Got my ropewalk and this is a thing or beauty. I tried to do the wrapping by hand and it was difficult to say the least. With the ropewalk it is easy to do an everyone should have one.
To do the wrap on the top of the masts I just use a piece of brass wire through the one end.
Paul
Current Build: HMS Winchelsea 1764 1:48
Completed Build: HM Cutter Cheerful-Syren Ship Models 1/48
Completed Build:  Artesania Latina Bluenose II
Completed Build Lady Nelson
Have some of the rigging done. Learning as I go and have made some mistakes with the knots not staying tight but overall I can live with it since it is my first time doing this.
Trying different glues to see what works best for keeping the knots tight. I have settled on a 50/50 water/Modge Podge mix as it gets into the knots good and dries a satin.
Paul
So I am finished!
I learned a lot of new techniques and had a lot of fun. I think I am hooked.
Mistakes made and overcome and even though the instructions were not the best because of the lack of plans I worked through it.
Here are the finished pictures.
Paul
Very nice model!  I like the contrast the veneer makes below the waterline.  Thanks for sharing the build.
Bob
Current build -- MS Bluenose
Future build - MS Flying Fish
"A ship is safe in harbor, but that's not what ships are for." - William G. T. Shedd
On 3/18/2021 at 2:10 PM, PRS said:
OK so that didn't turn out too bad. I might have been better using thread and tying them but I will go with this.
Here is where I am at so far with things mounted on the deck.
Paul the railing on the aft deck has a cut away which instructions say is 59mm long. Does the cut away face inwards or outwards?  Instructions don't really show it.
Hi Chap,
Very nice build!!
I'm hooked also, I think it's partly due to the scent of the A/L new kit wood.... 🙂
Wot's next?
Cheers....HOF.
Edited by hof00
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
Sergal/Mantua Cutty Sark
A/L Pen Duick
A/L Fulgaro
Amati/Partworks 1/200 Bismarck
A/L Sanson
Not sure which railing you are referring to. The railing at the very rear is curved and only goes one way. I agree the instructions are lacking.
Paul
  • 2 months later...
Paul,
Just checking your earlier builds and your way of working is even more methodical than mine...
Very inspiring, good tips and techniques with beautiful results!
Frank.
Current builds on MSW:
HMS Winchelsea 1:48
Prior builds on MSW:
None
