Posts posted by vossiewulf
What that looked like when painted.
- mtaylor, Canute and CharlieZardoz
3
Hi.
Putting my 2 pence worth in...
I agree with the statement that INSTRUCTIONS are very important and there are a lot of new model ship suppliers trying real hard to do what's right.
Just to list a few.
http://www.marisstella.hr/marisstella_modeli.php
The guy is complaining about not understanding instructions, so let's send him to a site in solid Croatian
Those are some cool model offerings though, especially the galley/xebec with the built-up stern castle. If he offers English instructions there are some nice small ships there that could be good choices for the OP.
Actually speaking of that schooner I linked to above, what the heck kind of sail rig is that? I thought it was just a topsail schooner at first but the foremast is a semi-lateen mast, not a gaff, so it has left my limited knowledge of sailing rigs.
- Canute, mtaylor and Don Quixote
3
Sails are definitely an option and it's your option.
There's lots of choices and yes, many builders do put on sails. Go to the Kit Build area and search on "Victory"... there's all varieties of methods.
As a primer, go to the article database on masts and sails here: http://modelshipworldforum.com/ship-model-rigging-and-sails.php There's a primer by John Tilley. It is an old article so not all the links work, however.
Anyone interested in hobbies runs into this all the time - the solution is the Internet Archive's Wayback Machine. You just go back as far as you need to until you find snapshots with the information you want. I used it while reading that exact article a few weeks ago, had no issues finding good versions of all the sites and info he recommends.
Chuck Passaro's Syren (Model Shipways kit) has great plans and detailed instructions. Check out some of the builds here. Chuck is also a PM away for questions.
Russ
Plus he has a practicum also doesn't he?
Another recommendation would be Victory Models' Lady Nelson cutter. Only one mast's worth of rigging to deal with, but it's a mast with full shrouds and square yards and a gaff boom so it's representative of all the other masts you'll run into, excepting the not complicated differences between that and one with all square sails. That's about as easy as it gets, and in doing it you can understand all the ropes and standing rigging for that one mast in isolation. Then you can move to two masts and then three, now that you can see them as consisting of two or three units of that mast you now understand.
Also buy Rigging Period Ship Models and Masting and Rigging of English Ships of War 1625 - 1860, both of which come with lots and lots of clear diagrams and drawings and explanations of what everything does and why.
- mtaylor, pirozzi, Don Quixote and 4 others
7
I sent some mail to the guy who put together that presentation, will see if he answers. Matrim I wouldn't anticipate you could just point the tool at a bunch of plans and walk away, there would still be a degree of human input to make sure the plan is clean and marking locations of certain items before it could make an attempt to build at the very least.
Are you saying you've found the drawings are stretched somehow? I thought generally speaking the paper used for these plans was fairly heavy and would be resistant to something like that. Yes, that would be very difficult to correct.
Indeed as these plans dont have it.. (most of the plans posted in detail are missing something) though in this case that is less an attempt to deliberately lose something as a decision not made. Basically when I last looked at building on the original plans I had decided to taper after completing the stem and false keel under the perhaps mistaken idea that it would be easier.
Perhaps it would be better to mark the taper now and cut it accurately on all pieces..
Just in case here is a revised with the start of the taper marked with a red vertical line...I am cutting corners slightly by making it start just after the joint (in both cases) so if this is very wrong then please say!
Has anyone ever taken a run and automating this? We (and I mean human race) have thousands of these plans in a relatively consistent format. I see no impossible to overcome challenges in creating a tool that can output to formats importable by CAD and creative modelers (MAX etc.), by extracting the station frame curves and positioning them on a correct keel and generating a skinned/solid model. If wer can extract the station frames, we could easily tween the values between station frames to generate the intervening frames.
I'm not saying it would be easy, but I think it's doable, and it seems to me we have enough interested parties and groups that it might be worth doing - imagine there being a library of skinned and solid models with correct hull forms, wales, gunports, would have to draw the line at the head and the stern, too variable and complex. But still if we got that far, modelers, historians, games and movie people, all could access all of these sailing models for whatever purpose they need. And the processing would still require some human input to indicate the correct areas to scan for the curves and which is bow and which is stern, and marking the keel location and length and probably a couple other steps to prime the tool for each unique plan.
Only step I'm iffy on is automated generating of spline-based curves for the station frames, I'm not sure that I know of a product doing that, turning 2d drawings into vector/spline-based lines. I have some idea of companies I could ask who should be able to do it. But also I'll see if I can track this guy down, this was a proposal to do the exact same thing for old rocket parts.(FYI - that's a PDF). This is just the proposal, not clear he did it.
Anyone else know of existing tools/companies/researchers who might find this problem interesting?
Ship model kits which may or may not be based historical vessels
in Wood ship model kits
Well yes, we don't have good plans for much of anything prior to the 17th century, and even the 17th is highly spotty. So it's not just galleons, it's naos and race built galleons and carracks and cogs too. I recently bought the Victory Revenge. Is that exactly the ship Drake sailed in? Nope, of course not. But it's based on logical extrapolations of what hard info we do have, and I'm convinced that it is likely to be close enough that Drake would only need to make minor corrections to get it right.
And every kit manufacturer has a Santa Maria and usually Nina and Pinta too even though no one has any idea what the hell any of them looked like, we have even less info. Those models I wouldn't bother with since it's likely every single one of them is wildly wrong. Actually an amusing group build would be to collect every Santa Maria kit going back 40 years or so and have people build each of them and then compare.
I'm with whoever that was upthread who replied that kit manufacture falls in the toy and hobby industry and therefore bear no legal responsibility to get anything right, so when it comes to building kit's it's caveat emptor- you're responsible for doing some research to see if any particular kit represents a real ship and if so, whether it does so accurately.
Also remember that Absolute Historical Accuracy Disorder (AHAD), although very common among serious ship modelers, isn't universal. Lots of people just want to build something reasonably close that looks nice in a display case. It's not like your neighbor is likely to walk in and say hey those lift blocks are British style and totally wrong for your model, which is clearly a Temeraire-class French 74 built in the 1780s.
