Ahoy Muggebigge :D
I will get my chair for this one. Thanks for posting. Great start. I find a little irony in that (less the layup) it can take as much time to build this model as it took to build the real one, sometimes longer.
Edited by JPett
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
Ahoy Muggebigge :D
No Problem
Lots of pictures will do just fine.
Your english is also much better then my Swedish :P
  J.Pett
Greetings
,and another caldercraft victory to follow. You just enjoy your build . It is looking very good , and I will follow your log with interest.
Don't worry about your English, it no problem at all . Enjoy you build DAVID
it seams so long ago that i was at that stage, getting it right at this stage saves so much time later
looking good
all the best
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
HI Muggebigge..
Just wanted to say hello and welcome you and encourage you to continue posting your build.  I was reluctant at first to start a log but had so much persuasion from other Victory builders, I had no choice but to give in. You're going to be very happy that you started your log because I can guarantee you'll be getting a lot of help from other builders of HMS Victory. Good to have you and keep letting us know of your progress.;  Good luck to you....Jerry
Hello again
Things are looking very good indeed. Your work is excellent. Keep posting your photos and enjoy fitting the wales. Why is your ship on the cooker????? regards. DAVID
Hello muggebigge
The reason I mentioned the ship on the cooker is in time your ship will become a lot heavier and cumbersome and be prone to damage, being moved about a lot. Regards David
Lower whales done.Waterline sorted out and lining up some gunports.zipnrp.jpg        Getting slower now in the heat,Gonna have some time driving my motorbike and teach boyfrend to drive one :)
A better pic of my bike....Its an Suzuki Intruder 1400-93...Customize a littel :)2ngwm5i.jpg
A fellow petrolhead! (Although for me it's little 2-seater cars...
Vanguard Models on Facebook
345obgk.jpg        Manage to do this over the weekend
