extension
Imitation of tacks by a nielloed hornbeam
Imitation of tacks a brass wire
Попков Сергей Федорович
To do imitation of buttons of the case of the ship
I think the pictures you can see how this is achieved
Hello Sergey,
Thank you for sharing how to make treenails, or the buttons as you call them.
This is a tip that should also be posted in the Building, Framing, Planking and plating a ships hull and deck forum. Will you also post this here? http://modelshipworld.com/index.php?/topic/740-methods-for-making-treenails/page-8
Thank you!
Anja
Those we loved but lost are no longer where they were, but are always where we are.
In the gallery: Albatros 1840 - Constructo
Hello Sergey,
Thank you!
Anja
technology, manufacturing and installation of treenail placed on http://modelshipworld.com/index.php?/topic/740-methods-for-making-treenails/page-8 # entry52023
Test Pattern lifting eyes on skylights.
Not carefully done, but this is the first test. I need to scale
I found the best option
can be seen in the photos, I hope
Thanks for sharing this - I like the approach!  Nice looking result as well.
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Sergey,
Very nice work you are doing.  I like the way you improve the bad parts.
learning to weld the Silver solder brass
Composition: copper shavings, silver shavings, boric acid
the first test failed
improved decoration on the stern of the ship
hinges of the rudder ship
sharpening on the milling machine Proxxon M70, brass rod welded to a silver solder with a gas torch
painted in black hinges of the rudder ship with a solution:
  chemical solution 25% ammonia (ammonia), 100 g / l to 1 l
  Copper carbonate (CuCO3) 40-200 g / l
parts have been cleaned with a hot solution of citric acid
Edited by PSF
installed on ship hull pen of the rudder
Hello Sergey,
The hinges are great. They look much better then the ones provided in the kit.
Good job.
Anja
