Good Evening fellow shipsmiths
First a little intro about myself. I am a 35 years young man from South Africa, currently residing in Cape Town. I have done quite a few plastic models before and have enjoyed doing them. My uncle picked up a AL San Giovanni Battista about 15 years ago(which he is still doing) and this was my first introduction to wood modelling. For the last 5 years i have been working in construction which gave me a few skills for me to attempt a wood model. After finding this forum and these build logs i finally decided to do one and to do the Santa Maria by AL as it was one of the readily available ones here in Cape Town. I first wasnt going to do a build log but after seeing how much help others have gotten here am going to do one.
Onto the build. I started this build at the beginning December 2019, I dont have many earlier build pictures as over eagerness didnt leave time for pictures lol. I used many of the advice and ideas from the build logs here. Would like to thank whoever created all the articles in the database you have here. I got a lot of ideas from a user Katsumutso(sp) build of the Santa Maria and must say his build is absolutely stunning, not gonna measure myself against it lol. I didnt really have any trouble with the planking phase. I did make a few mistakes when assembling the false keel and bulkheads. i also did not check to see if my deck lined up properly with all my bulkheads and had to use a bit of wood filler as a result. I had more trouble with the veneer as it was harder to get it to bend the way i needed them to but in the end managed. A few pics to show you where I am currently.
IMG_20191220_222600.thumb.jpg.0f609ff96c8ba8e961a6bbf7d18b0b27.jpgIMG_20191220_222552.thumb.jpg.1d1824afab8d8ffd39e3c8896cb8cb72.jpg
imageproxy.php?img=&key=4f3b55ae31fcd018
Edited by NateB
welcome and good luck with the rest of the build which looks great so far
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thanks Kevin!!
A small building update from today. Next step is to do the gunwales. I have to do them in sections. Decided to use the laser cut as a mould/jig as bending onto something is easier than bending into something i find. Using a quilting iron to do all my bending, so far has worked really well.
So this is where I am currently. I have to do the last two sections which are done in 4 parts. This is where i start to have a problem as the wood supplied varies in coulor and I thought i would have enough of the darker walnut to finish the gunwales, will have to see what i want to do. Need to file and sand back the bits sticking over the knees. Will update when I have made progress.
you could lightly paint those areas
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Was thinking something along these lines, trying to find a good african walnut stain. Think i might have found one in a gel. Will have some updates soon
9 hours ago, the learner said:
first wood kit? looks like you are doing perfect!! yep diluted stain, no paint.
Thank you! What would I dilute the stain with? Paint thinners? And is applying with a cloth better than brushing?
17 hours ago, the learner said:
Water based or oil based? I would use water based and dilute with water brush on and wipe off with cloth. Let dry then apply again if needed.
Thank you. I actually think the one i want is water based. Will double check, just haven't had a chance to go past that side of the world yet to go get it.
A small minor update:
I was near the hobby shop and picked me up one of these Excel sanding sticks with belts on them. I need to sand my ship so i can either seal or oil it (not sure what i want yet). Its really working well at getting in those hard to get places. Especially where i have used too much glue, which is nearly everywhere hehe 😎
Pic of the stick
610133131_IMG_20200130_1136561.thumb.jpg.df45a4cf1fa9e7ab839f76c0ccb85d5c.jpg554289189_IMG_20200130_1137021.thumb.jpg.292a349785b6dc96c1b9adb92bddf04d.jpg
