Ahoy Mates :D
Has anyone used a rheostat to slow down their Dremel tool? I know some motors are “OK” with this and but others are not
I need to drill treenail holes in my hull and would like to use my Dremel, but at a considerably slower speed.
Dremel does not list this as one of the accessorries
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
An older single speed model I own is hooked up to a sewing machine foot pedal........works like a charm a quite and responsive for those "delicate" tasks requiring precision. I'm able to get quite a range of speeds from a basic crawl to full out.......
JP
Built & De-Commissioned: HMS Endeavour (Corel), HMS Unicorn (Corel),
Abandoned: HMS Bounty (AL)
Completed : Wappen Von Hamburg (Corel), Le Renommee (Euromodel)... on hold
Current WIP: Berlin by Corel
On Shelf:  HMS Bounty (Billings),
Mine is an older varible speed model (395 type 5)
I am wondering if opening it up and changing out or adding a resistor to the speed control is an option. I never use it at full power
I got the idea from this product sold by Micro Mark
http://www.micromark.com/variable-speed-foot-operated-rheostat-4-amps-max,8172.html
What I would love to hear is a cheap fan rheostat could be used
  J.Pett
Ahoy Vince
It is not on their site
Do you have a link
  J.Pett
J.P,
Which model of Dremel do you have?  If it's a variable-speed tool (such as the 395 like I have), the slowest they'll go is around 1000 rpm.  You could try putting a rheostat in there, but the addition of the electrical components could make the device not as hand-held (duct/electrical tape, small box to house, etc.).  If you'd like to get something that's in the 100rpm or so, try a slow single-speed, then rheostat for control.
Btw, where I DFW?  I'm in Tyler.
-Rich
Ahoy Mates :D
So I called Dremel's US customer support, which by the way was very good. People were very nice, well informed, spoke perfect english and I was on hold for less then 2 minutes,
With customer support like that I will be sure to buy more of their stuff.
Official:  The variable speed control is no longer sold by Dremel. It was made for the single speed units only (100 series)
Off the record: They did elude to but could in no way recommend using a motor speed controller on the variable speed units and only with the speed set at full on the tool. They also said this would for sure shorten the life of the unit. By how long no one would say.
Edited by JPett
  J.Pett
Ahoy Vince
Do you have a link
Micro-Mark. Part # 82694. Price $43.95 US.
Vince P.
Thanks Vince
  J.Pett
I use a Solid State Solder Iron Control to manage the speed of my Dremel 100.
PROWE
If someone says something can't be done, it only means they can't do it.
Building:Shipyard - HMS Mercury card madel
Completed Builds:
Wood Models; AL Bluenose II 1989, Corel Toulonnaise 1995, Corel Flying Fish 2000, AL Scottish Maid 2005,
Sergal President 2010, Mamoli Beagle 2011, Corel Eagle 2013, Mamoli Constitution Cross-section 2014, Victory Cross-section 1/98 by Corel 2015, Occre San Francisco Cable Car 2018, Model Shipways Armed Long Boat 2021
Card Models
Christmas Train by PaperReplika 2012, Yamaha DSC11 Motorcycle 2013, Canon EOS 5D Mark II 2014, WWII Tiger I Tank by Paper-Replika 2014, Wrebbit Mercedes-Benz 500K Roadster 2014, Central Pacific no. 60 Jupiter card model 2015, Mirage III 1/30 converted to 1/33 card model 2017, TKpapercraft 1912 Mercer 2021
