This is pretty much a matter of personal preference. Either way will work. So will starting at the keel and working up, or starting at the keel AND bulwarks and working toward the middle. Main thing is to work on both sides equally, so as not to distort your hull.
Cheers!
Actually I would carefully plot the run of your wales first.  Then add those.   The wales will be a prominent feature and you want the run from bow to stern to be correct.   Measure off your plan and mark out the location at intervals along the hull.  Then plank above the wales and then start below the wales.   If your planking run is off ....especially the wales it will throw off the look of your entire model when completed.  Check out the many tutorials on planking in our database as that is a good place to start.
Chuck
My preference is as Chuck states, do the wales first, with one exception, that is if the wales are to be anchor stock or top and butt planks.   In that case I install the top strake of the lower thick stuff as a guide for the wales.  The top edge of the thick stuff will make it easier to form the curved bottom edge of the wales pieces.
Allan
