, but so far it ain't quite right.
- MEPering, EJ_L, CaptainSteve and 1 other
- 4
While waiting for the paint to dry I thought I'd start on the gun tackles (with 3/32" blocks), but since I was having trouble threading my miniscule line through the tiny holes, I figured I'd go back to the berth deck - more knees in place, taken through one of the gun ports. Needs to be painted - again.
- EJ_L, Canute and CaptainSteve
- 3
USS Constitution by stevenmh (Steve Herzberg) - FINISHED - Mamoli - Scale 1:93 - Cross-Section
Forging on - here is the updated version of my poor-man's lathe - works better, but I'm still nervous when I get to the thinner parts - however the main and topsail yards and main studs'l booms have been successfully constructed.
Spar deck is framed and now just needs the port side to be planked, then on to the masts and spars. Given the configuration of the gun deck, especially the cannon that is run in, I don't think putting in the 2 ladders will work - especially as they are in the plans, running port to starboard. Running them fore and aft probably also won't work, so I am going to try to use the materials provided, particularly the risers, to make a grating or two for the hatch.
I also am thinking about changing the positions of the deadeyes - the channels that came with the kit place the fore-most deadeyes so that the lanyards cross over the carronade gunports and the chains have to take a severe turn to avoid the gun deck gunports. I'd just shift them back, but did not really realize this until after I had glued the channels onto the hull, so I will have to give this some more thought - thoughts and photos to come.
I've begun to add blocks to the main yard - using some of the stuff I've seen on this sight the first 2 were a lot easier than I'd dare to hope, but that could also be because they are 4 & 5 mm blocks, not the 2.5-3mm ones I was suffering over for the gun tackles. The upper yards will tell - I'll just spend some time enjoying these victories. The footropes will be made with 28 gauge wire, so hopefully they will not take too long either.
I have not had great love for the blocks that came with the kit, so as you might be able to tell from the above photo, I've gone to Chuck/Syren Ship Model Company to be rescued - I've even combined his single and double 'make-your-own' blocks to make the triple block for the main jeers. You can see the quality difference below - kit blocks still in the bag, Chuck's on the bottom - they still have to be sanded and rounded, but still...
