23 hours ago, cog said:
My spies informed me you were "done" with it
Thanks Carl ! Yes, my Security Chief, Dr. Gundam, did tell me he encountered a group of your spies trying to penetrate the StealthWorks, but he chased them off.  But, Carl, you really must teach your spies to be more discrete; they left a very large and obvious trail of Hollandaise.  <pun intended>  But they did not succeed in discovering our next Stealthy project. ;)
Edited by Jack12477
Jack
Current buildUS Constellation
Thanks Steve and Craig.
Jack
Well done Jack, your use of artists oils has me integrated...may I ask how you prepared them to paint on plastic?  Did you have to prep the styrene in any way to get them to lay properly...how did you apply them?
JCT,  They aren't "oil" but rather water base artist acrylics.   I prepped the plastic with Tamiya Fine Surface Primer in a rattle can. I then applied the paint with a brush.  I dip the brush in water then take a dab of paint on the brush, then a little more water, then mix it around till it thins out then apply it to the model.  Same mixing/blending technique an artist uses to put acrylic on canvas.  I use a plastic egg carton style palette I get in Michaels. There is probably 4 maybe 5 thin coats of paint on the model when I am done I overspray with Testors Dullcoat to seal the paint and decals..
Winsor Newton produces both oil and water base artist paints.
Edited by Jack12477
Jack
Thanks, Marcus
Jack
Great work Jack it was an interesting build to follow. Congratulations
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Thanks Lou
Jack
