I have finished bulkheading the frame and cutting out the under deck beams etc, i have done abit of a mod-con on the troubled bh's as spoken about by hamilton, my workflow here and idea was to start with the top of the keel where the bh cut outs are, my theory was to create a gentle slop towards the middle and produce a sheer, this would make correcting the 2 bh's a little less work, i also built up with a bit of balsa the difference in deck hight to keep a corresponing sheer. My next job after the keel/bh assembly is set will be to sand down and smooth edges abit, then i will give the bulkhead frames abit of shaping, then the next job on my list will be to give the inside deck sections a lick of white wash, then i will start panking the lower deck. C.
- 455 replies
- slightly modified
- greyhound
Does anyone have any advice over correct paint colors for the 1719 light frigate ships, i am tempted by off white for interior bulkheads etc, red ocre for upper deck bulwarks & fitting against them etc, flat metal black for cannons and iron work, french blue for the hull detailing near to rails, a rich pine stain for hull above whale, whale same black as above, flat white for hull from waterline and below, and gold or brass for ornaments guilt figurehead etc. What do people think. C.
- 455 replies
- slightly modified
- greyhound
I made some more progress today but also when backwards abit when i stumbled on a problem with the placing of the front bh's in relation to the the front area of the keel, there was to much keel showing with to much profile, so i took the keel off and cut back the false keel about 8mm, i also re shaped the front keel bringing it closer to the line of planking when i do it, i have also been continuing with my bh's again working from bow and stern towards the mid-ship area. Here are the pics... C.
- 455 replies
- slightly modified
- greyhound
After having a day off due to my other hobby - cameras calling me i got the chance to play with my new nikon dslr that i use for my pics on here, anyway yesterday was on with the build, i have been working with the bulkheads from both bow and stern, as i am mindful of hamiltons problems with the two miss-aligned and shaped bh's, and as i am showing a wider lower deck with part deck floor beam and knees, i have been working on 1 bh at a time then fitting/glueing and dry testing the main gundeck against the line of the bh's. I have also found that by correcting for a slope or sheer over the quarterdeck of possibly 5-10mm this equates to a real sheer in full size terms of about 2-4ft over the same area, this will meen i can file out abit of the bh/frame slot and sit the bh's slightly lower, hopefully helping to correct abit of the problem hamilton disscovered, this should look ok as i know they would have had quite a deffined slope/sheer anyway. I will continue in this form and adjust as i go and fingers crossed end up with a hull shape that is not to bad, and if anything like hamiltons i will be extremely happy. C.
- 455 replies
- slightly modified
- greyhound
Carrying on with dry-fitting stuff aswel as fitting the bulkheads, i have decided to widen the lower deck, this i started on bulkhead 4 and have cut it out to extend the planking area and also to include the floor beam knee's as shown, the other two pics show the general dry-run layout with the captain/leutenants door/window assembly(not sure if i will use this with a little re-work or make my own), and the other a general plan view showing how the quarter/forecastle/poop areas will look. I may even consider extending the decks even further down to include a hold(i know this wont be seen but it will be fun building and i will know its thier) abit like building a sub and fitting it out inside prior to sealing it up. Heres the pics... C.
- 455 replies
- slightly modified
- greyhound
Not at all mark, thanks for following. C,
- 455 replies
- slightly modified
- greyhound
Great progress there she is looking mighty fine and very realistic looking, i understand what you meen about finding the time, i was in a similar situation some time ago, but since my dissability and the wifes we have more time on our hands, mine for boat building and photography and the wife with her knitting, also its appropriate my build where we live - its a 17th century cottage that saw action during the english civil war in 1640 so building such a ship seems to fit in, i think the house approves aswell.
More progress yesterday, with the decks and adjusting the bulkheads as they do not lign up with the slots in the decks, i have also marked out and adjusted the new cut outs for the masts, as all three are in slightly different positions due to me moving the main deck about 5-6mm further back. I also fitted the next bulkhead from the bow section num 3, and the corresponding one at the stern to help me align the decks for the poop and the forecastle, these are not fitted as i have plenty to do to them and i will even plank them on the table then fit them prior to planking the walls of the bulwarks. C.
- 455 replies
- slightly modified
- greyhound
Hi hamilton, im still toying with the idea about the forecastle, to square it off/or not to quare it off? i might if im lazy, make it an interpretation where it had all the other mods but kept a rounded forecastle, but i am deffinatly extending both the poop and forecastle areas, as shown in my pics, they show the flat areas minus the planking, i will do both these as seperate builds and plank them prior to fitting, then i will work on the bulwark/stud areas when i have fitted them. I would like to use abit of artistic licence here with my build, as i am sure there are no deffinatives regarding thier exact look, as we know alot depended on the captain at the time, especialy with smaller alterations - ladder situating etc. C.
- 455 replies
- slightly modified
- greyhound
Thanks hamilton, I have started work on the rear section today and fitted the rearmost b-head 13, i then worked on the poop deck and forecastle, because i have decided to build her as HMS Lyme (with a little artistic licence-well alot), both these areas needed extending, so i went from the plan marked around extended, then added some ply the same thickness as the poop/forecastle deck, i have also fixed a template of paper underneath and secured with strong glue to aid strength, i also filled in the poop deck stairway port as i will fit two external ladders instead. Here are the pics showing these two areas and the frame plan showing the alterations i will make to the quarterdeck bulwarks, and others. C.
- 455 replies
- slightly modified
- greyhound
I have been working on extending the rear section of the keel, and correcting the wrong angle of the rudder post. i added a small strip of balsa i had knocking around, i constructed it - 8mm wide down to nothing, this will meen the rear quarters/poop deck area wil be 8mm longer, but this might just help the quarter windows abit. C.
- 455 replies
- slightly modified
- greyhound
And an old pic of the pilot boat i built for my old vic kit, i still have this boat but had to leave my quarter completed vic kit. C.
- 455 replies
- slightly modified
- greyhound
Thanks hamilton, it will certainly be an interesting build, and hopefully my build experience both plastic and wood will come in useful. On with my build, after offering up forecastle b-head num 1, i soon discovered the slots on both the keel and b-heads where tight, so i opened both up slightly after checking the centre point of the slots, then a nice join was made, i then fitted brace 23s and offered up both number 24s, but as i did with my vic build i decided to fan out these two supports at 45deg angles, first i sanded the edges of both to meet at a point then glued both in place. I did this because i found it makes for a smoother more natural curve for the hull planking. Anyway heres the pics..... C.
- 455 replies
- slightly modified
- greyhound
Does the kit come with extra materials or are they exact? just incase i decide to lengthen the forecastle area and plank it, this is what i would need to do to build the kit as HMS Lyme, also i would need to plank over the rear step upto the poop area as this would be acsessed via extarnal steps again if i build HMS Lyme. C.
- 455 replies
- slightly modified
- greyhound
Thats ok, i will keep a carefull eye on your build as it will help me no end with mine. C.
Hi dragzz, jeff and hamilton, Thank you for the replies, Im fairly well up there with farring i had to do this quite considerably with my vic build, also adding shaped timbers from formed wood strips(coffee stirers) and constant-Constant-COnstant sanding the bulk heads with different strengths of sanding material to get a good smooth planking shape, i had to go almost completely away from the de-agostini build instructs, as they where also not 100% acurate, mind you i started from the bottom up from the keel and even started to add some lower floors like the hold etc. This i will try to do with this kit, and after scouring the net for info on the 1720 20-24 gun man-of-war(frigate), it is possible with some mods to build any of the four mentioned, Lyme is perhaps the most interesting as she shows to have a slightly lengthened forecastle area and poop with the addition of a (poss 6pdr cannon) on the top of the poop deck, and and additional one rearward and on the same deck as the our cutouts. So lots of possibilities C.
- 455 replies
- slightly modified
- greyhound
Well it arrived today in a nice tidy box well packaged and presented, i checked over all the contents and decide my build strategy, i first checked the keel for squareness and found that it was not sitting totally flat when on its side, so i gently flatened it aided by abit of friction/heat, next was to design/build a building frame so it was to the shed i ventured....i found a piece of 2"x1" soft wood, after cutting to length and shaping the ends, i fitted four pieces of balsa that where placed against the keel for aligning, then after gluing in place with some strong glue. Here is my first pic showing the above, but as i dont have a close up or wide lens just 55mm minimum on my dslr, i may struggle to show close/fine details.... C.
- 455 replies
- slightly modified
- greyhound
What i will do is try to space the 11th port quite close to the side cabin window assembly, as this looks like how they have been laid out, like in the victory where nelson had one in his quarters that was lashed against the side when not in use, and when in action his best and most trusted gunnery men would fire from it. It looks like there might just be enough room just after bulhead 12, possibly not quite centred between bulkheads as with the others, but a slight nudge towards bul 12 might not look to bad, even if not open or cut out it could be a dummy port just engraved with hinge assembly. C.
Thank you for that hamilton, i have been saving some diagrams and pictures of greyhound and her sisters, and one or two first obvious things i can see, firstly i noticed that the bulwak on the real ship steps down further back towards the mizen mast close to bulkhead no 10, and the mention of there being 11 gun ports on the real ship, i think the missing number 11 port is in the rear captains cabin, just as in many fighting vessels. C.
Hi hamilton, some realy great work you are doing there, i have ordered mine and await delivery in a few days, i cant wait to get back into period ship buliding again since my last build of the de-ag part build Victory that got asfar as the hull palnking stage and some extra detailing i was putting inside. Your build is an inspiration, as is most other members, and i follow with great interest. C.
