sudomekh
Everything posted by sudomekh
  1. I have ... 70 MF .... but this machine for brass is very weak ... I would like 300 watts
  2. if you want to show on the model copper plating and mounting boards .... you will not want balsa or foam .... I am not a supporter of these materials linden, pine or something unsteady OK!
  3. Ненад М..это груша на маленькой шлюпке....а теперь представьте ваш тип дерева для этой работы Edit comments from Moderator: Please post in English. Nenad M.. Pear is on a small boat .... and now imagine your type of wood for the job
  4. Nenad M. .. Try to use a more fine-grained trees Example: pear, hornbeam and so dapee
  5. I think Google does not always translate correctly ... if I can not write in the forum .... you tell me .... and I will not do so Sorry!
  6. pear .... take ... you can do it without problems 0.5x0.5 circular saw immediately ... you should submit that 2 mm on a scale of 1/100 it is 0.2 m have you seen ... such railing? no offense ... the appetite will come during the meal)))
  7. I am sorry that climbed on foreign territory)))))) please ... you wenge then had to redo ...
  8. ... I would at least partially filled em space wenge think not particularly suitable for the construction of the model (especially small scale) .... I just did the gunwale of his 1/50
  9. need for such a tool cutters 150 watts or more
  10. Adrieke! I think the small rack of brass for this model ... 1.5 times more than would have been better
  11. I did loop steering of copper (strip and wire, thin tube) ... tin soldering the entire sequence is visible in the photo
  12. not always trust ... instructions ... see more old photos, drawings from the archives and their artistic taste )))
  13. sorry .... I think it helps to understand))) if it's too much, then I apologize again
  14. Adrieke! Sorry! Everything is fine, but the stairs and railings would like to see more subtle, more elegant
  15. went through it all ... that is usually all learn from their mistakes ... try not to lay down a thick layer of putty ... it should remain at a minimum ... Good luck!
  16. Nenad! OK! Then essentially ... pay attention to this part of the body ... in my opinion it is not quite right ... but up to you ... I told only my personal opinion
  17. B.E. Hi! I fully support)))
  18. I did .. MDF frames began to build three years ago ... the spacing of tree filled ... there is nothing dangerous in this material do not see if it is used partially.
  19. Thank you! Sorry ... I do not have a workshop and I build the kitchen))) two halves easier to handle)))
  20. Dremmel ... think ... not really good for the performance of many works in the construction of our models (for rough drafts Dremmel works good) ... and mainly used something smaller
