HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
Greetings,
My next step is to measure and mark the positions of the stanchion and jack stand bases.
Cheers,
Tim
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
I decided to use my miniature egg beater style hand drill because it gives me precise speed and depth control.  I used a fine point Sharpie to mark 1/8" depth on the bit.
Following two photos are of the holes for the stanchion and jack stand bases.
On to the discharge openings with my next post.
Cheers,
Tim
Edited by Timothy Wood
Tim
Future Build:
Completed Builds:
Member:
Greetings,
Here it is Saturday and I'm finally getting back the kit.  Funny how the real world gets in the way of the things we like!  Oh Well here goes!!!
The instructions only show and mention the starboard side of the boat, which didn't set with me, I contacted a fellow PT Boat scratch builder in our club and we mulled ove the question of discharges points only on the starboard side, he suggested I look at www.PT-103.com web site.  He stated they have all kinds of information including the original PT parts catalog and many orignal drawings. (PDF Files)  His lead really paid off, I found there are in fact discharges on the port side not mentioned in the instructions, I also found many water pickups located on the underside of the hull, from the orignal drawings, at this time I choose not to add these to my model.
Below are photos of the starboard discharge points, I will also add the port discharges to to the model for accuracy.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Tim
Future Build:
Completed Builds:
Member:
My next step was to cut the stanchion bases to 3/16" length, which is 1/16" longer than the hole for the is deep.  They will be filed down to .005" above the deck which is about the thickness of a picee of photo etched
Tim
Future Build:
Completed Builds:
Member:
I found the easiest way to handle the stanchion bases was to insert a toothpick into the end, it made it very easy to insert the bases into the deck holes.
Once the glue dries the stanchion bases will be filed doen to .005" above the deck, this is about the thickness of a piece of photo etched brass.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Greetings,
The next step was to file the stanchion, jack stand and discharges to proper height, 005".
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Thanks Harvey,
I was siting there trying to fit them in the holes with my fingers, and not having much luck I might add, then it hit me.   The end of the tooth pick just might work to hold the base, needless to say it worked perfect!   That just may be the only bright idea I have all year!   ;)
On to marking and placing each Shaft Boss.
Cheers!
Tim
Tim
Future Build:
Completed Builds:
Member:
My next step was to mark the locations of the struts, rudders and shaft bosses.
Tim
Future Build:
Completed Builds:
Member:
After I marked the hull for placement for the rudders, struts and shaft bosses, I used a #75 drill to drill the holes for the rudders.  The next step was ro cut the slots for the locating tabs on the struts, this was accomplished by using a hobby knife blade.  Pictured below are the forward struts in their proper location.
Tim
Future Build:
Completed Builds:
Member:
The final photos are of all the struts in their correct locations.  The next step is to drill out the shaft struts with a 1/16" drill bit.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Thanks Gerty!
Tim
Tim
Future Build:
Completed Builds:
Member:
Thank you,  Harvey!   :)
Tim
Future Build:
Completed Builds:
Member:
Greetings,
Today I made the attempt to drill out the Struts so the shaft can be inserted.  My attempts to say the least ended in failure, the reason is there is very little room for error when drilling the strut.  The strut housing is a little larger than 1/16" diameter.  I even started with a pilot hold with a #75 drill, then switching progressively to larger diameter drill bits until reaching the desired 1/16" bit size.  (I must return to the drawing board with this problem).
One solution I have thought of and may very well try is to cast the struts in resin.  This will give me a part which can be easily and slowly hand drilled with a pin vise and bit.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Greetings,
Just got off the phone with BlueJacket Ship Crafters in Maine, I ordered a new set of shaft struts.  A fellow member of Hampton Roads Ship Model Society (HRSMS) has offered to cast them in resin for me.  I believe I'll take him up on his offer because is should be much easier to drill the openings for the shaft in resin over cast metal.
I did start to work on the Chart House and Day Cabin last night, they are now at the proper height.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
I have built several Bluejacket kits, and the last, the 4 Piper 310' Destroyer was the last one I did and I know just how much goes into one of these.  You are doing a fine job sir and I look forward to more.  I now see that they have revamped the Destroyer kit, that was a monster to build........pretty much done me in on solid hull kits.  Keep up the precise work, and any parts that you can have cast in resin, I would do all I could, alot easier to work and detail.
Rick
Wherever I am at...........there I am
KARTONIST in the making.......... B)
Ship Shape,
Thanks for the encouragement.  So far it's been a fun build, even though Im not too far into it!
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Ship Shape,
Cheers,
Tim
You're welcome, here is my version of the PT Boat, albeit RC, is still scale..........yet to be built, this is a promo photo of the kit.
My current project is this scale boat @ the moment.......... a Lindberg Connie, 2nd photo.
Rick,
Here is a photo of an Elco that a friend is building from scratch, this will be RC also.  I don't recall the scale though...
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Tim,
Your 80' ELCO is looking good.
Bob
Current build:  SS_ Mariefred
Thanks Bob, with a little luck I may be able to add something new to the build this weekend!
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Greetings,
After some searching the internet and with some help from my friend Gene I was able to come up with the placement sites on the lower hull for the remaining drains.  I was able to to get them installed this week.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Greetings,
I finally made time to return to the model bench!  After trying without success to drill the strut for the shaft placement, I contacted BlueJacket Shop Crafters, I was informed they now include a new one-piece shaft and strut assembly.  I quickly ordered three, and they arrived within a week at my front door.
Pictured below are the strut and shaft in their correct placement.  The three shaft boss units will be glued to the hull at this time, the struts with the shafts will be attached at a later time.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
The struts look nice. Kudos to Bluejacket for coming through. I've always kikes the lines if th PT boats and yours is showing them nicely. Keep up the good work.
Dave B
Current build: HMS Pegasus, English Pinnace (on hold)
Completed build: MS BluenoseSkippercraft
Thanks to everyone for their kind words of encouragement.   :)
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
