giampieroricci
Everything posted by giampieroricci
  1. I fixed the decoration in place. Now I just try to polish it a bit 'and pass a coat of clear varnish
  2. gouges I use are self-built using old screwdrivers and cutting pieces .... Your work of sculpture is truly exceptional, believe me!
  3. Very nice figurehead! How have you made?
  4. Your work is simply perfect!!!
  5. The wax is applied on the outside of the lantern, warming it slightly to be modeled. Then I mixed the two components of the resin and I filled the lantern. The resin takes about 12 hours to dry. When the resin is hardened, it is easy to remove the wax with a bit 'of hot water
  6. for the lantern glazing I thought of a transparent resin that use rail modellers to reproduce the water: I prepared the lantern covering it with wax, to allow casting of two-component resin
  7. Some small step forward; there is nothing yet fixed, everything is provisional: I would try to do the glazing, but I do not know if I can!
  8. I removed the counter-shaped timber with a small tip mill, patiently!
  9. I remade the central part of the light, with a different technique. I didn't like the previous light. I made a wooden counter-form on which to secure the uprights of the light of two brass supports; I also used a thinner wire, 0.8 mm for the uprights and by 0.4 for the spreaders:
  10. some progress. This work is really difficult. Especially I can not get the little crosses at the bottom of the third lap; I don't like how it is coming. I'm afraid that I have to look for alternative roads ......
  11. Continue I realized that I have mounted the hat of the light on the contrary, but fortunately it's only temporary, to make pictures....
  12. These days I am trying to build a sternlight. I began by its cover I first made of wood, in order to understand the forms, and then I tried to make brass.
  13. Great job!!! Pure art!! Could you show a little more detail the implementation of the ruling wheel?
  14. Thank you for your likes, friends! I also completed the serpents of the starboard side
