It seems most of the kits have instructions that have you plank the hull and then cut out the over-lap of the planking coming from both sides of the hull. My question is after the bulkheads are installed ,couldn't the keel  from bow to stern be installed and when you plank you could plank right flush to the keel instead of using a knife to cut away the over wood to lay the keel.???
Welcome!
To answer your question: yes, you can certainly do it that way, and many modelers do (I have). In fact, I don't think that the method you describe first is actually all that common, except maybe within the kit designs of particular companies. When attaching the false keel prior to planking, it is helpful to cut a rabbet into the profile former. Use the search function to find topics with rabbet in the title to find help on that subject.
Cheers!
:sign:
