This ship has a long story to tell :D
I ordered it from Cornwall Modelboat, and it was shipped immediately, and reached Malaysia 2 weeks later..
However, when the postman send it to my house there wasn't anyone at home! So, he left a notification message of my parcel.. BUT, in a different mailbox :mellow: which my dad actually sealed it with duct tape (because bees love to nest there..). I've really no idea how he break it..
Since we don't use the mailbox anymore.. I thought CMB lost my item, and contacted them several times.. and gave up...
Until 3 months later, I saw a notification message in my mailbox (this time the correct one), with a BIG red "REMINDER" on top!! I was like "WOW!! Miracle!!", and quickly went to my local post office and pick up my item...
I sent the same 2 pictures back to CMB to clarify everything!!
Anyway, it's here finally..  ^_^
Here it is!!
And everything is good
I added 10 sets of Cannon with carriages, some Cannon balls, 1 set of gratings, and a bell!
My DIY clamp!
not really diy actually.. just added a clamp on my tripod ballhead!!
And added racquet grip to protect the false keel!
This is how it looks like
First problem...
Although laser cut, but still not so through..
I haven't cut out the ruddle (on the most right, in case u can't figure out :P), will take it out next time when I am in a good mood :D
So, here's my plan..
I want to make an extra hatch on deck, since there's a big empty space!
So, I cut off another 'square' there which is parallel to the bombard docking area..
Here it is
The main purpose of the hatch is not jz for decoration!! But I want to make a 'signature' in my ship!! :D
By using this!! An old Stamp Seal
A 'board' will be added inside the ship, to hold my signature :)
However, when I again put the deck on the bulkhead only I noticed that the half deck (alignment bar) is actually blocking it to see through.. :(
So, I removed that part that blocking.. within bulkhead 6 and 7..
Hope this won't cause a big deal in future.. since I can't rely only on the alignment bar to secure all my bulkheads in position
Then when i decided to make the board for my signature... I cut myself.. =.=
ON THE VERY FIRST DAY I MAKE THIS SHIP!!!
THIS LITTLE INJURY WILL NOT STOP ME FROM MAKING MY SHIP!!!
Ok, anyway... I'll have to stop today... it's really hurt :P
So, I started posting here.. :)
Okay, enough for story telling... now I've some question to ask :P
Does anyone of you encounter this problem also? The deck doesn't sit perfectly to the bulkhead..
Let's take the right circle as example.. The 'hole' can be easily covered by deck planking, but what about the extensive space created by the bulkhead? It seems hard to be covered by deck planking... Any suggestion?
Another one..
How do I solve this? It looks serious... bevel the touching one??
Visit My Blog!
http://malaysiamodelship.blogspot.com/
Previous Build:
HMS Race Horse (Sergal)
HMS Unicorn (Corel)
After healing from that silly cut, it's time to get back to work!
I almost miss out the bulkheads beveling part which is so much important in ship modelling.
So, this is what I've done. The Sergal instruction shows only first few bulkheads need to be beveled, but I personally think it's best to do all. It doesn't take even 30 minutes after all!! :)
OK, Let's get back to the signature! Which cost a scar on my big thumb!! :P
I'm placing that right beneath the extra hatch that I make, which is between bulkhead #6 and #7. To make it looks better, I've also made planking within all visible area.
The rectangular board is where the signature will be! :)
The stamp seal comes with 3 colours: gold, silver, and red. Since it will be dark inside, so I chose more shiny colours.. gold and silver!!
A breath on the copper seal head + a slight press on wax... oh ya, and a drippy drippy :D
I named it "Planet Z and Its Moon" XD
So, it's basically how it looks like now.. :)
Didn't have much time on weekdays..
this is basically the progress in one night
Visit My Blog!
Previous Build:
HMS Unicorn (Corel)
Another one..
You'll find that most ships have a "sheer", where the deck is lower in the middle compared with the fore and aft, a long sweeping curve, and a "camber", where the deck is higher in the middle than at the sides. Think banana.
You'll need to clamp/pin/weight the false deck down to the bulkheads, providing they're correctly shaped from the factory (look at the plan's drawings) rather than shimming them up to the deck.
"Give you joy!"
Current Build: RATTLESNAKE 1:64 POB (Mamoli)
Kits on hand: "Lexington", Mamoli: "Robert E. Lee", Scientific
Scratch to do: "Fannie Dugan", 1870s Sidewheeler Steamboat
Day 3
Before I started Race Horse building, I've been thinking of making the interior of Captain's Cabin. So, I searched through the net to find one good example.. and here it is!!
2010-06-dollhouse-kupjack-pirates-ship-d
Interior of Captain's Cabin
Of course that's no way that I can make such complex cabin, this is just for a reference!! :P
So... Here's the plan!!
Draft on Making Cabin
The red shaded area are region that need to be cut off. Part between bulkhead #10 and #11 will be the cabin; while part between #11 and #12 will an empty space between the cabin and the stern window.
Full Size Plan Comparison
Comparing to the full scale plan, the window is right within the area.. So, it's workable!!
Now, the stern window part.. which is much more difficult to handle. The reason I remove the area on #13 is because they are blocking the view from the stern window. However, if they are removed, it will cause minimum area for me to apply glue on it, which makes me no way to hold #12!
Removing Shaded Region of #13
Now you can see how small is that area to hold #12. To solve it, I'll need to make another wood piece increase the surface to stick on #12.
Extra Wood to hold #12
This extra wood will be placed between the tips of #13.
Holding Firm   :D
#12 On Position
DONE!!!
Anyway, #12 is actually temporary.. Because there is no 'holes' to allow people to see through it. I haven't had a clear plan on it yet, maybe I'll need to drill a 3 big holes on it; or I'll directly put the cast metal on! The purpose to put #12 on position temporarily is to give body planking a set point.
However, there's another issue here... the cast metal stern window doesn't fit perfectly! I have currently no idea on solving this. Anyway, I think that the double planking will cover that empty part. Let's put it aside first.
This Is So Not Good
So, after all these planning and cutting I can finally put my bulkhead on!! In my case, I used a rubik's cube pieces to help them set in right angle.  :)
Rubik's Cube Pieces to Help Positioning Bulkheads
How it looks like now
All Bulkheads in Position
O.K.
- End of Day 3 -
Visit My Blog!
Previous Build:
HMS Unicorn (Corel)
Day 4
As mentioned in the previous day, the cabin sits between bulkhead #10 and #11 where only very limited space for me to design it. I drew plan to make sure everything sits right:
Draft on Captain's Cabin
So, I've only 49mm * 25mm of space for me to include everything into the cabin!!! This is going to be very challenging!! :D
I started with the table first. Since I still kept all leftover wood pieces of my Black Pearl making, it makes my work easier...
No big issue on making the table.. around 20mm * 8mm.
And then, the chair..
The Chair, Tiniest Among All
Making the chair is the HARDEST part!!!   :angry:
To make sure all these furnitures looks in ratio, the chair's seat needs to be only at 4mm * 4mm, and its legs at 1mm * 1mm!! The tiniest wood strips I have is only 1mm * 2mm, in which I'll have to cut them in two!! It took me around 30 minutes to complete this, with few breaking wood strips..
The Map!
'Map' Dip with Coffee to Give Vintage Effect
I've also made a map (ok, just a paper.. :P) to fill the table. In order to give it a vintage effect, I added some flavours (IPOH White Coffee) on it :D
I canceled my cabinet planning, and replaced it with a mirror. This idea came out when I was eating snack for my breakfast, which the inside of plastic bag is a good reflective body. :)
Mirror with Stands Using Previous Ship's Material
The stands are the leftover pinrail material from the Black Pearl, which I think suitable for this too.
To fill up the big empty space on the port side, I added another pole hanger. It is made by using one copper nail as its pole, and copper rings as the hangers. It really took me sometimes to glue the hangers on the pole...
Pole Hanger Beside the Table
For the bed.. Too sad that I've forgotten to take photo on its progress.. It's done by using a 4mm thick wood piece, and few small pieces to tissue papers. I put a folded tissue beneath first, to make a 'bulge' effect, and then only 'wrapped' the whole thing up as a bed sheet.
For the pillow, I cut out a long 'tissue-strip' and wrap it up at one end of a wood strip. Glued it, and then cut off the end of the strip. :)
Captain's Cabin As Seen to Stern Side
Take a close look, and you'll see a pen in a container on the table!! :lol:  The container is made by a spanker bead from my Black Pearl; while the pen is made by a refill of mechanical pencil! :)
Take a clear look again!!! YES, I made another chair to fill up the space!!!
Now left only a door to complete..
It's done by using the removed part from the half deck.. I added planks on it, and drilled a hole as sash of door, and then a nail as door knob! :)
Door to Captain's Cabin
So, it's how it looks like now!!! ^^
The Captain's Cabin
I can finally proceed to the most fun part of ship modelling... PLANKING!!
- End of Day 4 -
Visit My Blog!
Previous Build:
HMS Unicorn (Corel)
Great job on the captain's cabin.
Regards,
John
<span style='font-family: courier new'>In progress: <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/177-king-of-the-mississippi-artesania-latina-scale-180/'>King of the Mississippi</a></span><br />
<br />
<span style='font-family: courier new'>Completed : <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/176-mare-nostrum-4331-artesania-latina-scale-135/'>Mare Nostrum 4331</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://modelshipworld.com/index.php?/gallery/album/51-16th-century-galeass-imai-scale-1160/'>16th century Galeass</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://members.upc.nl/carla.en.john/Modelbouw/Rocket.htm'>George Stephenson Rocket Locomotive</a></span><br />
<br />
<span style='font-family: courier new'>Next build : sl Louise</span>
I started my 1st planking since last Sunday, and it took me around 20 hours!! Anyway, it's so much fun!!
First Temporary Batten
Front View
I don't think I started it real smoothly.. here's one example :(
I've over tapered here..
Anyway, it can be easier covered by wood filler..
Over Tapering Aftermath
Worrying the result turns worse, I stopped here and continued on the garboard plank part..
Garboard Planking
Same step is carried on until they touched each other at the bow side..
So, now it's time to fill up the center part..
Well, I saw this picture from another forum.. it's in Czech
I followed the method above, since the Rule of Thumb says tapering cannot exceed half of the plank original width... and the result is quite satisfying :)
Following the Rule of Thumb
This method really took me some times..  ;)
Stem side
Then, the stern
I filled them up using some stealer planks, full and half..
You can actually see a 'hole' there at the stern side!! LOL
I trimmed the woods too early before I know they will need to cover that part!! :P
Stem Side
Stern Side
Just when I about to start the wood filling, I found this.. zzz
This is the deck planking I done last time during my spare time, and see? They turned yellow!!
It is caused by my cheap adhesive.. 3 pieces (9g) for just RM1.20 (less than US$0.40!!!)
And since the deck planking is using thinner wood strips (0.5mm), so it made the result more obvious..
I think I'll need to change a better brand before I start my 2nd planking
Visit My Blog!
Previous Build:
HMS Unicorn (Corel)
After woodfilling and sanding she will look great. Just in time you note that the cheap adhesive will ruin your planking, a blessing in disguise ;)
Regards,
John
<br />
<br />
Regards,
John
yea, and I just bought a new adhesive..
just done sanding and filling.. now working on 2nd layer :)
Visit My Blog!
Previous Build:
HMS Unicorn (Corel)
No too big issue here on the 2nd layer planking, since I was just following the 1st layer.. :)
Anyway, I think that I forced the wood strip a bit and caused a 'flaw' at the middle part..
DSC_0194.JPGPort Side (A Flaw Can Be Seen at the Middle)
I also scribed the wood strips using a 8B pencil, that's why you can see obvious black between woods. :)
Stem
Starboard
Here you can see the flaw more obvious from the picture below..
Anyway, comparing to the full scale plan.. the wale will just cover it! :)
Wale Will Cover That Flaw
After sanding with 320 and 600 grit, I then continued on staining my ship. I bought a Dark Walnut, and a clear gloss stain in order to get my desirable color.. As shown in picture below, from top to bottom: Dark Walnut, 50/50 Mix of Dark Walnut + Clear Gloss, Clear Gloss.
Second One as My Ship's Colour
I chose the 2nd one as my ship's stain colour, which look pretty similar as the picture on the box... anyway, a nightmare began!!
When I swiped my brush across my ship, some portion just didn't 'bite' the stain!! And cause all these big freckles on it.. HELP!!!
I think they are caused by the excessive glue that applied earlier, and I tried sanding them and stained again the next day.. however, it still return me the same result.. :(
Any suggestion?
Visit My Blog!
Previous Build:
HMS Unicorn (Corel)
ZyXuz,
I have the same kit, I purchased it five years ago from Model Expo.  It currently is about number four on my build list.   I plan to follow your build in order to get important building tipf for future use.  I look forward to following your build, keep up the nice work!
Cheers,
Tim
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
Timothy Wood, on 07 May 2013 - 12:27 AM, said:
ZyXuz,
Cheers,
Tim
thanks!! hope my build log helps! :)
Visit My Blog!
Previous Build:
HMS Unicorn (Corel)
When I swiped my brush across my ship, some portion just didn't 'bite' the stain!! And cause all these big freckles on it.. HELP!!!DSC_0213.JPG
Any suggestion?
Hello ZyXuz,
I had the same problem, but on the innerside of the bulwarks. I didn't removed the dust andused too much glue, which I didn't sand correctly. And I didn't use any wood conditioner.
Wood dust from sanding will cause problems if it's not removed from the surface before staining. Dry rags or brushes aren't the most effective tools for removing dust. Instead, use a tack cloth, a sticky piece of cheesecloth made especially for this purpose. Wipe the folded tack cloth across the wood to remove dust. As each side becomes saturated with dust, refold the cloth to expose a fresh surface. Tack cloths are available at hardware stores.
Did you use any wood conditioner? A number of soft woods aren't conducive to stained finishes. To help even out the color when working with new, bare woods such as pine, fir, maple and birch, try using a pre-stain wood conditioner. These conditioners are designed to penetrate into the wood and allow the stain to absorb more evenly when it is applied later.
Sometimes it is also necessary to degrease the wood before you put any finish on it.
Degreasing the wood also removes the dust. What to use for degreasing depends on the sort of wood you are using.
I don't know if it is necessary or advisable to sand the hull again and start over. I really don't know what the effect from sanding the hull again will be. You need an experts advise on this. Either from a member of this forum or from your local hobby or hardware store.
Please also look for tips on this forum. you may even ask your question there.
http://modelshipworld.com/index.php?/forum/21-painting-finishing-and-weathering-products-and-techniques/
I'm sorry I can't solve your problem instantly, but I do hope you will get an answer soon.
Good luck and take care,
Anja
Those we loved but lost are no longer where they were, but are always where we are.
In the gallery: Albatros 1840 - Constructo
Hello ZyXuz,
Anja
Thanks Anja!
I've searched through the link you suggested here, and googled for more options.. and seems like I've no way to repair it, but to resend it and stain again..
Before this I've already learned that pre-stain conditioner will help on staining, but I didn't purchase it because the smallest size in my local store is way too big for me! 30+ Oz!!
Well, here's the result... still not so satisfying, but at least it already covered those major defects especially those corner parts..
Port
Starboard
There will be 2 blue stripes running along the middle part of the hull. Let's hope it can help on 'covering' the remaining defects..
Visit My Blog!
Previous Build:
HMS Unicorn (Corel)
Day 13
After fixing the stain, I continued on the deck planking while waiting the stain to dry.
Same method as the hull planking is used, I scribed one side of the woods using an 8B pencil to give better details.
Deck Planking
Top View
Treenails are also added using mechanical pencil, and finally a natural stain on it to provide protection. Inboard plankings are also done up till now..
Treenail
Now the Bulwark.. I will need to cut the gun ports out before I can apply colour on it. I transferred the distance between gunports from the full scale plan provided, mark them on a piece of long cardboard to get better accuracy.
Bulwark's Gunports
I drilled around 4-6 holes at both sides first, to help cutting them out.
DSC_0231.JPGGunports
- End of Day 13 -
Visit My Blog!
Previous Build:
HMS Unicorn (Corel)
Nice job on the planking and the gun ports. Looking great.
Regards,
John
<br />
<br />
Day 14
Since my ship's color turned darker after 2nd staining, I've decided to give my Race Horse a Navy Blue coat to give better contrast.
Result after 7 hours!!! Setting the wales really time consuming..
DSC_0249.JPGStarboard
Port
If you look closely, you can see that I've overdone the lower stripe to black.. :P
-End of Day 14-
Visit My Blog!
Previous Build:
HMS Unicorn (Corel)
This is giving a nice contrast indeed. Well done !
Regards,
John
<br />
<br />
Hello ZyXuz,
I'm back for another look at your Race Horse.
Yes, I was afraid you would have to resand the hull again. But it turned out good in the end.
And we both learned a lesson to use pre-stain or wood conditioner first.
The dark colour of the hull is a nice contrast with the blue/white.
Looking forward to your progress.
Take care,
Anja
Hi ZyXuz,
She looks great, like all the other comments l really like the paint job.  Good selection with the colors.  I look forward to following more of your build.
Chers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Day 15 to 22
It has been awhile since the last post..
I've been working on all the deck fittings till late night, that's why I didn't have much time to add post here..
Anyway, I haven't glue my poop deck on because I'll need to wait for my LED to arrive before I can start..
Windows
Since I've interior for my captain's cabin, so I'll need to cut out holes so that it can be viewed from outside.
Side Windows
Seeing Through
The same steps are carried on on the stern windows.
Gratings
I purchased extra gratings to fill up the empty space on my main deck between the 2 bombards, and it is set as the same size as the bombard base.
Frame is also added with leftover walnut planks. the 'drain racks' at both side will hold the bombard shots!! :)
I've also made another 4 racks to put them besides the 2 bombards!
Rudder
Rudder with rudder hinges fitted. I did not hammer the nails, instead I used a long nose plier to push them in.
Rudder with Hinges
Bits & Pin Racks
This is the worst part of the week!
In the beginning, I thought all the bits will be provided by the kit, carved and done!! Not until I read the instruction of making all these bits... :(
So, what the kit actually provides is just a long 500 *4 *4mm walnut strip...
Belaying Pin Racks
Parapet Bits
Making these really testing my patience... and wearing my blade..
All of 4*4mm Walnut
Done! and it's time to change a new blade!! XD
Metal Blackening & Bombards
This is my first time doing metal blackening, and it was fun!! :)
I used Blacken-it as my solution, and it worked quite well!!
I made a mixture of 50:50 solution and water.. hot and boiling water!!
Hot water really help quickening the process, you can get an obvious result within a minute!!
Before
In Progress
After!!
Yea.. the 2nd picture you're seeing right now is the result after 30 seconds!! Anyway, I still let them there for around an hour or a half.
I actually did it twice, because the first attempt did not give a very satisfying result (rusty feel). So, on my second attempt, I made mixture of 40 water, 60 solution, and the 3rd pic is the result I get. :)
Bombard Completed
Hatch
The hatches at the poop deck.. I added nails as door knobs.
Hatches
With all these deck fittings done, I can finally put them on my ship.. It's how it looks now!!
Deck Fittings Done
Bombards with Shots
Again, the poop deck is not glued yet, I just put them on for few shots.. still waiting my LEDs to arrive.
-End-
Visit My Blog!
Previous Build:
HMS Unicorn (Corel)
I LIKE IT!
 Keep those phots coming!!!
Tim
Tim
Future Build:
Completed Builds:
Member:
Day 23
I was tidying up all my ship stuffs after working it one night, and when I digged out all stuffs at the bottom of the box of my kit, and OMG!!! I found one thing that I've totally forgotten.. The Bell!!
Bell & Belfry
So, quickly I searched through the net for examples of belfry as references.. and this is what I've made!! :)
Belfry
The columns are those leftovers from my beloved Pearl. Two 1mm thick of maple strips (leftover from 1st layer hull planking) are stacked up, and then another strip as bridge to hold them together. :) And, the shaft is made from fuse wire.. thin enough to cross through the crown of the bell.
Well, the flat head really doesn't look good.. So, I added a 'hat' for it! It is made of 3 * 1mm thick maple strips, and beveled at both ends. And, the shaft is painted to black.
Belfry After Staining
Now, where should I place it??? Hmm... normally it should be at the main deck, but my main deck is currently tightly occupied.. but putting it on poop or front deck looks weird..
Anyway, here's a shot of how it's look like on deck! :)
Belfry on Deck
Err... any comment on the position?? :P it really looks tight there! :D
Light & Lantern
As previously mentioned, I am still waiting for my LEDs to arrive.. however, I actually already bought 'lamps' to light up my cabin but it's just not bright enough.. That's why I'll need to buy LEDs to replace it.. and IT's tritium!
The main reason I wanted to use tritium to light up my ship is because of its durability, in which it is able to light up for 25 years!!! You just have no idea whether you'll be able to see it goes off alive!! :D In case you never heard of tritium: it is quite frequently used in military purposes, for example night vision on weapons; while for household application, watches.
Tritium Vials
Tritium is costly. I bought 10 of them, and it cost me nearly USD$100!!!
I tested it at night with all the lights in my room turned off and taken this shot..
Light From the Cabin
3 vials are placed RIGHT surrounding each window, in this case 6 vials are already used for the side windows, and there won't be enough for the stern ones (3 windows). This shot is taken in long exposure of 30s, and I swiped my phone flash over the ship during the exposure. If I don't do that, you'll be just seeing the light..
OK, the result here looks kinda satisfying but it's really different in real life. The light is already not noticeable from ~3m distance, without any presence of other light source in the same room!! Moreover, 3 vials for each window is just so not worth doing, that's why I changed my mind to replace them with LEDs.
So, instead of wasting them, I planned to make them lanterns on deck! :)
Column's Head and Base Cut Off
Again, by using the column from my Pearl, I cut off the head and base of the column as the head and base of my lantern. :) I then drilled a 1.5mm diameter (diameter of the tritium vial) hole on both the head and foot, and pinned 4 more holes at the 4 corners of the foot. These 4 small holes will be where the columns of lantern set, like this:
Lantern of Tritium Vial
The eye on top is made by the thinnest fuse wire.
The first one really took me some times until I came up with this idea, and my patience just allowed me to make another 2 on the same day. :P
The Three Brothers
How it's look at night.
Lanterns At Night
Brightness Comparison
Here you can see the brightness comparison of tritium with my laptop's notification lights..
-End of Day 23-
Visit My Blog!
Previous Build:
HMS Unicorn (Corel)
Hello ZyXuz,
That is some fast and wonderful progress you've made.
The close-up pictures of your hull are beautiful. Very nice painting job.
Your deck furniture looks absolutely great.
Well done. I look forward to your progress.
Take care,
Anja
Hello ZyXuz,
Take care,
Anja
Thanks!!
you really motivated me ;)
I like the scale of this model.  You can add a lot of detailing.
Indeed.. I still have cannons to add..
They are on their way from the UK :)
Visit My Blog!
Previous Build:
HMS Unicorn (Corel)
