Hello Pirates,
I m ready to plank the lower deck of my Revenge by Amati and I was wandering what is the rule to calculate how long a plank on the deck should be.
the scale of the kit is 1:64, I do not have a clue hoe long in real life the planks usually are.
thank you in advance
An average deck plank length would probably be about 15-20 ft, but you can fudge a bit on either side of that. At your scale, anything from 2.5 inches to 4 inches would be okay. You could even go a little longer and still be within reason. Good luck with your model.
Russ
If you look at the real deck planking patterns of the Vasa or the Mary Rose, you'll stop worrying about it :) It seems the driving concept of the period was to use whatever they had at hand, including 2 foot planks and wide planks and really narrow planks, fit together like the decks were done on All You Can Drink Free Beer day.
indeed.
Just look at the topic below ;)
In those days the hull planks were 4.2 to 5.2 meters long.
suppose that deck planks were 6.4m long (640 cm)
Then a deck plank  on scale 1/64 can be about 10 cm long maximum ( 4 inch).
The deck planking on my Golden Hind will have bits and pieces. :wacko::blush:
Gidday olopa.
My two cents worth.
Based on the above comments and advice.
As long as you find the end result aesthetically pleasing you have found your answer.
I hope I haven't confused the issue.
All the best with your build.
Mark.
41 minutes ago, pontiachedmark said:
Gidday olopa.
My two cents worth.
Mark.
thank Mark
more or less this is my view as well but i donnt
want to end up with a build that i like but looks ridiculously out of contest or proportion.
and i dont have enough experience, yet, to know what the boundaries are.
