Tim, Bob and Popeye,
Thanks for looking in and for the good words.  I haven't worked on the boat for about a week as I've helping my son refinish some furniture.  That project took a couple of days but turned out great.  My last post was about installing the dredge rollers and although they turned out great I had a problem with the blackened finish.  When I first blackened the parts and installed them the blackening looked great, a nice flat even finish but in about two days they turned rusty with splotches of black.  Looked kinda good actually, like they were really weathered but not in keeping with the rest of the boat.  I had to hand paint them after they were installed but they look good, so I'm happy.  I also have a tale of two sails to tell.  I made a previous post about my first try at sail making which I was quite proud of. Since then I decided to use the tan colored cloth so I remade the sails. The basic sails turned out good, nice seams, and hems. The next step was to put the bolt rope on.  I didn't think I could sew them on so I used glue.  On the jib sail I used ca glue to attach the bolt rope. It worked but stained the sail cloth and made the sail very stiff.  On the main sail I used elmers white glue to attach the bolt rope. That worked well and the sail was less stiff.
I then proceeded to put eyelets in the jib and this is what happened. The ca made the sail very brittle so I won't be doing that again.
So back to the beginning. Since I have to remake the jib sail, I decided I will sew the bolt rope on and I also decided to take the time to install eyelets, and thimbles at all the sail lacing points.  That means I will have to remake the main sail as well, as the elmers glue made the bolt rope to hard to pass a needle through. That will be a VERY time consuming job but I think it will be very realistic and add a lot to the model.  The eyelets I am using are 1/16 dia. x 3/32 shank .  I tested whether I could do this well and these pics show the result.  The stitching on the piece of bolt rope will be much better than shown as this was just a test to see how difficult it would be.
post-1790-0-76115000-1373465224_thumb.jpgpost-1790-0-39177800-1373465283_thumb.jpgpost-1790-0-44631500-1373465345_thumb.jpg
To maintain my sanity, I think the best plan is to work on these sails a bit at a time while also working on other aspects of the boat.
Thanks for looking in.
Thanks for sharing your learning curve on the sails.  It's good to know.  Your last try is looking very good.
Bob
Current build:  SS_ Mariefred
When I'm done sewing sails,  I like to paint them with a diluted white glue.   it helps to keep fraying from occurring.  I felt that's would happen if CA was used....so I've never used it.   the idea of the eyelets looks great.........something I never thought of.   you have a tool to install them,  I take it.  looks very nice!  ;)   I have different thickness needles......thinner needles work better.  the other day,  the admiral was looking for one.........I just laughed.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Sweet, nice work on the sails!
Tim
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
Wow! Sails look fantastic.
One of the two things I am very intimidated by at the moment,  the sails and the metal work.   You did great on both!! Kudos sir, kudos!!
-Adam
-Adam
Current Builds
Santa Maria - Artesania Latina (1:65) POB
MayFlower - Model Shipways (5/32"=1') POB
Blue Shadow - Mamoli Revolutionary War Brigantine. (Fict) (1:64) POB (Recommissioned as the Kara June)
On The Shelf Waiting so Patiently
USRC Ranger - Corel (1:50) POB
18th Century Longboat - Model Shipways (1:4) POF
La Nina - Artesania Latina (1:65) POB
U.S Brig Syren - Model Shipways (1:64) POB
Completed Builds
Phantom NY Pilot Boat - Model Shipways (1:96) Solid Hull
Decommissioned Builds
(Time and conditions were not good to these. They have been cancelled =( )
Willie L Bennett - Model Shipways (1:32) POF
USRC Harriet Lane - Model Shipways (1:128) Solid Hull
  • 5 months later...
Richard,
I am also working on the Willie Bennett and like the way you made your sails. Where did you obtain the eyelets and what type of tool did you use to install them?
Bill
  • 5 months later...
Richard, what a work of art.  Amazing.  I'm awaiting my Willie to arrive from SHipways.  I'll be referring to your log!
Don't you worry about it.  I'm working on it.
Thanks for sharing this build. I have the kit on the way and this info is a treasure. Being from Md the old skipjacks are pieces of history
  • 5 months later...
  • 5 years later...
I had this kit 98% completed...... and then the refrigerator ice maker water line broke, water leaked thru a heat vent duct and drenched the boat and the box it was in.   I worked on this kit off and on for 15 years, and now I just have a box of misc parts.  I'm hoping to pick up a partially done kit on eBay and finish what I started in the '90s.........🙂
