Posts posted by vossiewulf
"BTW Rick what is up with these uneven and different on each side curves on the tops of the bulkhead strips?"
You may want to buy a small herd of goats before you've finished. The upper edge of the gunwale should run parallel to the deck - so in this case there should be a smooth curve for the full length of it. Looks to me as if the laser cutter had some sort of hiccup or maybe just a bit of a wobble, the gun ports either side of the dip actually look distorted slightly as well. Shouldn't be as much of a problem as your redo of those elbows however, When it gets planked just ensure you get a nice line with the top plank ignoring the wobble, the capping rail will conceal the dip nicely.
Next time you start to get that feeling of burning one of the more recalcitrant bits go ahead, just remember to make a good copy first!! I've got half a ships worth of junked items where it was a better idea to junk it rather than continue the fight but I've always either got a good copy or been able to reconstruct the bit from the outline from the blank that it was lasered from.
You're going to have a brilliant model when finished , plus this build will be pretty well the definitive manual for beginners building "Lady Nelson".
Rick
On the bulkhead strips, sigh, more things to fix, What confused me and kept me from doing something sooner is that if you look, you'll see that despite the unevenness that the bulkhead stanchions all have almost identical overhang on the strip so it looked purposeful. This material is thick enough to add pieces on top if needed, I can even reinforce with CF pins if necessary, so one way or another we can fix them.
So next step is laying out planking and first, John/Landlocked thanks for the links to Chuck's videos, that is indeed a pretty simple method. I think I'm still going to use one or more planes to at least do the tapering step he does with his xacto knife, I think I can do that faster and more accurately with a plane. I'm guessing Chuck started with building ships and hasn't done much furniture work and just isn't that experienced with planes so he defaults to a perfectly workable and familiar to him method that isn't much slower. And if I find I have squirrely stock with unpredictable grain I'll put down the planes and pick up the knife for that step too.
I'm surprised he doesn't bother with soaking at all, and I'm wondering how he handles bends more severe than what he needs to do here, since anything more than what he did and that stock is breaking. Since he seems against soaking I have to assume he does it in more than one step, progressively increasing the bend.
Since I don't have more severe bends I'll give that a try, but I may soak also - there is no time wasted in putting stock into water a couple hours ahead of time and if anything raising the grain, at least on the final planking, is a benefit for sanding to a final surface. Long time ago I used to make very expensive corporate conference tables and one of the steps of preparing the tops was wetting down the surface to raise the grain before final sanding.
But as noted I'll try it without soaking and if it's really not needed, it's not needed.
Other difference is for the sake of peace and quiet I'm going to forego the screaming hair dryer in favor of my plank bender, at least if that works. The key point there is to raise the piece to bending temp and then let it cool again, doesn't matter how you heat it.
The taper and bevel technique is pretty much what I was intending to do. With the bevel I actually don't think he explained it well, he only explains the convex curve where the inside of the plank needs to be smaller than the face - he left out concave (or maybe I couldn't hear it) where the converse is true and the plank face will need to be smaller. I think of planks this way from the front view, with the divisions between planks being radii of curves extending from the curve's centerpoint, which is what they need to be if they're going to fit side by side correctly, and that means wherever planking is covering a curved surface the plank edges need to be beveled.
Those videos don't show how he decided how much the planks have to taper, so I went ahead with how I intended to do it, and need some feedback as to whether this looks correct. Since this hull is very simple until we get to the stern, on the bow I decided to just let the planks terminate naturally into the stem and keep tapering the rest.
I started with figuring out how many are needed at midships by making a piece of paper the correct length, and then dividing it by the 3/16" width of the planking, turned out to be exactly 14.
So then I made a set of parallel lines on paper into 14 divisions at 3/32" (less than the smallest anticipated taper) to use to draw the divisions on the following paper strips. Here is the first strip being marked.
And then transferring to builkheads.
Long term this is overkill, but I'm also sketching in the lines as I go as it's a totally unambiguous reality check as to whether my cunning plan is working out or not.
Here we're at the forward bulkhead where planks start terminating into the stem. Note that if you're going to do ad-hoc divisions like I am that they need to be straight and perfectly parallel to the bulkheads from the side view like we see here. The first vertical line is the point at which the first plank ends. The second is after two more end and I'm just tapering 11 from there.
Marking the paper strip for the second line, with just 11 divisions.
And transferred marks to hull.
From there I used Mk.I Eyeball to draw them the rest of the way. It's logical and simple, but it looks kind of straight from the side view, not exactly the most graceful lines. However, anything I do to make the lines more graceful is going to also be more complicated with drop planks in the middle required.
Please let me know what you folks think, if I need to do it differently we'll erase all this and start over.
Yes I know this detail isn't necessarily required for inner planking, but it's also an exact dry run of what I will need to do for the final planking where high quality is required, so I can't think of cases where I won't do it this way and work out everything I need to know for the final planking at this point.
Stopping for the moment to catch up with where I am and show the Nightmare on Fashion Piece Street.
So anyway, back a couple days ago we had left the starboard bulkhead strip to dry in situ prior to gluing to the ship, here he is ready to be glued on. Not showing that process as it was the same as the other side.
Here checking symmetry, looks reasonable and the overhang at the stern was different on the two strips by only about 1/64" which means the two sides are pretty close to identical.
And I did do better this time on ripples, basically none worth mentioning. The one hard turn as we go to the stern should disappear on its own when I remove the stanchion thing.
So here is where I made the fateful decision that the perfectly-painted fashion pieces were unacceptable for being too orange. We don't see pics, but the first effort of course was just overpainting, both are acrylics right? Nope, Tamiya didn't react well at all over Admiralty and really the only choice was to strip them down.
Here we are blithely sliding down into the pits of modeling hell.
The fact that afterward the pieces looked exactly like compressed cat vomit should also have been some kind of indicator that we were traveling through the valley of model death.
And here they are ready to go. One way I try to make going backward less painful is improve it in the process. Even when I want to paint the first time the pieces felt too heavy to me, so I narrowed them all down until I was happy and then rounded them over. Considering their position leaving them with hard edges didn't make sense to me.
So now that everything is super ready to go we start painting and...
Holy crap how is that still happening with them sanded down like that??? I'm already removing this disaster.
This time around I removed the paint with an abrasive acrylic rod held in a collet thingy held in my rotary tool. This is a pretty rough grit so it went pretty quick and they can get down into corners.
This is after that operation.
I then removed the rest and cleaned thoroughly with rubbing alcohol to ensure nothing was left on the pieces. We don't have pics here because this is where total madness set it. I painted one stroke of the Tamiya red and waited, and watched it do the same exact thing as before.
First I had to walk away for a while because all I could thing about was ripping off the fashion pieces and making a very small bonfire with them in my driveway.
Once I got over that I came back, but I was totally in "ok I've had just about enough of this crap" zone, so to solve this once and for all I coated all of them in thin super glue. Once dried I had to resand all of them for like the 14th time. Eventually they were ready and when painted the Tamiya red worked fine and here we are.
Only difference between this and a previous similar pic is they're somewhat redder. Well that and many hours and steps and an urge to burn fashion pieces.
What is weirder about the fashion pieces was I'd first noticed the Admiraly-Tamiya problem on the stern fascia, and I had stripped that down and sanded it a bit and the Tamiya went over it no problem. I have no idea why the fashion pieces were still able to screw up the Tamiya paint until I sealed them in super glue prison.
Here it is with Tamiya color, it needs to dry overnight then it will get sanded lightly with 2000 grit and then a few more coats, surface still too uneven.
Next comes planking, but before I could do that I needed to finish my Mk.I Advanced Rope-Powered Keelalator, which I did.
If you can figure out how it works at this point you should be tested for wizardy.
I needed something very strong and dependable to grip the keel plate through the deck grate holes, but still be detachable later even though that area was going to become inaccessible after planking. This was the result, a U-shaped piece where each arm goes in a grate hole grabs each side of the hull plate firmly and the bottom of the U bottoms out on the deck, so we have a pretty good mechanical hold. We just need to make sure it stays there.
Here it is in place, I've just drilled the four holes it needs and beveled the edges with a countersink.
And this is what will hold it in place: black bowstring. The reason for using bowstring is that one strand is about strong enough to hang your car off of, it's very supple and flexible, and most importantly, it does.not.stretch. At all. Negative on that stretch attempt, Ghostrider.
That makes it very good for jig applications like this and is why I have four types of bowstring in my closet even though I don't own any bows.
Here is in in top view, and indeed parts of the boat itself will fail well before the Mk.I ARPK lets go.
And all of that was for this reason- so I could now flip it upside down and hold it correctly in my engraver's block.
And here is how it will be in planking, rotated toward me. Since the engraver's block's top half rotates when you allow it to, I can put on one plank on this side and then just spin it around and be in the same basic position for the other side.
I now am going outside to sacrifice a goat to the Ship Modeling Gods and ask that planking go somewhat better than this last phase did. Um... hmm.... anyone have a goat handy?
Hey Vossie at least you didn't have your decking laid before you had the "do over" - it's sheer hell when you have a nice clean deck with a spot of paint on it (speaking from experience).
Rick
Ok I'm trying not to think about how much fun that must have been.
Hi Jay,
I've just read your build from the beginning and want to congratulate you on what you've achieved thus far. At this pace and level of quality work, your really going to end up with a beautiful ship.
You've made a couple of references to Chuck's Cheerful. On page 45-46 (or so) of the build he shows how to make thimbles, which you mentioned was of interest. It took me a bit of practice but I'm now able to make them in virtually any size. Also, early on you mentioned shooting boards and plank benders. Chuck has a video of a planking technique which obviates the need for either of those. Here's the links:
Video 1 - http://modelshipworld.com/index.php/topic/8131-hm-cutter-cheerful-1806-148-scale-by-chuck/page-16
Video 2 - http://modelshipworld.com/index.php/topic/8131-hm-cutter-cheerful-1806-148-scale-by-chuck/page-17
I will be following along to watch the remainder of the build and am really looking forward to it.
Best,
John
Thanks John! I'll watch those before starting the planking.
I did buy some brass thimbles at Modeling Timbers, but I'd prefer to make them long run.
Another good option is Grobet, they're an American company with files of very nearly the quality of GV. I own and use lots of Grobet files too.
Search for riffler files or file sets in their storefront on Amazon.
Hi- very nice build so far. I've been following along. I've been using Tamiya red for my build and it's been working out for me. It is very thin right out of the jar so I do not even thin it before using. I use several coats and sand before the final coats. I'm also a big fan of elmers wood glue. It's easy to clean up and rip off pieces when needed, which is often for me!
Steve
Thanks, good to know someone else likes that color. I still thin it a bit but I agree it's pretty close to brush consistency out of the bottle. I try for zero brush marks, I find going a tad thinner than that, making them glaze coats, gets me the flattest surface. Downside is 5-10 coats instead of two, but they also dry extremely quickly.
Hi Jay. I am glad I found your build log and now have a real name to call you. You are doing a great job, even with the redos. You should put a link to this log in your signature, so others can find it too. I love those riffler files you use. I have seen other builders use similar ones too, so they are on my list of tools to get.
Hey Tom, thanks for the kind words. I keep forgetting the sig thing I'll see if I can add it when I post the latest pics.
WRT files, I remember thinking I was being really excessive buying a set that expensive, and then 30 minutes into first use it became "I'm a complete jerk for not buying these sooner". The quality difference is at its greatest on metal, these are just wonderful for shaping brass.
Do not forget that GV has a complete line of files, all of which are better than you get at the hardware store, and their second-quality files are pretty reasonable and will still make you very happy.
Check out needle file sets here. You want cut 2 to start with, it's a good general purpose cut. You can get a set of 6 of their best-quality needle files in cut 2 for $42. Down at the bottom they have sets of 12 second-quality files in two sizes for $80 and $60 respectively. And even their economy set of 6 at $19 is better than what the hobby stores sell, there really is no reason NOT to buy a set of those, you use them for nastier work and save your nice files for precision work.
Also look at the larger riffler file size, the Habilis files, and the machinist's files, all have tools extremely applicable to this hobby and are not too expensive.
- usedtosail, BANYAN, Canute and 1 other
- 4
Yes, I am. Unfortunately I have not gotten started though because I decided I couldn't accept the Admiralty color on the stern, even the bright red was actually orange. So I stripped it off, which itself took a while and was very messy, and then got on one of the runs where nothing works and hours were spent just getting back to square zero. Well not quite, I did finally get the new color on the pieces, I'm using straight up Tamiya red about same value and saturation as the Admiralty color but several notches toward red.
Too annoyed to post pics now but I did take them, will post them tomorrow so everyone can follow along while I repeatedly punch myself in the face.
It's basically example # 18 quintillion or something to know exactly WTF you are doing before you do it. I went ahead not being 100% sure of a color, and as a direct result found myself in a position with paint on and pieces less accessible than they were and needing to remove that color and paint over. Which itself went badly requiring two tries. Gigantic time sink. If you're wondering, having to strip the first was one because Tamiya and Admiralty acrylics don't like each other. And that should have been a giant waving flag that I was descending into the valley of modeling madness.
BTW, only issue with the Admiralty paints was the color, otherwise they're excellent paints for ships and brush paint extremely well properly thinned. They come extremely thick, almost like a concentrate so the small bottle is going to cover a quite large area.
- Canute, mtaylor, popeye the sailor and 2 others
- 5
Not sure I understand the crisis, but that looks like a Dr.I aileron to me. Very nice job leaping into unknown territory and making it across successfully.
And if you're interested, here's an interesting a thread on the Aerodrome from 2001 discussing the early Dr. I wing failures that killed Gontermann and Pastoris and very nearly Lothar Von Richthofen also. But the best summarization comes from my friend Dan-San Abbott who has passed away now. The reason I bring it up is that the main cause was weak attachment of the ailerons leading to flutter, which is a type of positive-reinforcement resonance specific to aerodynamics that's been the cause of death of many a test pilot.
Gentlemen:
The wing failures occurred when the early production Fok.DR.I aircraft were put into a turn. The ailerons had an over long balance which started to flutter as it rolled into a turn. As the flutter progressed it caused a structural failure in the aileron spar. The rib to aileron spar joint was not adequately reinforced. The fabric was tacked to the ribs. When the aileron spar failed it caused the fabric to rip away from the wing structure thus resulting in a total failure of the upper wing.
The corrective action was reduce the chord of the aileron balance, to reinforce the ribs with battens, add a box rib at the end of the aileron cut-out, larger rein-forcements to the rib-aileron spar joint, and stitch the fabric to the ribs. The chord was increased from 980mm to 1000mm on all three wings. There was not a failure of the upper wing main spar. This is just skimming over the corrective action details.Blue skies,
Dan-San- Nirvana, thibaultron, mtaylor and 3 others
- 6
I finished the prep work after fixing the bulwarks because of the stability problem myself, even then I broke one of the inner elbows off the deck once. The fascia should be flat in the vertical plane with a reasonable curve horizontally. I do recall that it took a bit of time/work shaping the elbows to get a proper fit - I also made three ( I think) fascias before I got the fit right. These niggles are sent to try us!
Rick
I need to make a "thanks Rick" macro ;-) That's basically what I was seeing. And although it would have been a little tricky because of them resonating, I think I could have at least reasonably prepared the joint ahead of time as mine were pinned to the deck.
I got the other bulwark strip on and finished painting the fascia, then spent some time making an Advanced Rope-Powered Keelalator that is a basically a U-shaped construction, the arms of which reach down into the midships grate openings to grip the keel plate that will be locked down by a looping line running through four holes in the keel plate and over stanchions on the Keelalator.
The reason is so I can flip the ship upside down and have it be held firmly in my engraver's block.for planking, and the line is because I of course can't glue or screw it as the planking will make that attachment inaccessible. So the line will function to hold it firmly and when done I can cut it and remove the ARPK.
I'll show the pics after tomorrow's session.
Nah, I've already acknowledged that this is something I shouldn't do that with, a zillion hidden dangers that even an experienced person can easily miss.I was actually in two minds about posting as I know you like to work these things out yourself. However you had already mentioned ironing out ripples so I went ahead with my own experience in this area.
Rick
And in any case, I'll never react negatively to anyone who is trying to help.
And I have a question I thought the fascia would be flat, but the angle of the outer fashion pieces seems to require a curve and I'm wishing now I totally prepared this joint before now, I didn't because I thought it would be better to wait until it was stabilized by attaching the outer bulkhead strips. Poor decision.
- mtaylor, Canute and popeye the sailor
- 3
Looking good Vossie - I knocked the bulkhead extensions off at this stage then planked the inner side of the gunwales which smoothed out some minor ripples at the forward gun ports. Obviously all the planking was curved to shape first and gun ports were planked over then re-opened once planking was dry.
Rick
Thanks Rick, you're now anticipating my questions so I don't have to ask them I was thinking about that option too. that may very well be what I do this evening.
Couple more...
Best tack cloth I have found.
1. Lasts forever as long as sealed in plastic bag.
2. Reusable many many times.
3. Most important, leaves no nasty sticky residue on hands or work.
This filler putty is made for plastic modelers and is not appropriate for filling large areas, but it's one I still use often on wood. It's:
1. Very very smooth.
2. Does not stick to fingers and spatulas nearly as much as say Elmer's or Famo.
3. Dries at least as fast as Elmer's/Famo.
4. Water cleanup.
- captainbob, Jack12477, WackoWolf and 7 others
- 10
Solid wood. This time I mailed to a different mail address. Hopefully that will help. I´m sure I can fin strips at the model hobby store but like you say, annoying.
I have started on the ailerons instead, soldering. Going well so far. But I like to finish one subgroup before starting on the next one so it still bothers me bit, to have half and three quarter finished parts laying around.
The hell with email addresses, call their customer service line and tell them you've been waiting weeks for an answer and you're not going to drop this call until you speak to someone who can help you. And good luck
- mtaylor, thibaultron, Canute and 3 others
- 6
I needed to make a decision so I was mixing last night using the Admiralty paints, I settled on a 10-3 ratio of their Eye-Blinding Super Red (Ensign Red) and their Red Ochre.
It's still more saturated than I would use on a realistic finish, but since the stern/inner bulkheads are about the only surfaces being painted on this model I'm already totally violating realistic color, and this color should provide a reasonably striking contrast with the cocobolo and boxwood and holly that I'm using.
I have mailed model shipways twice about a replacement part for the middle wing but have not received any part or reply yet. First mail was 3 jan, second mailed about 10 days ago. I´ll try a third time before I give up and scratch build a new part.
Looks great, and that's a real bummer when you're on a roll and then forced to stop because of a problem not of your causing.
Are the strips solid or plywood?
- Nirvana, mtaylor, thibaultron and 2 others
- 5
So I am really happy with what I did last night, just leaving it to dry on the ship. This is what we have this evening:
It had both the sheer and top line curves exactly. The fit on the ship was perfect, and therefore gluing was extremely easy and not rushed at all.
I used yellow glue and clamps only at the bow, this was the only place where clamps were needed to refine the fit, and also would required adjustment hence the yellow glue.
We started here with just a tiny amount of glue in the stem, very carefully applied so it wouldn't squeeze to the other side and block the fit of the second strip. I also was very careful ensuring the bulkhead strip only went into the stem piece half way, again so there would be room for the other one, and in fact this was the fiddly part that made me opt for yellow glue here to allow me time to get it just right.
I then added glue for the first couple bow sections, and clamped up top plus I used some Frog uber mongo grip multi-surface tape to pull down the bottom edges that really didn't want to follow that vertical curve
The rest of it was glued on with CA with finger clamping, one bulkhead section at a time so again I didn't have to rush and could be careful and make sure I added the right amount of glue where I wanted it for each section - we have to remember the bulkhead stanchions will be removed later so we want minimum glue there, just enough to force it to shape.
I was happily gluing my way down when I realized I had gotten so excited about the perfect fit that I'd forgotten that I didn't like my fashion pieces' color and needed to stop, remix something better, and get them painted first.
First why not make them better, so buzzed over them with wet 2000 grit paper to take them up a notch in smoothness.
The mix I decided on was 10 to 3, Admiralty Hippy Bus Acid Trip Red (Ensign Red) and Admiralty Red Ochre. As usual with brush painting I thinned the paint quite a bit and added four thin glaze coats until I had the color buildup I wanted. I always end up with a much smoother finish that way
Then I continued gluing the port bulkhead strip. Happiness is a one-finger glue joint, and the fit is perfect there with the strip overhanding the outer fashion piece by only 1/64" or so.
Inner glue line looks good.
Only a teensy bit of glue to clean up on top, and none on the bottom, but it's glued plenty firmly.
Afterward this is what we have, and I couldn't be happier with it.
Fit is very good on bottom edge too which worried me plus it's perfect fitting into the stem.
There are a few ripples, but within easily removable tolerance. However I'm not going to smooth out those ripples now, since most are caused by a bulkhead stanchion pushing out a bit too far so if I remove those ripples now, they'll come back reversed and even harder to remove when the stanchions go away.
I'm thinking of pulling most of the stanchions prior to planking the bulkhead strip, and then I could fully smooth out the ripples before doing that planking so the planks don't inherit said ripples.
Next was to do the same forming step for the starboard side strip so after soaking it here we go. First although it worked out I wasn't happy with the clamping of those Amati squeeze clamps I used on the other side, or more accurately that they don't maintain the pressure. At first it feels like they're pressing quite hard, but when I was de-clamping that side I found half of them had come loose. So doubt I will be using those except for CA clamping where they don't need to hold long term.
So switched to baby C-clamps (reminder: need more baby C-clamps). The first stanchion having a point facing inward wasn't cooperating, so I cut a flat in it.
And here is what I mean about clamping outward, the strip didn't want to follow the right curve going into the stem piece so I'm using this fly-tying hackle plier to clamp it outwards against the caul curve.
All clamped, C-clamps are clamping inward, all the small clamps outward. I did a better job with this one than other side, there are going to be almost no ripples here.
Since my stern fascia piece will be painted one side and planked the other I didn't want to use the walnut piece because the open grain would need filling, so I made a replacement out of basswood. Which made me wonder why a Euro kit made in Europe had an entire sheet of pieces that are exactly 1/32" thick, but it made it easier for me.
I cleaned up the inner part with rotary tool, then filled all those edges with my superfine Perfect Plastic Putty. It's made for plastic modelers and filling small spaces so it's not a good option for giant fills, but it's 1) amazingly smooth, 2) water-based, 3) dries at least as quickly as Famo or Elmer's, and 4) doesn't stick to fingers and spreaders nearly as much as the other two. I'm going to post it over in my tools thread, I think everyone should have this in their tool arsenal.
After the filler dried I sanded everything, and gave it a few coats of clear flat sanding sealer. That needs to dry along with the starboard bulkhead strip, so called it a night.
- BANYAN, popeye the sailor, Canute and 2 others
- 5
I did have problems with a slight bowing at the gun ports however once I'd started to plank this area the planking did pull it all back into line.
Rick
You're braver than me, when I saw the way they were bending I felt like I had to fix that immediately.
I prefer the bending technique you have used over the use of a heat source/plank bender although, sometimes the shape does resile a little and a further over bending may be required to allow for it. I also find that for thinner pieces I only have to soak for about 20 minutes.
Nice progress, the planks should lay along this with very little pressure.
cheers
Pat
I may end up with that also, but remember this is a first build and I'll want to experiment with planking techniques to find the one I prefer. I also already bought a plankling bender so it's going to get used at least once
The only technique I'm sure I don't want to use is those crimping tools, the idea of partially crushing wood on one side to make the other bend the way you want is not something that appeals to me, even if it is effective.
Thanks so much Robert.
OK vossiewulf, you saved me some work. When I got home tonight I thought I'd give your method a try. I had nothing to loose since I was going to remake the topmasts anyway. I cut off the round sections, drilled holes in a piece of square stock and the topmasts for a piece of dowel, filed in the tenons at the top of the new square section and glued them on. I made sure the square section at the top lined up to the square section at the bottom and the new part was lined up lengthwise with the rest of the mast.
Overall, I think they came out pretty well. The joint is hard to see and will be covered by the topmast trestle and cross trees, and this part will be painted black to boot. I think they will be pretty strong with the size dowel I used, too. Thanks for the advice.
Beautiful! Both how they look and that you got there with the shortest route possible. Glad I could help
Same thing exists in pretty much every modeling field, in WWI aviation there are death struggles over the "real" color of British PC10 and PC12 brown/khaki that was painted overall on all British aircraft. And it's basically impossible, first because different batches drifted some, and then it also rapidly faded due to exposure to sun and rain.
So really, the color it was painted with can't be determined with total exactness, and then it faded once applied such that literally every single day that aircraft was a slightly different color than it was yesterday.
I fully understand those issues and am not looking for a single color but a range- I know the hue range of PC10, and also its saturation range. And names of colors don't help at all here, you have to generate numbers - I'm talking I know the colors in a Hue/Saturation/Lightness (HSL) model typically used in Photoshop.
If I had to guess, the red gunport sill/bulkhead color, if they were using their "real" red vs red ochre, would probably be an HSL range (on a 0-255 scale with zero being pure red) of H:3-8, S: 90-120, L: 180-200. Does that sound correct to you Frankie?
Thanks Welfack for the GV links.
For the broader goup, all of my needle/riffler files are either Grobet or Gardon-Vallorbe. I can't recommend them enough, all I can say is the performance differential between these and hobby store versions easily justifies the cost, and they'll become tools that someone is going to have to pry from your cold dead hands if they want them.
- thibaultron, mtaylor, Canute and 5 others
- 8
"I'm good with this, although I look forward to doing a ship where the keel is correctly left off until after planking as cutting those rabbets will be trivial in comparison to this little bit of micro-surgery."
I've seen a couple of builds where instructions recommend fitting keel before planking - the builder has ignored this, cut the rabbet, planked first and second layer then cut a groove to take the full keel. Worked very well as long as they had a very steady hand for the last operation.
Rick
Hmm would have to see that as I'm not sure why that would take a steadier hand than what was required for what I just did, at least the rotary tool part, and also am thinking there should be a way to make a fence for a rotary tool with a router base to follow.
Anyway, thanks for continuing to look in Rick, all the advice and help is appreciated.
To be a little less terse, I suggest starting with raw sienna and white, and have a mild red and a mild yellow like Naples yellow on hand to tweak the color. According to what I've seen, it should be very slightly redder than the pure tan you'll get from raw sienna. The yellow is on hand just in case you go too red but can still save it with a little yellow.
- mtaylor, thibaultron and Canute
- 3
Thanks again Rick, that's what I'll do then. And yes inner stern faces and bulwarks will be painted, one of the few places I'm sure I'm going to paint. You saw I already painted the fashion pieces with red ochre from Admiralty and come to think of it I need to stop and address that first, since that seems just too orange and would blend in too much with the overall mostly browns this thing is going to be. I want the red to be a point of contrast so I need to mix a red I can live with and repaint the fashion pieces that color. But it will be somewhere between red ochre and the eye-blinding pure Admiraly Ensign Red.
So first this evening I finished the rabbet on the port side, I did a bit better this time and I worked it a bit longer in practice for doing the final planking rabbets that need to be dead on.
Following your suggestion I soaked the bullwark strips in warm water for about an hour and then test-fitted, no pics as have to move quickly bending drying wood. I found there was a problem I should have anticipated, it wants to bend too much at the gunports where there is much less wood and not enough where there aren't gunports. So I was going to need to clamp both ways, clamping in against the bulkhead stanchions and also clamp out the too-much bends at the gunports.
So I decided to make a caul, that would let me do both. So I went and looked at my scrap plywood and couldn't find the 1/2" I wanted but found something better, a warped 1/4" piece. The warp would help it follow the deck sheer of this little ship, and I could just CA glue two pieces together to get my 1/2" piece.
Traced the pattern. The yellow tape is Frog delicate surface masking tape that works great for taping things on plans, it holds quite well while coming off without doing any damage. And it still works well for masking, at least straight lines.
Glued pattern trying to use glue only on the waste side, so theoretically the paper mostly just falls off after you're done cutting.
I put in a couple of flats in case I needed heavier clamping.
Slightly concave and that is perfect for a caul, just clamping the center will generate some clamping pressure across the whole strip.
This is a final dress rehearsal dry fit. The caul worked well in that I could clamp it fully into the correct line. However, I found I had to move much more quickly than I like to when gluing something very important like this, and even though the top view line is perfect, I wasn't sure wheter it was aligned vertically exactly as I couldn't see the bottom line in some places.
So instead of moving ahead with gluing this, I decided to leave it clamped like this overnight to dry and set to this shape. That should mean I can glue it without the caul and just use normal clamps and I won't need to move as quickly.
So I know this method will work, but it's more complicated than I think it should be, so with the other one I'm going to try my plank bender. And that will be tomorrow, since I also had to do some other things and didn't have much time.
- tkay11, popeye the sailor, BANYAN and 2 others
- 5
Rick is there any reason not to add the stern fascia after adding the upper bulkhead strips? As far as I can see just prevents you from letting deck planking run long and trim later, and I don't see that as a big issue since I plan to add waterways and to toggle in the deck planks. I hate the fashion pieces hanging out in space begging to be broken, adding the fascia would stabilize the inner ones until we add the counter after planking.
Ancre Publications
in Traders, Dealers, Buying or Selling anything? - Discuss New Products and Ship Model Goodies here as well!!
Also remember Abe Books, which pulls together the stock of a zillion smaller booksellers. I bought my copy of Boudriot's French frigates book there at a reasonable price, and they had about 25 listed in several different printings and covers. I got the limited edition leather bound with nice paper because for some reason it wasn't more expensive than the non-special ones, and very happy I did so, paper and printing quality is as good as it gets.
