Is there a general rule or a table that gives diameter of various rigging lines/chains(links per inch)/wire depending on the scale of the model being constructed? I don't trust my eye to select the proper dia. From a photo and I don't want the rigging to be badly out of proportion. The model I am building is 1:74 scale. I am thinking that .028mm line looks right for the shroud lines but not sure what size to use for the running rigging.
HKC
Current (fist) build Billing's Danmark 5005 static
R.C. Anderson gives a rule of thumb in his Rigging of Ships in the Age of the Spritsail Topmast as follows:
Diameter of the Main Stay = 1/6 the diameter of the mast
Fore stay = 4/5 of the Main Stay
Mizzen Stay = 1/2 of the Fore Stay
Stay collars = 3/4 of the stay
Shroud and stay laniards = 1/2 of the stay or shroud, except main stay is 1/3
Shrouds are 1/2 of their respective stays, i.e. topmast shrouds are 1/2 of the topmast stay
Mast tackle pendants, backstays = 1/2 of the shrouds
Tackle runners are 2/3 of their pendant
Tackle falls are 1/2 of their runner or pendant
Ties = shrouds
Halyards = 2/3 of the Tie
Lift and Brace pendants = 1/2 of the shroud
Lifts = 3/8 of the shroud
Braces = 3/4 of the Brace pendant
Tacks = 1/2 of the shrouds
Sheets = 3/4 of the shroud
Clews = 1/2 of the sheet
Bowline = 1/2 of the shroud
Leechlines and Buntlines = 1/3 of the shroud
Blocks sheaves are 9 times the diameter of the line, blocks are 12 times the diameter of the line.
Hope it helps :)
Edited by popeye2sea
Henry
Laissez le bon temps rouler !
B.E.: I am building the Danmark. Built in 1932. Steel masts and yards.
HKC
HKC,
For a modern square rigger with wire standing rigging,
some of the main sizes (diameter in millimeters) would be as follows:
Lower shrouds: 0.33
Topmast shrouds: 0.3
Stays: 0.33
Topgallant stays:0.24
Lower braces: 0.33
Topgalland braces: 0.27
Lower lifts: 0.44
Topgallant lifts: 0.25
Other lines in proportion.
Hope that helps.
John
I am building the Danmark Scale 1:75 also and am wondering what running rigging proportions to use for a 1932 ship with the wire standing rigging. The info provided by John is a great start. Is there a definitive source for the Danmark? Is it built using 1850 style rigging proportions, but I don't see scaling using them since the masts are based on wood main lower mast diameter. Also would the blocks use steel strops?
Again is there a good resource for this type info.
Thanks for any help.
Tom in Beverly, Ma.
Tom,
The best source by far for 'modern' sailing ship rigging is Harold Underhill's "Masting and Rigging.  The Clipper Ship and Ocean Carrier".  You should be able to pick up a used copy from Abebooks for $25- - $30.
John
Tom,
John
Thank you.  Book is on order!
Tom
  • 6 months later...
Having problems attaching forward sails on a Danmark BB550. Does sail rigging 162, 167, 170, and 174 just feed thru the ends of the sails or attach to the sail at the ends? The plans are not clear. Anton T. at perthshipyard has been helping me on this rigging. Need to know how to attach photo of item
Edited by kayjdickerson
  • 7 years later...
Ties = shrouds
Hope it helps :)
I have only just found this which will be good enough for my means. Best regards and thank you  for posting this information. Dave
Completed     St Canute Billings            Dec 2020
Completed    HMS Bounty Amati          May 2021 Finished
Currently building HM Bark Endeavour
