Also, after discussions with Bob Hunt, I removed the primer from the open area on the starboard side.  I was not planning on leaving the primer on the exposed framework, I just did not like the look of the raw exposed MDF material that was supplied with the kit.  I suppose I could have attempted to recreate the frames using some hard wood, but I don't currently own the skills needed to transfer the information from the drawing into software to create the proper shape.
Also, I could use some assistance with a necessary modification to the height of the bulwark.  I need to add another row of planking so that I can frame the gun ports.  When using a test gun and carriage, the barrel comes very close to the top of the bulwark as it is currently.  I am not sure how to proceeed with the adding of "stanchions" to provide the support for an additional row of planking.  And second, I am unclear how to get the proper measurements for the gun port openings transferred from the plans to the model.
Here is an example from the practicum showing the need to add another row of planking, but I could not find instructions on how to lay out the stanchions or where they actually needed to go.
Jeff
Edited by jdbradford
Current Build:       Model Shipways MS2015 - Fair American Kit bash
Previous Build:     J-Class Endeavor
Jeff:  Are you sure the cannon is in proper scale?  Many kits have parts that are grossly wrong scale-wise.  The practicum suggests adding another bulwark plank, which you can do.  But realize it will change the sheer profile and other relationships on the ship.  If the gun is out of scale, replacing the cannons may be the better option.  If you plan to add another plank, lay out the gun port  locations (the plans should help you locate these in relationship to another part of the model; ( 6 mm aft of the aft edge of bulkhead #6 as an example).  Lay out the framing and the new stanchions for the gun ports.  Then add a stanchion next to each bulkhead between the ports and all the way to the bow and the stern, so the plank has support between each port also.  Hope this helps
Jeff, both of my models so far have had a false deck, but for pretty much all my planking (both hull and deck) I just used regular wood glue and held the planks in place by hand for 60 seconds or so until they would stay on their own.
The trick (for me anyway) is to put a very thin coat of glue on the back of the plank, then let that tack up slightly while I'm applying the glue to the surface the plank will bond to.  Then put the plank on and apply firm pressure, and it grabs almost like fast CA, although without the permanence, in that I could pull it off and relocate it if I didn't wait too long.
Not sure that will work for you on your bulkheads, but that's the system I used for my first planking of the hull, everywhere except where the most extreme bends were, and for every single plank on the deck.
You could also try using the pin collar clamp things that I got from MicroMark - http://www.micromark.com/pin-collar-set,9549.html
They should work right up to the next to last plank.  I haven't yet found them anywhere else, but they are quite useful in my opinion.
Jeff, I replaced the kit carriages with appropriately sized carriage kits from The Lumberyard (www.dlumberyard,com). They are better wood. You might also look at Chuck's (Syren) nice carriage kits to see if any are sized right.
Bob
Hi Jeff -
I went with the low budget alternative - I removed the "axles" and glued the wheels directly to the carriages.  It was good enough for me.  You might try that approach and if you are not happy with the result, then pursue the option of buying better carriages.  Good luck.
<<Gary>>
p.s.  Something to be very cautious about - small changes in carriage / wheel dimensions can greatly affect the position of the cannon barrel relative to the gun port.  I found myself sanding off the bottoms of front wheels to get the cannon barrels properly positioned.  You need to do a LOT of test fitting as you proceed to build your cannons.
Edited by GaryKap
current build: SYREN
nearly done:  Fair American, Benjamin W. Latham
future builds:  Emma C. Berry
completed builds:  Rattlesnake, Newsboy, Sultana
When the axles broke off both with and without wheels, I did glue the pieces directly back to the carriages.  So far, I have finished 7 carriages and they look okay.  I may look at ordering replacements from one of those places.  But, I am not sure what size I would need to order.  I read on Captain Jerry's Fair American build that the plans were actually something like 1:55 instead of 1:48.  Any thoughts on what size to order?
Jeff
Jeff -
You might want to contact Chuck Passaro at Syren Ship Model Company and ask him if he has a gun carriage kit that would work for you.  Give him as many dimensions as you can and tell him what you want to do.  Decide whether you want to use the brass cannon barrels supplied with the kit or purchase new ones to go with the carriages.
While you are at it, you might consider the additional blocks you will need to rig the cannons.  (four per gun) and order these at the same time.  Other items you might consider ordering are the shroud cleats (I found these difficult to make on my own), and also his wooden cleats.
So here I am - spending your money for you.  Well, good luck and please keep us informed of your progress.
<<Gary>>
I finished putting together the carriages.  I am using one to test the current Bulkhead height so I can see if I need to add an extra plank.
It looks like I need another row.
Here are the carriages.  They turned out fair, the quality is lacking and if I want to rig them, I will need to order more blocks.
Jeff
My powder monkey stole the quoin.  And, the gunner is trying to hit that ship way out there. LOL
The practicum does not show much on the building of these.  I looked at the drawing in the book provided by MS, but they reference a drawing on the plan that I do not see.
Thanks,
Jeff
Greetings jd...
I am on the bell lap with my FA and have encountered the same challenges with the gun carriages. To begin with, I did not raise the bulwarks as, evidently, your practicum advised. I built mine per the drawings because I believe that was the right way to do it. I modified the carriages so that they would fit the gun ports - not the other way around. Yes, I had to glue the trucks to the carriages as Gary suggested to you. In addition, I deepened the trunion notches so that the barrels would sit slightly lower in the carriages and I set the quoins so that the barrel angle was closer to level instead of pointing skyward. Finally, I lightly sanded the front trucks so that the front of the carriages would sit a little lower. The net result was that the guns are properly framed in the gun ports, and the ports are sized per the drawings. In my opinion, there is no need to buy different gun carriages (which may present other challenges) or to raise the bulkhead elevation by adding another plank. Frankly, I am surprised a practicum would even recommend bastardizing the model in that way when other options exist.
wq3296
Greetings jd...
I forgot to mention: I used brass rod for the gun trunions. The rod I used had a slightly smaller dia. than the dowel provided in the kit. This also helps to lower the gun in the carriage. You can also trim the front carriage bulkhead to further flatten the angle of the gun. If you use the brass rod, the guns can be left in natural brass so they can "patina" naturally, which is what I did. I always leave brass guns natural, unless there is a reason (gun size, period correctness, etc.) to paint them black.
wq3296
Jeff - your carriages don't look bad to me.  One advantage to doing the gun carriage rigging is that it hides most of the "adjustment" that might be needed to the front trucks.  I think I used 1/8 inch blocks for this.  And I will remind you, the kit includes tiny brass handles for the quoins.  To make mine, I cut wedges from a strip of mahogany 1/8" x 1/16" and finished them with wipe on poly.  If you do need to deepen the trunion notches as wq3296 and I did, the cap squares will mask this nicely.  I used the brass rod that came with the kit for my trunions, and finished the guns with brass darkening solution that I purchased at a local antique store.  But they also look handsome left in natural brass.
<<Gary>>
I have begun to deepen the trunion notches, and even then the gun would have to point down some below the level of the horizon to clear the top of the gunport.  I will try to post some pictures when I get back home this evening.
If I end up adding 1 row of planking to the model, my main question is what to do about the stem area.
Thanks,
Jeff
Greetings jd...
Well, perhaps you haven't removed enough material yet (Gary, feel free to jump in) and you might want to swap out your dowel trunions for brass rod, as has been suggested. Also, see message #52 above for other mods that might help you out. All I can say is that you can make it work without adding to the bulwark height. I checked my guns again, and the muzzles all have an upward, albeit slight, angle after all is said and done. In my opinion, you may create more problems for yourself by adding an additional plank. Just snuggle those guns down as low into the carriages as possible.
wq3296
Okay, I will continue to work on the carriage some more as I test.  I am using the brass rod (look at the top pick showing the test cannon) that comes with the kit.  I do not see any dowels in the kit small enough.  I had some fairly small dowel in my wood pile, but I spent way too much time trying to sand down the diameter to fit the cannon.  The dowel would need to be about the diameter of a round toothpick to fit.
Jeff
Okay, I got my gun ports framed and the carriages sanded down.  I have not cut the brass rod for the trunnions yet, but it is looking like I can get by without adding another row of planking.
I have sanded down the interior part of the bulwark bulkheads in preparation for planking.
Jeff
After reading many of the other build logs on this great site, I have found myself to be amiss in thanking everyone for the likes and the kind helpful words in regards to my build.  As I move along to the next steps I look forward to the great advice and tips from you folks.
Jeff
