Hello fellow builders. I have just completed the second planking on my HMS Flirt (Standard Edition). While I am reasonably pleased with the outcome, it is not perfect as there are small cracks between some of the planks. Can anyone recommend a good wood filler that would help address these imperfections? One consideration is how it will look on the unpainted areas - I'd like the colour to match closely the pearwood. Many thanks in advance for your advice.
Peter Halpenny
Ottawa, Canada
Welcome to  MSW Peter/
There are choices here.  Ideally, redo the planking so there are no gaps.   Realistically, it could be very difficult to match the pearwood.   You can try making a pile of saw dust with any pear wood that you may still have then make a putty of the sawdust and wood glue to fill the cracks. The finer the sawdust the better.  You can quickly make a pile of saw dust with a thickness sander or even a hand held orbital sander.   Even a sanding stick with a 220 or finer grit will  work, just takes a little longer.    It may not be exact, but might just be better and easier than trying to find a store bought filler that matches in color.
Allan
Peter
Not to name drop..... David Antscherl (in our local model club) once showed me that a dab of wood glue in the crack and a light sanding to move the sawdust into the glue made the crack disappear like magic.
Of course, he has a magic touch, and years of experience!
Try this on a test set up of two pieces of scrap before doing it on your model to see if it works for you.
Alan O'Neill
Well, there are "cracks," and then there are crevasses! But for cracks, I sometimes find a furniture finisher's crayon useful. These wax "filler sticks" or "crayons" come in a wide range of wood colors and can be purchased individually or in sets with a range of color. All you do is warm the wax in your hand to soften it a bit and apply to the crack and then rub away the excess. Fine furniture finishers use them to fill open joints and nicks and dings, as do gunsmiths on banged up gunstocks. They cost around three bucks apiece.
Color chart:  https://woodrepairproducts.com/product/fil-stiks/?gclid=Cj0KCQiAwf39BRCCARIsALXWETxVSo6lB0Guzfus1DrsLNcS6EnG11mDoXB0vhFS4_SFn8DkaBctn1kaAvsZEALw_wcB
