HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 64 donations so far out of 49,000 members - C'mon guys!) ×
MikeB4
Everything posted by MikeB4
  1. I've decided to send away for the right size rope. I'll obsess over it other wise, you can never have to much rope around anyhow.
  2. I bought some rope from the Syren Ship Model Co. I realize I purchased the wrong sizes for each rope.I'm going to use this rope any way and hope it looks OK.
  3. You've done an outstanding job on the planking. the first time I planked my boat I ended up ripping all the strakes back off and starting over.
  4. Nirvana, yes I put a pin at the bottom of the mast. I'm not going to put a step under the mast, I do believe I read in the instructions that a step is optional. I drilled a hole in the center floorboard where the pin will fit.
  5. The instructions are a bit ambiguous on the rigging. I don't blame Chuck though, after all this is an advanced model kit and it would be assumed the builder already understands how blocks and rigging are properly tied. Stepping back a moment, I except my model isn't going to be perfect (I wish it where). An analogy would be that If I where making music it's more like jazz than classical, but that's OK it's still music. I just thought I'd throw that in because sometimes this hobby can be so frustrating, but I realize the only real failure is giving up and I also realize that all the talented builders on this website put in many years to learn their craft. With that said I need to learn how to rig this puppy.
  6. I've completed the mast. I found tying the blocks to be more of a challenge than I had anticipated. looking at the remaining seven blocks they are tied in different ways. I'll need to do some research on this subject before proceeding.
  7. I may stop by to say hi on Saturday. I'm only an hour away from Mystic. You guys are going to love the large selection of nautical books in the gift shop, second to none.
  8. I went to a flea market this past weekend and came across this. The seller didn't know which vessel it came from, only that it was out of Cape Cod. I don't know what I'm going to do with this, but I had to buy it.
  9. Eric, yes, I used left over scrap wood from the kit, There's plenty of it. I made it from the piece of wood that the oars where laser cut from.It was the perfect thickness for the tiller Mike
  10. I've carved out the area where the pintles will go on the rudder, this will give a better bond and the pintles are flush with the rudder. I hand carved the tiller with an arch instead of the straight version, this was time consuming but quite satisfying after it was done. now I will proceed with painting the rudder.
  11. I installed the oar locks, I used masking tape to try and mark the proper locations and spacing between each lock. My efforts had a less than perfect outcome but I can live with it.
  12. I've completed the windlass. I thought this was going to be much more difficult than it actually was, especially connecting the windlass to risers. If you follow Chuck's advise and take your time, you should have no problems. I actually got it to pivot on the pins which I didn't think it would be possible. I didn't use any glue to assemble this part.
  13. I Put together the cockpit.The hinges where a bit challenging I used 28 gauge wire and a material I bought at a hobby store called Bare-metal. It's an adhesive metal foil that comes on a sheet in various colors. I got the one called black chrome and with a little patience it seems to have worked out pretty good. I'm going to paint the cockpit seats and locker in red. I also need to do some paint touch up on some areas where the paint has chipped off.
  14. I decided to to try and customize some wooden belaying pins because it will be a little more accurate to the period. The only pins that I could find are the right length but they are much to wide,So I carved them down using my power drill like a lathe. With some practice I could probably get much more accurate but this will do for now.
  15. I've hand painted the hull under the water line. Nothing ended up under the masking tape which was a nice surprise when I pulled off the masking tape.I thought for sure something would have seeped under like on the last project I did. In the future I would like to start using an airbrush, but for now I'm doing everything with a brush. I'm going to make sure the paint is fully dry before adding a coat of poly over the white paint..
  16. I've laid down the floorboards and platforms. I'm thinking about ripping up the platform at the bow though because it's slightly off. I'll give it a little brake for now and return to it later and see how I feel about it.
  17. My boat isn't perfect by any means, but I do feel good about a lot of things I've learned with this build. I'll probably give it another coat of red paint, it's slowly coming along.
