In addition to the Independence, I am also working  on a model called the Mystique.  It is an older A/L model.   The problem I am having is that the bulwarks have a significant bend to them right out of the box.   My problem is that if I try to plank them length wise I will end up with a number of very thin planks with sharp ends.  My other alternative to plank them vertically which will entail a large amount of small planks.  My question is - are the inner bulwarks normally planked in a vertical or horizontal fashion ?
