Hi Sjors, yes feeling really bad, but no beer at 11 in the morning. First the break and thereafter the beer. Rest assured there will be a stair so you donot have to make a split to enter the wheelhouse (a split can be very painfull and a one-off if you are not trained).
Regards,
John
<span style='font-family: courier new'>In progress: <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/177-king-of-the-mississippi-artesania-latina-scale-180/'>King of the Mississippi</a></span><br />
<br />
<span style='font-family: courier new'>Completed : <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/176-mare-nostrum-4331-artesania-latina-scale-135/'>Mare Nostrum 4331</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://modelshipworld.com/index.php?/gallery/album/51-16th-century-galeass-imai-scale-1160/'>16th century Galeass</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://members.upc.nl/carla.en.john/Modelbouw/Rocket.htm'>George Stephenson Rocket Locomotive</a></span><br />
<br />
<span style='font-family: courier new'>Next build : sl Louise</span>
Gentlemen thanks for the encouragement, that's probably the biggest value of this site, to support a member when he needed it most :D
Regards,
John
<br />
<br />
My ruined 3rd deck state-room. Or is this high tech weathering ?
My stupid action dissolved the paint of the doors and windows and smeared over the planking.
So a I have to redo the planking and painting, own fault. Anyway, it keeps me off the street.
<br />
<br />
not sure how you are going to proceed but this is what i would do. fix up the stateroom glue it all back on the deck and the ventilation openings .
wet the ventilation windows dowels at the bottom and clamp it down so that you get a bit of bend in it aftyer drying
the ventilation windows assembly has some wood parts to hold her in place. place a strip of 1 mm of wood on the bottom of it.
then when yuo glue her in place you need to push in a bit before it clicks in place and she should the curve  nicely
its something i am goign to try (without glue) so i cna remove the top part i f necessary to fix the lights :)
Current builds : HMS Bounty, Constructo Pilar
Next build : undecided
On the Shelf : AL San Juan, Mamoli HMS Victory
Builds on hold : Ochre Gorch Fock, Hachette/Amati Black Pearl
Previous Builds Gallery : Virginia; King of Mississippi
Previous Builds logs : AL King of Mississippi 1/80
Thanks Adrieke, however I was not able to bend the right curve to fit to the third deck. The weakness to do so are the window separators, they cannot hold the tension and at last I ended up with the mess I caused. Since I donot have to be able to remove this part I now choose for the simple way as done by Wim, namely by placing a stroke walnut veneer to close the gap between the ventilation windows and the deck.
Thanks for help thinking.
Regards,
John
<br />
<br />
Morning John,
Simple ways are always the best.
And if everybody is doing the same thing at there's paddle steamer, It just belongs like that.
Then AL makes a fault by not showing that in his drawings!
Thanks Sjors, I think the pictures published are from a customized ship and not from confection as supplied in the kit. It is as going on holidays, you never see those beautiful girls from the holiday brochure :( .
Regards,
John
<br />
<br />
Sodexo nog an toe
<br />
<br />
Have finished the second deck state-room ventilation windows and am still busy with the restauration of the third deck state-room. Will close the gap between the ventilation windows and the third deck lateron with a stroke of walnut veneer. I donot have the courage for another attempt to get the needed curve.
Regards,
John
<br />
<br />
Coming along very nice. You are progressing at a good pace.
Sjors, Adrieke and Geoffrey, thanks for the encouragement.
Regards,
John
<br />
<br />
At last finished the rebuilt of the 3rd deck state-room, so can now proceed further. Next step will be to add the wheelhouse, afterwhich I will glue the 3rd deck in place.
According to the parts list ramin wood 1x5x10 mm is needed to create the steps of the stairs. No wood with such dimensions in the kit, so have to do some shopping first.
Regards,
John
Edited by john46
<br />
<br />
John,
Excellent!  Very good looking boat....good progress!
Cheers,
Jim
:cheers:
Completed      Robert E Lee, Misisssippi riverboat
Completed,  HMS Victory Bow Section
Completed,  Wells Fargo Stagecoach...Picasa album....
Completed,  Lackawanna tugboat converted to private yacht...
Completed:  Sopwith Camel, 1:16 Scale, Model Airways...at another location...
Completed:  1961 Ferrari F-1 Sharknose
Completed: (sorta)  OcCre BR-18 Locomotive
Completed: 1/35 Pz.KPfw.III
Completed: Allerton Steam Pumper circa 1869
Thanks Jim
Sjors, thanks your wise words, I have the charachter of a terrier, I just cannot give up, even if I should.
Regards,
John
<br />
<br />
John nice work :)
did you have a look in the plastic containers. in my kit there where a few short pieces of the ramin ther efor the steps
You're right Adrieke, there are 5 pieces of 100 mm each, so exact the volume needed. Completely overlooked them, did not expect them there, buried under the United States flag. Next built I better follow your wise example and count/sort all the pieces before start crying :wacko: .
<br />
<br />
Thanks Robert.
Regards,
John
<br />
<br />
Thanks Wim, will show the result lateron.
Regards,
John
<br />
<br />
The wheelhouse in place, added the ship's bell and the start of the wheelhouse stairway. Next will be adding the borders and then place the whole on the ship in order to construct the stairways.
Regards,
John
<br />
<br />
Guest
This topic is now closed to further replies.
