Everything posted by Kevin
good morning everyone thank you for comments and likes Wednesday day 22 having marked out where the gunports go, a lot of them have been rebated to accept the lids in the shut/closed position, i quickly realised these lids are going to have to be put on at a later date, because i was finding that the sanding of the hull was hiding them. Not regretting doing them like this, but i can understand people questioning my logic behind it, (lol i dont want all guns run out, when under full sail). lots of paint added, and i am still sanding areas that refuse to look good, lower wale added to just give me the warm fuzzy feeling that i have most things in the right place this idea does not work for me, putting the lids on and then finishing the hull, as the gaps fill up and they become invisible
Gun Port Hatches
Kevin replied to acaron41120's topic in Building, Framing, Planking and plating a ships hull and deck
in a continuation to this thread, Victory had, vents fitted, was this common practice, -
Good evening everyone, thank you for comments and likes day 19- a recipe for disaster but so far avoided- hinged gunports Come on AL there has to be a better way for a gunport template I copied the template onto printer paper, cut them out and built them up on the original template, took a lot of messing around to hopefully have them in the right place as non of these are going to be open, i just had to remove the top planking, this side has now been roughly removed, and require some tidying up to get the lids to fit free flood ports still to be marked out
good evening everyone thank you for comments and likes Day 18 completed 2nd planking not in a hurry to do that again, double planking using 1mm x 5mm used appx 150 meters sanded using 240 grit, will do again later with a finer grade after touching up a few places, like the stern where the rudder post will eventually go, worse to come soon (gunports)
i will still have to rebate the lids into 2nd planking, but none of the 140 odd liners needed, apart from the upper deck ones, i doubt very much that with a full set of sails there would be many lids open, Sails to get right will be the issue on this build, was going to do then on a 1/64 Cutty Sark, but thats not available for now
Good evening everyone, thank you for comments and likes day 14 started 2nd planking Well the 1st planking was very messy, but it was so very well worth the trouble to do it, im not a lover of planking in the first place, but with 16 frames using 2mm stripwood in 300mm lengths would have done me in i have thought quite a bit how i would like to present this build and have decided - wait for it...................... A all gunport lids will be shut B i will attempt to do sails on her, whether to use the kit supplied ones or do my own, still to be decided C_ put some lights on her
good evening everyone Day 10 1st planking port side complete thank you for comments and likes this build is quite the monster, i have just finished 1st planking the port side and she has taken 50 lengths of 1x5mm lime strip, the other side is progressing. Although a slightly smaller scale than the 1/72 Victory she looks a far bigger hull. (i need to check that fact out), will certainly dominate the display area when completed The planking is not pretty at all but gives me a lovely base for the next layer once the planking is complete i need to mark out the gunports over 4 deck levels
day 6 1st planking good evening everyone no regrets at all on changing the planking from single to double, i have 100m of 1x5mm lime strip on its way, might need some more, at present im using anything left from previous builds gave her a bit of a sanding, starting to look like the instructions now, working on the gundeck before it more of less gets covered over
wow @Waldemar fantastic reply, thank you so very much
unless you try the Marcle SD14 cargo ship
welcome from the person who has lots of ships, and hardly ever finishes them
good evening everyone day 4, hull build up, and galleries, with some 1st planking pleased with myself on how this id going so far, 90% of the frame is complete, stern galleries have been made up i have changed the kits requirement from singe planking to double, therefore using the kits 1x5mm in the wrong places until my ordered stock arrives.by planking the galleries now, i can protect them better, by going to double planking i think i will be in a better position to display the gunports shut, without having to do the lid linings the light kit arrived today, Thank you @chris watton and i will be possibly sorting that out in a couple of days that pretty well sums it up for today
on recommendation i have now purchased this EIGHTEENTH - CENTURY RIGS& RIGGING. KARL HEINZ MARQUARDT. IST ENGLISH EDITION...
yep its me, asking silly questions again having just finished the Vanguard Models HMS Indefatigable, i have moved on to the Santìsima Trinidad, and it seams to me that she is certainly lacking in the amount of rigging, if i was to rig her with info from my Caldercraft HMS Victory would i be that far out, or is there a decent POR i can turn to, were allied 3/4 deckers more or less the same
day 2 hull build up Good evening everyone My concerns for a sloppy loose joint build have gone away, i did a test fit of everything, and wasn't impressed, but once all the locking tabs are inserted and the glue allowed to dry the hull is quite sturdy. but still feels very light weight and looks fragile, i am already onto planking the middle gun deck, this needs to be done now before the rest of the upper hull is fitted looking ahead and seeing the lack of frames, i am going to convert her to a double planled hull and order some 1X4mm lime strips. she will then have a decent base for coppering, i also do not intend to have her with all guns showing, hoping to do the same as my Vic and have them in vent or shut
