Cockpit plankings, 1mm mahogany sheet. Don't they look like tangram parts to you, too?
After dry-fit test, one of them was slightly (less thn 0,5mm) too long. I cropped it:
Edited by aydingocer
Current :
HMS Sphinx by Vanguard
Completed:
Orient Express Sleeping Car by Amati
Bluenose II (Artesania Latina)
Istanbul Tram - Occre
Bluenose II - Artesania Latina
Bosphorus Sandal Fishing Boat
Riva Aquarama - Amati
Titanic - Mantua
Bosphorus Fishing Boat - Tersane Model
San Juan Nepomuceno - Artesania Latina
Bluenose - Billing Boats
The mahogany parts have laser burns around the edges. I thought they may cause trouble later during the finishing phase if I use them just like that, so I sanded away the burns from the visible edges.
Before:
After (a different side than above):
Current :
Completed:
Titanic - Mantua
I would expect the manufacturer to pay attention to the direction of the grain when placing the parts on laser CNC. It would look much nicer if they did it:
Current :
Completed:
Titanic - Mantua
Cockpit has now been covered with mahogany planks:
Current :
Completed:
Titanic - Mantua
Reinforcements reinforcements everywhere  ;). I think this kit contains alone more reinforcement parts than all my past ship kits combined. Not that I complain :). Of course it should survive moderate collisions and vibrations. Here are several photos in a row: the first one with list of parts followed by the rest showing them installed in their places.
Here the boat turns to side for the first time:
Current :
Completed:
Titanic - Mantua
Rudder supports on the bottom.
The orientation of the two holes are important.
Below I was first wondering "what is the gap here? There must be a reason?!?"
Then I realized I glued the part 64 wrong! (First mistake in this project - so far).
Luckily it was not too bad a mistake. I ripped the part off:
Scraped the glue stains, and glued it back in correct position. Now looks better (phew). This would absolutely cause me a lot of trouble later because I noticed that it was partly blocking some slots above it.
Current :
Completed:
Titanic - Mantua
Support for the rear cover.
Glued in place:
Current :
Completed:
Titanic - Mantua
The cover itself. NOTE for the R/C builders: This cover must not be glued but be removable.
I just temporarily placed it in its place to let the glue dry at  its correct shape:
Current :
Completed:
Titanic - Mantua
Lateral plankings of the cabin. 1mm mahogany.
The instructions say you can also nail them if you like, but I preferred to avoid it, not to take the risk of cracking them all the way. Mahogany, especially at this thickness is not easy to work with. Instead, I gave it a bend with the help of the frames in order to make it easier to position without applying too much force:
Dry fitted and glued:
Note that the front parts (the triangular ones) should be glued from the outside:
Though this leaves an uncovered section in the middle, but this is compliant with the specs. Who knows maybe it will be covered later (I was too lazy to check forward).
All in place:
Current :
Completed:
Titanic - Mantua
Ayden,
Good progress. You are quite right in your remark that the manufacturer could/should pay more attention to the grain of the visible wood in relation to other components. These kits are expensive enough for the parts to be 'in grain' with eachother. To me it seems as a very nice, and challenging kit to make!
Edited by cog
Carl
Here the instructions call for a 2x6mm strip to be glued under part 49 to act as a support to the rear seat. Checked the length from the plan and glued it as seen.
Current :
Completed:
Titanic - Mantua
Sorry to hear about the broken part, but I am sure you can make one yourself, or contact them to have them send you one.
I'll see if I can mend it.
Current :
Completed:
Titanic - Mantua
The backseat.
This is also one of the pieces which should be left removable if R/C option is used. I noticed that the part 116 was not perfectly flat. It was a little bit warped (about 1mm). It would look ugly if I use it just like that. For this reason I soaked it in water for a while and fixed it with clamps on an aluminum jig which I had lying on my shelf for other project. I will wait until tomorrow hoping that it flattens. If it won't, then soak it longer time and maybe use hair dryer while it is clamped.
Current :
Completed:
Titanic - Mantua
Side supports for the backseat. The small metal squares which I had bought (from micro-mark.com if I remember correct) help well in these kind of tight places to ensure the right angle.
A 4x4mm lime strip to reinforce the back support for the seat. Temporarily dry-fitted until the whole thing is glued in place:
Current :
Completed:
Titanic - Mantua
More lateral mahogany planking sheets. I had to trim some 1mm for a perfect fit.
Dry fit:
Measure the trim:
Trim (about 1mm):
Glue in place:
Repeat the steps for the other side.
Current :
Completed:
Titanic - Mantua
More lateral planking.
Note that the parts have small groove at one end. It is essential to pay attention to orientation of the parts:
Measure 2x6mm strips to act as spacers to above parts, using the plan sheet:
Spacers glued in fornt of the support piece (which was temporarily fitted above  - in the photo with masking tape):
Current :
Completed:
Titanic - Mantua
Aydin
Wow you really are rocking building the Riva. It's interesting and fun to follow along.
Respectfully
Thanks Per! It is also exciting to know being watched :)))
Current :
Completed:
Titanic - Mantua
Mind the groove which I mentioned above. This is where it should be:
Current :
Completed:
Titanic - Mantua
This piece came around 1mm too short, because of the adjacent sheet (on the right) which I had to trim. This will most probably not even going to be visible, but just to be a good sport, I measured and cut a thin strip from a scrap mahogany sheet and glued it in place to close the gap:
Watching the direction of the grain  ;) :
Current :
Completed:
Titanic - Mantua
END OF BUILD DAY 3.
5 hours today.
14 hours into build in total.
This is the status at the end of DAY3 .Thanks for watching.
Current :
Completed:
Titanic - Mantua
You are moving along nicely. This is almost like watching a jig saw puzzle come together with all the pieces you have to fit. I agree with you that this is definitely one of the more intricate sub framing kits I have seen. Good to see that though when you consider the impacts and vibrations that she will take from the motor and when out on the water.
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
BUILD DAY 4. HULL CONSTRUCTION CONTINUED
Today I had to stop earlier than I was planning for the reason I will tell later (nothing bad).
Current :
Completed:
Titanic - Mantua
The rear seat panel, which I soaked and clamped yesterday to get it flat, is flat now and ready to be assembled.
Note that the two pieces are not aligned vertically:
The rear seat panel is in place. It is not glued to the place since it has to be removable (pulling by the help of the hole in the middle) to access the R/C compartment:
From top:
And from bottom:
Current :
Completed:
Titanic - Mantua
4x4mm supports to hold the lateral planks:
Current :
Completed:
Titanic - Mantua
1mm high quality birch veneer sheet containing the parts for covering the hull’s plywood at more visible parts of the boat:
Current :
Completed:
Titanic - Mantua
Cockpit cover parts from the sheet above. Here during dry-fit I noticed a mistake in the instruction manual. Parts 150 and 151 are labeled wrong in the photo in the manual. They should be vice versa. Otherwise they won’t fit. Or the numbering in the plan sheet is wrong, whichever. Well, this is the 2nd error in the instructions which puts me to 2-1 lead in the mistakes against the manufacturer!
Current :
Completed:
Titanic - Mantua
Parts 152 and 153 are the footrests which will be glued inclined. I used a piece of scrap wood (no glue) ensure that the triangular parts which will hold them dry at identical angle.
According to the specs the footrests are not flush with the mahogany plank (in this photo it is the plank on the left side. Similar thing is for the other footrest). They stop at the end of the plywood allowing the edge of the mahogany plank to show.
Current :
Completed:
Titanic - Mantua
And now I turn the page of the manual only to find out that I have to stop for today: Looks like it is time to apply some lacquer which I wasn’t expecting to come this quick. Well, actually the instructions are not calling for it just yet. According to the manual it is time to apply the “leather-like material” (that’s what the manufacturer keeps calling it throughout the manual) inside the cockpit. It sounds however wiser to apply the lacquer inside first in order to eliminate the risk of spilling lacquer on the upholstery.
I saw in another build log in another forum that the builder applied water proof lacquer all around inside, I think that’s what I will do. So I’ll go and buy a boat grade lacquer tomorrow.
I also checked this “leather-like” material. It is totally plastic and feels a bit tricky to fold in the corners. I decided to try on a piece of scrap and first results was not promising:
Cut a test piece:
Apply glue (trying with UHU Hart just out of curiosity):
Put on the plywood, swipe with a piece of stick applying pressure:
However it didn’t seem to work. There came air bubbles and eventually the glue came loose:
Then I tried with CA (super glue), which seemed to work well, except that the residues left stains here and there. Have to be very careful if I choose to use CA.
. It seems very tricky and make-no-mistake task to successfully apply the upholstery to the entire cockpit.
Right now I think this will be my plan:
-   replace the leather-like plastic with thin faux leather sheet. It would look more realistic and be easier to work with.
-   cut identical pieces from a very thin veneer (or from acetate sheet) using the plan sheets as guide
-   glue the faux leather peacefully on these pieces
-   and finally glue them in their places on the cockpit
Or any suggestions?
So, next, I will lacquer the interior and move on to the next task until I do the shopping above.
Current :
Completed:
Titanic - Mantua
