I have a combination deadeye/backing link cast from brittiana metal. I would like to blackening them with some kind of chemical compound. Is there such a solution.? The mixture for brass & copper does not work on this type of metal.
Or is paint the only option ?
Thanks
S.O.S.
New Bedford Whaleboat build. Kit by Model Shipways
I've been making progress on my model and according to the instruction booklet I should be painting it, at least parts of it.
Are acrylic's ok ? I did apply a sanding sealer. but I want to stain the untreated floor boards which are walnut.
Thanks
S.O.S.
Thanks ianmajor, some good leads there. I did send an inquiry E mail to Bluejacket concerning the blackening fluid as I did not see it in there online catalog . So lets see if they still whip,it up.
SOS
Thanks
S.O.S.
I use the BlueJacket products - both pewter and brass. They work well. They are still out on their website. You just have to drill down several menu levels.
Just make sure your material is clean. BJ also sells a cleaning product which I use and there are numerous homemade concoctions.
Thanks folks. I used the blackening agent that Bluejacket sells. It worked out great.
S.O.S.
Thanks
S.O.S.
S.O.S. - One thing I do to parts after blackening is give them a layer of some matte lacquer.  This helps keep the black where it belongs - on your piece, not on your hands. The flat finish hardly shows.
