Tadeusz43
Everything posted by Tadeusz43
  1. Hallyard winches on windjamers, Passat and Krusenstern Tadeusz
  2. Hi, The Cornwall Model Boats offers big choice of ship model accessories in resonable prices. http://www.cornwallmodelboats.co.uk/ Tadeusz
  3. Hi, Corner show case As the number of my models continues to grow, it was necessary to find a place in my living room on their exposure. So the idea for a corner display case is a good solution. It will be a safe haven for the model Peter von Danzig, the ship of the fifteenth century, which was related with the city in which I live. She was a privateer of Hansa League during the war against Britain and France. She’s biggest conquest in 1473 it was cargo of the Burgundian galley "San Matteo” in it was triptych of the Last Judgment painted by Hans Memling. Material for display case Profiled slats of pine HDF boards white Furniture corner joints + screws Plexi (for reason of required bending it was ordered in specialized company) Two lamps + cable + power supply unit + switch Time for job - two dys Tadeusz
  4. Hi, I made display cases for my models. Our models built at the expense of many hours of work should last many years and enjoy the perfect eye look. To protect them from dust, which is the main enemy of these delicate structures and especially the rigging, place them in showcases. Such cabinets can do with your own hands. Several ways to implement them. The frame structure of aluminum profiles joined with aluminum blind rivets. The frame structure of wooden profiles glued and fastened with nails and screws. The frame structure of PCV angles with use of double face self-adhesive tape for joint it with plexi plates. The basis for showcases can be made from MDF board, plywood or wood boards. The cover can be made as the transparent plexi or the same material as the base. Lamps for lighting model can be installed in showcase cover. PVC angles Wooden profiles Metal fittings and legs Aluminium, PVC and wood strips Woodenstructure of display case Aluminium structure of display case PVC structure of display case Tadeusz
  5. Hi, Almost finished boat only small items photoetched are missing. Tadeusz
  6. Hi, Ship boats I made as epoxy and glass fiber laminate using fine glass fabric ( 25 g/sq. m and 150 g/sq. m.) . Laminated structure was made on wooden core covered with layer of paraffin. It was 4-5 layer of glass fabric with fine on the top. After full cure of epoxy light sanding was applied for better paint adhesion. Final painting with acrylic paint. Tadeusz
  7. Hi, The admiralty pattern anchors for the three polar ship I done a proven way. The arms and shank cut of aluminum was connected with use of centering pin and CA glue next grounded and sanded. Tadeusz
  8. Hi, Brace winches on windjamers Passat Kruzenstern (ex Padua) Tadeusz
  9. Hi, After a long break, I go back to modeling. Meantime, my workshop was twice flooded with water from a broken pipe fortunately there was no damage tools, machines and models. I am working on equipment today installed a fife rail, pin rails along the bulwark, windlass, pump and winch as also deckhouses, skylights and companionway. Tadeusz
  10. Hi B2, HMS Victory was constructed in 1700 ( launched in 1765 ). Tadeusz
  11. Hi, Hammock storage racks on various ships HMS Victory HMS Warrior HMS Gannet Jylland Tadeusz
  12. Hi, Models of block making machines in NMM Greenwich. Tadeusz
  13. Old ropewalk in Chatham. In Historic Dockyards in Chatham (UK) is 200-years old ropewalk still producing ropes with old machines. For visitors held demonstrations braiding hemp ropes with use of old methods.
  14. Old ropowalk in Chatham. In Historic Dockyards in Chatham (UK) is 200-years old ropewalk still producing ropes with old machines. For visitors held demonstrations braiding hemp ropes with use of old methods.
  15. The Bomb vessels The bomb vessels it was specific type of battle ships armed witch heavy mortars used for bombardment of enemy ships and land installations. From the Royal Naval Museum in Copenhagen. Tadeusz
  16. Hi, Karlskrona, southern Sweden was established as a base for the Swedish fleet in 1680 because in this area the sea does not freeze in winter. Many buildings have survived to our times but the area is still used by the Swedish Navy. Artilery Manor - artilery arsenal Curent view - the long building it is old rope walk
  17. Hi, Figurehead on my HMS Warrior comes with this set of figures Celtiberians warriors. Producer is HaT http://www.hat.com/ Tadeusz
  18. Hi, Because the sculpting is not my strong point problem of figurheads for my models I solve using commercial figurines with possible “face lifting”. It may be figures of knights and ancient warriors. I do not know what is figurehead on HMS Surprisie, the problem is if this is figure of a woman, no many this type figures are available on market. HMS Warrir - it was Roman warrior from commercial kit Golde Yacht - it was knight on horseback Tadeusz
  19. Hi, Thank you all for your kind words, I try to pull this topic further. Tadeusz
  20. Hi, Chemical blackening is the best solution. http://modelshipworld.com/index.php/topic/13869-whats-the-chemical-for-chemically-blackening/?hl=%2Bblackening+%2Bbrass Tadeusz
