 This is one of the top part of the mast on my plastic USS constitution build.  As you can probably tell from the pictures it’s slightly warped and it is real flimsy. I’d like to make a new piece of wood or something else that would be straight and a little bit more stiffer.  Any suggestions as to the type of wood to use or an alternative would be greatly appreciated.
Hi Antonio
I don't know what is available where you live, but where I live I can get a big package of bamboo skewers at my grocery store for a dollar or so. It is a lifetime supply of small diameter dowling and other uses! The type of wood, (Or in this case, grass) is not all that important as you will be painting it white anyway.
I am sure that someone with more knowledge and skill than I have will be along soon with more or better choices.
Good luck
Edited by lmagna
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Glad it worked for you. I think you will find that they have all kinds of uses as both parts source and tools.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
You might find when you rig your ship that minor warping of spars can be mitigated by the tension on the lines.
Steve
"If they suspect me of intelligence, I am sure it will soon blow over, ha, ha, ha!"
-- Jack Aubrey
Builds:
Yankee Hero, Fannie Gorham, We’re Here, Dapper Tom (x3), New Bedford Whaler, US Brig Lawrence (Niagara), Wyoming (half hull), Fra Berlanga (half hull), Gokstad Viking Ship, Kate Cory, Charles Morgan, Gjoa
Voila, worked out well, looks very good. Use the rest of the skewers to grill some shrimp & veg kabobs.
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
