Kevin
MSW Social Media Moderator
Everything posted by Kevin
  1. good evening everyone thank you for comments and likes day 49 continuation of tween decks one or two transverse beams missing, may find them outside if the boi has taken them i am finding this build to large to get any decent photos, i may have to drag a wide angle lens out tomorrow i think i will start to frame the stbd side, this is possibly the most enjoyable build i have ever done SD14: A STANDARD DESIGN CARGO VESSEL | Yorkshire Film Archive (yfanefa.com) top deck stbd side stern section at last the tween deck is sitting in its correct position, this now shows the height to the top deck
  2. good evening everyone thankyou for comments and like comments day 48 tween deck transverse beams a lot of progress made in the last few days i decided to make a lot the internal decks and deckheads in modules i have found, for me it works very well, and allows me to get all the longitudinals quite straight, also allows painting a lot easier lots of transverse beams ready for fitting these are for the stbd side midships engine room lower level ready for paint tween decks level nearly complete, looks sqiffy due to the fact the decks are just placed on, and not slotted into position
  3. Good evening everyone thank you for comments and likes, and feedback about if i should do so many posts, im presently averaging about 4 hours daily Day 44 tween decks box girders made upto frame 99, all lower deck cargo bulkheads made up
  4. i will continue going down the port side with the occasional bit on the stbd side to keep it from getting out of shape, but any input from anyone about anything you see wrong or suggestions i will be grateful, this is my one chance to make this something a bit different
  5. good evening, everyone thank you for comments and likes let me know if you are getting bored with my posts, please day 43 tween deck box girders frames 54 to 99, upper deck transverse beams port side 17 to 54 painted cargo hold deck and bilge tanks Kevin’s shipyard paint schedule - machinery spaces green decks customer requirement – green decks in all cargo holds forward of the engine room and machinery spaces (this is just as well as I painted them wrong) the transverse beams are attached to the longitudinals but not the box girders
  6. hope you are feeling better this evening the diorama is looking fantastic
  7. good evening everyone thank you for comments and likes no dog photo bombs tonight day 42 port side engine levels corrected, bulkhead 84 made up and fitted everything with a clip is just a temp hold, not glued
  8. if i was able to find a correct engine i would try to obtain one,
  9. Good evening Jan just the hull, framework and superstructure no prop, anchors or internal detail i do have some links for a few compressors, but US supplied and costly i have a engine but needs to be rescaled down to 1/70
  10. good evening everyone thank you for comments and likes day 41 engine room levels as the port side will be fully enclosed i started putting in the engine room levels for that side everything seams to be lining up so far put some paint down as well today green and white for machinery spaces, grey and grey with white box girders and deck heads for the holds i had some decent outside photos of the engine room until i realised i had put the i had put the flat level in the wrong position, oh and the boi wanted a mention lol couple of the better photos from today with the engine room level in the wrong position
  11. Good evening everyone thank you for comments and likes Day 40 stern frames complete, and stbd side steering flat frames are in the build slowed down for a few days as i had to finish the Easter project, but managed to get a good few hours on her today.
  12. Good evening everyone day 37 stern build up continues, and a wheelie bin 3 days since my last post, and not much to show for it, life got in the way the stern build up is now mainly complete, i just want to add some paint to the hard to get to places before the frames go in, i will do that next to prevent any damage occuring the white painted section is the steering gear flat, it will get a green deck before the longitudinals go back in
  13. Good evening everyone thank you for comments and likes day 34 box girders and crocodile clips the after peak has been fitted and stands up quite well on its own, however the more support i can give it the safer it is the box girders are now starting to line it all up, no glue has been used since the last post i have no intention of passing the forward engine room bulkhead for a while with intentions of staying with the after part of the build
  14. yes i found a rescaling chart the other day, i hope to try it out within the next few days
  15. good evening everyone this build seams to have attracted some attention, so i had better make a decent job of it, and finish it this year Day 32 engine room tween deck module and after peak been doing some garden work the last couple of days but yesterday i varnished 12 sheets of card on both sides to allow more cutting out personally i have found it easier to work away from the kit rather than on the build itself
