giampieroricci
Everything posted by giampieroricci
  1. I went ahead with the work a bit. I completed the guns bridge. It is not very precise, I had to adapt some solutions with the drawings of the structure, some measures did not match, and above all there is a serious error in the fixing of the double pulley for the maneuver of the rudder which is not fixed to a beam, but I could not move it so as not to compromise the perpendicularity with the steering wheel.
  2. this corvette is a real show !! One of the most beautiful models I've ever seen!
  3. I went a little bit further with the model. The false bridge: The beams of the first bridge:
  4. Working on this scale is really difficult; It is necessary to be very precise because a small error of a few tenths of a millimeter is enough and the measurements no longer return .... In the work you have to caress the wood, obviously only with manual tools, perfectly sharp chisels, fine sandpaper, precision tweezers, double magnifying glass (now I don't see it more closely). The gluing must also be very delicate and the excess glue must be removed immediately. For the hold compartments the thickness of the boards is 0.4 mm, and the glue must take hold on this minimum thickness ..... But this scale is very exciting for me!
  5. this work of yours is one of the best masterpieces I have ever seen! ... Simply wonderful and perfect in the smallest details! You really are a great one, Johann !!
  6. Tho wood is pear wood and brazilian boxwood for the wall of gunboats mtaylor reacted to this Quote
  7. I started working inside the belly .... In order not to make the model too heavy, I decided not to place the planking of the hold
  8. The model is now of extreme fragility and therefore I thought of starting the coating of the dead work:
  9. I i am building this model at 1:96 scale, as it is written in the title. the model you see in the background is H.M.S. Alfred that I am building at the same time, based on drawings by Harold Hahn at 1:72 scale Here is the topic:
  10. thanks for your appreciation! Meanwhile, I started to open the gunboats
